Welcome to the North American Subaru Impreza Owners Club Tuesday May 5, 2015
Old 02-28-2008, 02:24 PM   #1
RingU
Member#: 137243
2004 2.5L WRX JPB
1999 Civic EX White
Default Can't Pass Emissions. Need Alternative fast!
I have a 2004 Subaru WRX with these mods:
Cobb Accessport V.2
Machined Stock 2.5L Shortblock (has 19,000 miles)
Turboback
TurboSmart Blow-Off Valve
Copper Spark Plugs
Exedy Twin Plate Clutch/Flywheel
Ultimate Racing T3/T04 (Turbonetics 600 hp)
Supertech .5mm oversize valves
Top Mount Intercooler
Cometic Head gaskets
Tial WasteGate
uppipe
785cc Fuel Injectors
Cosworth Oil Catch Can
Up Pipe
Cold Air Intake
Fuel Pump
Oil Pump
Is it possible for me to put the stock downpipe and turbo to pass emissions??? I dont have stock Injectors or Intercooler (Upgraded TMIC) Do i have to Reset the ECU? what exactly am i supposed to do? Someone plz help . Thank you
Ivan
RingU is offline   Reply With Quote
Old 02-28-2008, 02:29 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
How about adding some vital information, such as your location (please complete your profile) and the nature of the emission testing (sniffer, dyno, or OBDII scan)?
This may also be better asked in your regional forum for a more accurate answer.
Old 02-28-2008, 02:36 PM   #3
RingU
Member#: 137243
2004 2.5L WRX JPB
1999 Civic EX White
Im located in Prospect Heights, IL. They have a OBDII Scanner.
Old 02-28-2008, 02:44 PM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
To pass an OBDII scan you must have-
-properly functioning CEL (goes on with key, off when engine starts)
-no stored codes
-all readiness monitors in "complete" or "ready" status
If you reset the ECU, either with a scanner or by disconnecting the battery, just before going for the test the readiness monitors will all be reset to "not ready" and must run their cycles from the beginning. This can take several days of driving or more, depending on the length and type of trips. So, if you go for inspection immediately after a reset you will fail.
There may also be a visual inspection for any removed or tampered-with emissions components, which you will of course fail with a catless exhaust.
Old 02-28-2008, 05:47 PM   #5
mmiller2002
Member#: 159286
2002 WRX Wagon,Com-C
RCE wgn sprngs/Konis/H6
Whenever I read about all the modifications done on this board, I always wonder about passing state inspection.
mmiller2002 is offline   Reply With Quote
Old 02-28-2008, 05:59 PM   #6
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
If you have engine management which takes care of the codes (or things like the resistor fix for a catless up-pipe) it's not a problem - particularly if they only do an OBD2 scan - if you have sufficient driving cycles on the car, you are good to go (any decent obd2 scanner will tell you if your car is ready to pass emissions or not) - if they do a sniffer, as long as you aren't catless, you are still fine - if you are catless, though, you will likely fail a sniffer (and will almost certainly fail a visual inspection unless the tech looks the other way or is an idiot)
Old 02-28-2008, 08:47 PM   #7
sovietjet
Member#: 76600
2008 BMW M3
If you've been driving a while and have no check engine light, you'll probably pass. They never do visual inspection here in IL.
sovietjet is online now   Reply With Quote
Old 03-10-2008, 12:45 PM   #8
RingU
Member#: 137243
2004 2.5L WRX JPB
1999 Civic EX White
I just passed Emissions today. Took it to P and L motorsports and they found out the problem.. fried Rear o2 Sensor and a bad fuel pump line. Thanks everyone for your help.
ACT flywheel throwing codes-can't pass emissions rolzrex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 26 09-06-2008 04:56 PM
Can't pass emissions help!!! josh04 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 01-30-2008 04:10 PM
Can't Pass Inspection, Need Help??? (Philly) 05Massacre Tri-State Area Forum 5 06-05-2007 10:23 AM
Can't pass emissions in Davidson county (High Point NC) HELP! mneste8718 South East Region Forum 8 08-17-2006 11:10 AM
check engine light won't go off and can't pass emissions.. jefersun Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 11-14-2003 10:16 AM
