Old 02-28-2008, 11:19 AM   #1
overdose
Member#: 46399
0000 Knows nothing,
about nothing.
Default STG1/stock 05 sti rom?
where are these canned maps floating around at?
overdose is offline   Reply With Quote
Old 02-28-2008, 11:28 AM   #2
Bullwinkle1983
Member#: 172332
2006 WRX
Bullwinkle1983 is offline   Reply With Quote
Old 02-28-2008, 12:30 PM   #3
overdose
Member#: 46399
0000 Knows nothing,
about nothing.
registered there, didn't see anything free, just xpt trying to sell theirs
Old 02-28-2008, 05:42 PM   #4
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
just make your own. all thats done in most stage 1 maps is increasing the boost, get rid of the OL/CL delay, defeating some CEL codes, a little timing tweaking, and AFR tweaking.
Just go here and copy what Cobb does on their stage 1's....look at the "Map Notes" for your car and octane, they tell you exactly what they've changed
http://www.accessecu.com/accessport/...04STiMaps.html
"Original Mapping. Adjusted Fuel, Timing, Boost, closed loop control, and base
programming logic."
"Target peak boost pressure is approximately 16.5psi +/- 0.5psi depending on vehicle
and conditions. Boost will likely taper to ~14.5psi by redline to increase
reliability. This is due to high exhaust gas backpressure and thus heat created at
higher RPM and high boost. When the exhaust system is further optimized with Stage2,
we are able to increase boost levels at higher RPM."
"Target A/F Ratios are mid 12's under load before the onset of boost. Under full load
by 4000 RPM the A/F Ratio should drop to mid 11:1 and gradually run richer as RPM
increase ending at high 10:1 A/F at redline."
Old 02-28-2008, 05:54 PM   #5
testes1010
Member#: 47145
2012 Gas Saver
you didn't look too hard.....it was even on the first page....
http://plasmatize.com/osecuroms/view...9655f5f9a00212
testes1010 is offline   Reply With Quote
Old 02-29-2008, 05:33 PM   #6
turboge
Member#: 35076
2004 507whp Wagon
The XPT stage 1 for the STi is pretty nice, a great upgrade for a bone stock car with a K&N panel filter.
turboge is offline   Reply With Quote
Hard Drive fried - I need a stock 05 RS Rom formula91 Open Source Reflashes 1 02-03-2010 06:42 PM
FS: stock 05 sti side feed TGV's, stock 05 sti up pipe sartre311 Engine/Power/Exhaust 1 11-15-2009 11:22 PM
FS: stock 05 sti side feed TGV's, stock 05 sti up pipe sartre311 SWIC Private Classifieds 0 08-19-2009 04:41 AM
FS: So Cal. Stock 05 sti downpie/ Stock 05 intake with k&n b20todaej6 Engine/Power/Exhaust 7 03-28-2008 04:48 PM
stock 05 STi suspension VS stock 05 RS suspension erikm Brakes, Steering & Suspension 5 03-15-2006 10:55 AM
