Old 02-28-2008, 01:11 PM   #1
justinkarim
Member#: 138614
2008 WRX
Charcoal Gray
Default 2.5i Pitch Mount
What are your thoughts on the GroupA pitch mount on a 2.5i? Has anybody running this felt a difference in anything?
justinkarim is offline   Reply With Quote
Old 02-28-2008, 01:35 PM   #2
Gr3en
Member#: 160991
05 Corn Burner
Dirt Silver?
Get motor mounts instead. You will not need a pitch stop. www.rallispec.com has great pricing.
Gr3en is offline   Reply With Quote
Old 02-28-2008, 02:16 PM   #3
iRick.
Member#: 158155
just curious. i purchased some sti engine mounts
worth installing on a stock engine?
iRick. is offline   Reply With Quote
Old 02-28-2008, 07:04 PM   #4
jeisen
Member#: 27258
who dat be dat was?
the group N pitch stop mount caused no difference in feel for me.
jeisen is offline   Reply With Quote
Old 02-28-2008, 07:18 PM   #5
code_hat
Member#: 90896
CO RallyX'er
circuitmotorsports.net
Motor mounts on a stock car are great for keeping the motor a little more stuck in place, but you'll feel more vibration in the cabin. Regardless, if you don't mind this, it's a good upgrade to put a little more power down to the wheels. Not like you'll notice the difference with a 2.5i though....
As for the pitch stop comment above; If you're going to get motor mounts, you might as well get the pitch stop. Do it if you're going to do it. Just because you get harder motor mounts doesn't mean that the engine won't pitch in position still. Under hard acceleration it definitely will.
code_hat is offline   Reply With Quote
Old 02-28-2008, 09:32 PM   #6
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
engine mounts - tranny mounts = good investment
not sure I would recommend the pitch mount stopper
Old 02-28-2008, 09:34 PM   #7
rougeben83
Member#: 115154
2005 Outback XT
White on grey
Engine mounts first. But if you want something to fiddle around with to install yourself, the pitchstop is fine I guess. You may want to get one of those beefier units they sell (granted more expensive)
rougeben83 is offline   Reply With Quote
Old 02-28-2008, 10:39 PM   #8
iRick.
Member#: 158155
so the sti engine mounts i got for $50 was a good purchase? sick
i felt like i wasted my money when i bought them
Old 02-29-2008, 11:00 AM   #9
rcortez13
Member#: 157313
2007 2.5i
Obsidian Black
That was a steel depending on how old they are. I paid around $150 at Flatirons tuning for the Group N mounts. Here's just a helpful hint make sure you use your stock plates from your stock mounts.
rcortez13 is offline   Reply With Quote
Old 02-29-2008, 11:10 AM   #10
rcortez13
Member#: 157313
2007 2.5i
Obsidian Black
I disagree with the first statement. You will notice a difference with the engine mounts. If you want to notice even more of a difference install the tranny mount as well. I am running all of the above.
I agree with the second statement. If your going to do it, do it all. I would have done the Pitch mount but they were out of stock at the time of my purchase.
"Every Little Bit Helps"
Old 02-29-2008, 01:16 PM   #11
SilverSubie2.5
Member#: 136144
2006 WRX Wagon
CGM
Excuse me for asking, but since I haven't seen it come up in here yet, what is the benefit of going with hardened motor/tranny mounts? I know they reduce movement, but what does that translate to in drving feel?
SilverSubie2.5 is offline   Reply With Quote
Old 02-29-2008, 02:36 PM   #12
iRick.
Member#: 158155
they were off a 2006 STI. i dunno. guy told me 30k miles
Old 02-29-2008, 08:51 PM   #13
rcortez13
Member#: 157313
2007 2.5i
Obsidian Black
Less motor twist or movement translates to power getting to the wheels faster. Think of it kinda like better throttle response.
Old 03-25-2008, 12:05 AM   #14
ShadowVlican
Member#: 156965
with the engine or pitch mount installed, can our little 2.5L motors make the car shift side to side like mustangs?
also, is a tranny mount recommended for slushboxes?
ShadowVlican is offline   Reply With Quote
Old 03-25-2008, 01:51 PM   #15
LTracer
Member#: 167703
2005 '05 2.5RS 5MT
'10 Forester X Limited
Installed the GroupA Pitch Stop on my '05 RS, performance wise I noticed nothing, however it looks cool and I didn't really notice a change in NVH aside from a little louder engine braking. In retrospective I would have saved the coin to invest in suspension parts or tuning books.
LTracer is offline   Reply With Quote
Any difference between stock 04 STi pitch mount and wrx pitch mount Serkan Brakes, Steering & Suspension 1 02-10-2010 08:45 AM
FS!2.5i sedan stock rear sway bars,front & rear endlinks,rsb mounts & Springs 07impreza2.5i Suspension/Brakes/Handling 8 12-12-2009 07:23 PM
Group-N Pitch Mount identical to '05 Pitch Mount? WolfPlayer Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 30 10-07-2007 08:16 AM
STi pitch mount fit 2.5i engine? ScubaruImpreza05 Normally Aspirated Powertrain 7 05-28-2007 07:36 PM
PA: OE '00 2.5RS engine pitch mount Siper2 Private 'For Sale' Classifieds 2 01-17-2006 10:23 AM
