Old 02-28-2008, 01:53 AM   #1
imprezdrs00
Member#: 169156
Question AC fuse out?
Hi, i own a 2000 impreza 2.5rs. I havent used the a/c for about 6 months and the other day i tried to turn it on and it did not work. I notice that when i push the a/c button on the console, the compressor does not turn on. also the light in the a/c button does not turn off and on when i push the button which leads me to think that some connection or fuse is out.
Can anyone help me out or give me some kind of advice suggestions?
Thanks.
imprezdrs00 is offline   Reply With Quote
Old 02-28-2008, 02:17 AM   #2
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
pump needs freon to operate.
Old 02-28-2008, 02:27 AM   #3
imprezdrs00
Member#: 169156
ok, but is there a reason why the light on the button doesnt work? if it is an electrical problem what would you suggest?
Old 02-28-2008, 02:29 AM   #4
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
can't help with electrical prblem sorry
Old 02-28-2008, 08:54 AM   #5
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
check the fuses first.
Old 02-29-2008, 04:00 PM   #6
imprezdrs00
Member#: 169156
^ok thanks anyways gti.
- the one under hood in the fusebox or are there any others like under the dash or something? i looked in the fusebox when i first noticed it and well im not real experienced, so besides seeing that the a/c fuse was still there i didnt really know what to look for. what should i check for to see if its still good? also the fuse for the a/c in the fusebox is a bigger black one, and there is only a puller for the small one so is there a special way to remove it without damaging something or can i just pull it out?
thanks for your help. i really appreciate it.
Old 03-02-2008, 09:33 PM   #7
imprezdrs00
Member#: 169156
any help?
Old 03-02-2008, 11:11 PM   #8
RexyGirl
Member#: 63616
1996 Volvo 850 Turbo
with mods :)
Yes there are also fuses inside the car. On the drivers side close to the door there is a panel...behind the panel the fuses are labled
It could also be a relay under the hood, which is the bigger "fuse".
RexyGirl is offline   Reply With Quote
Old 03-26-2008, 02:22 AM   #9
imprezdrs00
Member#: 169156
where would i find the right fuse to replace it?
Old 03-26-2008, 05:25 PM   #10
nme187
Member#: 117763
Take out that a/c relay inside the fuse box in the engine compartment then take it to a local autozone/checker and theyll test it for free. I don't recall seeing any a/c fuses inside the cabin but if so take it out and inspect if the wire/arc inside the fuse is blown/burnt if so then replace that. it says the size/number ontop of the fuse. GL.
nme187 is offline   Reply With Quote
blowing AC fuse Steve B Electrical & Lighting 1 10-15-2009 12:24 PM
Blows AC Fuse Steve B 'Old School' Subaru Forum 0 10-14-2009 08:14 PM
AC fuse keeps blowing blackcloud Electrical & Lighting 0 05-17-2009 11:39 PM
THis is what happened when I took IGN fuse out derekok Electrical & Lighting 1 03-01-2007 07:01 PM
AC going out? DarkShadow Texas Impreza Club Forum -- TXIC 1 07-21-2003 11:24 AM
