Old 02-28-2008, 06:45 AM   #1
Guerice
Member#: 51519
2006 2.5i Wagon
AKA Drtywgn
Default 2006 Intake manifold
Anyone have a pic of the end of the runners on a plastic intake manifold?
I just wanna check if it would fit my Phase 2 EJ22
Thanks
Guerice is offline   Reply With Quote
Old 02-28-2008, 08:47 AM   #2
zavier
Member#: 141189
2007 2.5i (NBP)
2014 BRZ (DGM)
Thanks
they aren't plastic till 2008 (and are they even plastic for the N/A 2008's? i thought it was just the WRX/STi that had the plastic mani)
zavier is offline   Reply With Quote
Old 02-28-2008, 10:41 AM   #3
Guerice
Member#: 51519
2006 2.5i Wagon
AKA Drtywgn
I was just refering to the other tread here,
OK so does anyone know if the 06 aluminium manifold has the same shape as this one?
Old 02-28-2008, 11:03 AM   #4
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
The gaskets are the SAME SHAPE at the port inlets and same bolt pattern. This is same for PHASE 2 2.2L/2.5L intake manifold gaskets. The only difference is the pins which the gaskets slides onto to keep them from moving.
HOWEVER, I do want to see the runners and how BIG they are. I want them to be big like the WRX.
FuJi K is offline   Reply With Quote
Old 02-29-2008, 10:24 AM   #5
Whiteghost 2.5
Member#: 72994
2001 Racekor
Emerald Green
i have an 06 intake manifold I can take some pics tonight
Josh
Whiteghost 2.5 is offline   Reply With Quote
Old 02-29-2008, 10:45 AM   #6
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
Josh
If you can put the intake manifold gaskets on it, that'll help as well.
Kind of like the ones I took here. TOP is the WRX TGV section w/ the TGV deleted, bottem is 2.5L PHASE2 manifold; 2.2L PHASE2 is the same
Old 02-29-2008, 04:22 PM   #7
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Thanks
The '06 intake manifold is nothing special. The '05-07 N/A EJ25s all use the same cast aluminum IM. I believe there were some '04 EJ25s (maybe only in the Legacy and Outback?) that used a plastic IM. I don't know about the new models.
AFAIK, the thought that the '05-07 IM is better than the other N/A manifolds is simply based on the fact that Irish Mike/TWE used that IM on their 300hp N/A race motor build. I've never seen any flow numbers or anything like that to compare the '05+ to the -'04 manifold(s). I think it's safe to assume that Irish Mike/TWE did their homework and used the '05+ IM for a reason.
Whether it would bolt to your EJ22, I don't know. I was under the impression (perhaps mistaken) that the EJ20 and EJ25 IMs were interchangeable (assuming the correct bolt pattern at the heads), but the EJ22 IMs were different. I could be wrong.
While I don't have any measurements for you, here's a pic of a N/A DOHC gasket on a '05-07 manifold, so that might give you some frame of reference.
I would say the runners are only slightly bigger than the EJ25D IM where they bolt to the heads - maybe a millimeter here or there?
Pat Olsen
Old 02-29-2008, 05:06 PM   #8
cueball89
Member#: 90513
2003 wrx wagon
black
Here's a phase 2 ej22 manifold for comparison.
cueball89 is offline   Reply With Quote
Old 02-29-2008, 06:03 PM   #9
Guerice
Member#: 51519
2006 2.5i Wagon
AKA Drtywgn
Thanks guys,
Pat, do you have a pic of it without the gasket or maybe with a P2 EJ25 like cueball?
Old 02-29-2008, 10:14 PM   #10
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
No straight-on shots without the gasket, and since I have P1 heads I only have the P1 gaskets.
Pat
Old 03-01-2008, 12:13 AM   #11
piker28
Member#: 22664
yeup my 04 has a plastic intake manifold i dont see much thrill in it i mean going from my 03-04 felt the same in all levels
piker28 is offline   Reply With Quote
Old 03-04-2008, 08:31 PM   #12
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
What's required to put the '06 manifold on a '99-'03?
Because this would work beautifully with my ported EJ251 heads!!!!
Old 03-04-2008, 09:04 PM   #13
Storm
Member#: 5218
96L Most Over-
Developed Beater
A throttle cable bracket for sure....not sure what else.
Jay Storm
Old 03-04-2008, 09:27 PM   #14
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
Search for posts by SOLUTION about installing (or attempting to install) an '05+ manifold. The big issue was the IAC, I don't think he ever got it resolved.
Pat
2006 wrx MANIFOLD intake manifold ported and polished SUBIEDUDE33 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 10 03-26-2008 01:23 PM
Tmic, Intake Manifold & Vf39 Sti 2006 diplo12 Engine/Power/Exhaust 17 04-19-2007 05:18 PM
2006 STI intake manifold, DBW throttle body, wiring harness, DBW pedal Cstmboxermotorsports Engine/Power/Exhaust 0 12-11-2006 06:52 PM
FS/FT: COMPLETE 2006 STI INTAKE MANIFOLD w/DBW pedal ect... super low km! Cstmboxermotorsports Engine/Power/Exhaust 3 12-09-2006 03:18 PM
