Old 02-28-2008, 10:24 AM   #1
UpstateNYRS-T
Member#: 158497
Default Overheating Problem in RS-T
Past few days after i installed a FMIC on my car it will sometimes start to overheat when at a red light or stop sign never when im driving, but my heat still works 100% and radiator fans work. When i start accelerating the temp goes down back to normal then will rise again sometimes i burbed my system for air bubbles twice to see if that would help but i guess it didnt, my car has 123k miles new water pump, thermostat, T-chain, and radiator cap. Also its cold out below freezing which is weird why it would overheat thinking maybe its my radiator on its way out i heard they go on subbys around 100k miles???? Also i touch my radiator cap its not hot but the top hose is warm/hot very weird anyone got ideas????
UpstateNYRS-T is offline   Reply With Quote
Old 02-28-2008, 11:36 AM   #2
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
head gasket failure....
Jamie
Old 02-28-2008, 11:43 AM   #3
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
or your FMIC is blocking the air flow across the radiator at idle, you may need stronger fans to pull more air through there.
Does the car consume coolant? Have you had the cooling system pressure tested?
Old 02-28-2008, 12:16 PM   #4
UpstateNYRS-T
Member#: 158497
Don't consume coolant, and no haven't had it tested yet but i see a very small bubble coming outa my coolant reservoir every like 30-45seconds and when i first ran my FMIC I didn't have any reservoir attached so im thinking maybe my coolant system got air into it but i tried to burp it by opening the radiator cap max heat to floor and let it sit for 10 or so min is that correct i didn't touch the throttle or anything???
Old 02-28-2008, 12:21 PM   #5
UpstateNYRS-T
Member#: 158497
Only reason i don't think its the head gasket is because the car never did this before i put in the FMIC a few days ago and it didn't do it at first, only like 2-3 days after and it progressively does it less and less??? Soooo weird
Old 02-28-2008, 03:40 PM   #6
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
what year is your RS?
Old 02-28-2008, 03:43 PM   #7
UpstateNYRS-T
Member#: 158497
2002 2.5 rs
Old 02-28-2008, 04:16 PM   #8
UpstateNYRS-T
Member#: 158497
could it be because my reservoir is a soda bottle empty of coruse filled with coolant and on a weird angle??? sometimes coolant fills up over the soda bottle and spills out on my engine RARELY...?
Old 02-28-2008, 10:28 PM   #9
UpstateNYRS-T
Member#: 158497
I put back my normal coolant reservoir and removed the soda bottle i had when i dumped the coolant out of the bottle i saw there was a little greenish dark slime on the bottom of the bottle what is that does this mean i need to flush my coolant could that be clogging up my system???
Old 03-01-2008, 07:24 PM   #10
Speck102
Member#: 135117
2005 CL65 AMG
2005 350z
It's probably a combination of an air bubble (or possibly that green slime in your system), and the FMIC blocking air to your radiator.
Speck102 is offline   Reply With Quote
Old 03-02-2008, 10:02 PM   #11
UpstateNYRS-T
Member#: 158497
You think if i buy a new radiator OEM one it would fix it??? What about a Koyo??
Old 03-04-2008, 10:33 AM   #12
UpstateNYRS-T
Member#: 158497
bump!
Old 03-11-2008, 09:19 AM   #13
UpstateNYRS-T
Member#: 158497
Bad day.....so today i was driving to my friends house from school on my way there i noticed my temp gauge was going up FAST hit the red which normally before it would only go up when i would stop at a light or something i thought it actually was getting better.....guess not.... so i pulled over turned the car off popped the hood noticed coolant sprayed outta the overflow bottle let it sit blasted the heat ....waited 5-10min started it up temp was back to normal but idle sounded weird and i noticed white smoke coming outta my tail pipe....drove it 1/4 mile started overheating again went into the red pulled over again called tow truck was towed to the shop i take my car to....I'm thinking head gasket????? Also i checked my oil and coolant both good they didn't mix so weird i know that don't always happen with blown head gasket but anyone got ideas???
Old 03-21-2008, 04:55 AM   #14
pheonix991
Member#: 154173
2006 STI
Bump to find out result. I have pretty much same exact problem, need to know if it is HG.
pheonix991 is offline   Reply With Quote
Question on overheating problem, can't post in technical forum Daralantan Newbies & FAQs 8 11-28-2008 10:25 PM
Overheating problem in an 05 Sti jpjones5860 Newbies & FAQs 5 09-30-2006 02:26 PM
New RS-T with overheating problem WRX 555 STi Normally Aspirated with bolt-on Forced Induction Powertrain 32 03-11-2003 09:41 AM
('93-'01) Overheating Problem.... Help! (kinda long) but important SubaTubaru Impreza Forum 15 05-27-2001 04:34 AM
Minnam Stage II overheating problems??? Scoobyfan General Forum Archive 6 12-07-2000 09:46 AM
