Old 02-28-2008, 10:43 AM   #1
KillerBumbleBee
Member#: 120116
2003 Subaru
Yellow
Default ea82t into an ej18
I've been looking into engine options for me old ej18 impreza hatch. One option that I was looking at was the ej22t, which I've heard can be run off of the ej18 ecu. is this also true of the loyale ea82? compatibility issues? thanks
KillerBumbleBee is offline   Reply With Quote
Old 02-28-2008, 12:38 PM   #2
DSM_Outback
Member#: 56345
93 Swapped L
Green
Bad idea. Cracked heads & blown head gaskets galore.
EA82t = saddest Subaru engine ever, EA82t FTL.
DSM_Outback is offline   Reply With Quote
Old 02-28-2008, 01:23 PM   #3
Numbchux
Member#: 71658
'84 Brat
4" lift and 29" tires
^ agreed. the EA82t is definitely the crappiest subaru motor ever made!
also, the EA series uses a different bellhousing pattern, which can't be mated to an EJ trans (can go the other way though....). completely different management. the EAs have a distributer.....
run, do not walk, to your nearest exit
Numbchux is offline   Reply With Quote
Old 02-28-2008, 07:24 PM   #4
kheff46
Member#: 66739
2002 WRX wagon
basically any EJ engine you can find will fit and possibly run off the 1.8's ECU(maybe not perfect depending on the displacement).
--keith
kheff46 is offline   Reply With Quote
Old 02-29-2008, 03:54 PM   #5
ChuChi
Member#: 128662
2006 WRX
Slight thread jack, but I want to clarify this. If I have an EA82 and 'procure' an EJ22, it'll bolt right up to the existing tranny? I can swap engines and keep my d/r? That would make me very happy
ChuChi is offline   Reply With Quote
Old 02-29-2008, 07:12 PM   #6
Numbchux
Member#: 71658
'84 Brat
bolt right up......no. the bellhousings are different. but it works out with an EJ engine and EA trans, there's room to use an adapter plate. but won't work the other way around.
"some" info on the swap:
http://www.numbchuxconversions.com/Files/EA2EJ.pdf
my car:
http://www.numbchuxconversions.com/frankenwagon.htm
GL-10 EA82T into 93 Loyale!!! HELP ME! loyalesti 'Old School' Subaru Forum 2 10-15-2006 12:32 PM
EA82T into EA82 car jeffg Subaru Conversions 10 02-12-2006 12:45 PM
Would the EJ22 bolt into an EJ18 as easy as the EJ25 bolts in? Max Umbarger Subaru Conversions 16 02-27-2004 11:51 AM
ea82t into a legacy? legacy2003 Subaru Conversions 2 01-01-2004 03:00 PM
Why Swapping an EJ25 with an EJ18 is bad...Comments? SubieKidTK Normally Aspirated Powertrain 20 06-13-2001 06:53 AM
