Welcome to the North American Subaru Impreza Owners Club Friday July 11, 2014
Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Gauges & Electronics
Old 02-28-2008, 04:36 PM   #1
JBK Performance
Vendor
Vendor Sales Rating: (27)
Member#: 135346
2003 wrx
Default Defi Racer Red, White & Blue Deals+Aem,Autometer,Defi
GAUGES AND PODS
Great Deals (Pm,Email, or IM for Great Deals)
Prices way to low to advertise
Pm for ALL Gauges and other accessories
CONTACT INFO:
P: 407.412.9551
F: 860.295.3077
E-mail: Orders@jbkperformance.com
DEFI
BF Series (60mm)
Features:
  • Brightness adjustment: 10 stages of brightness, 5 stages in the daytime and 5 stages at night.
  • Driving data can be stored and can be replayed up to 3 minutes.
  • Double Warning function by a meter's LED lamp and a beep
  • If Defi-Link Indicator(sold separately) is connected, it blinks when any of connected meters' warning LED light.
  • Defi-Link Indicators can be connected to each gauge.
  • Differential pressure between fuel pressure and turbo can be shown if both of fuel pressure meter and turbo meter are installed. Gauges have peak hold and warning features
  • All Gauges are 60mm
  • Defi-Link Control Unit II is necessary to operate Defi-Link Meter BF.
SI Units
Amber Series:
Part No.
Boost Gauge (in KPA):DF04302
Oil Pressure Gauge (in KPA):DF04402
Fuel Pressure Gauge (in KPA):DF04502
Oil Temperature Gauge (in Celcius):DF04602
Water Temperature Gauge (in Celcius):DF04702
Exhaust Gas Temperature Gauge (in Celcius):DF04802
White Series:
Part No.
Boost Gauge (in KPA):DF04301
Oil Pressure Gauge (in KPA):DF04401
Fuel Pressure Gauge (in KPA):DF04501
Oil Temperature Gauge (in Celcius):DF04601
Water Temperature Gauge (in Celcius):DF04701
Exhaust Gas Temperature Gauge (in Celcius):DF04801
Imperial Units (US)
Amber Series:
Part No.
Boost Gauge (in PSI):DF04304
Oil Pressure Gauge (in PSI):DF04404
Fuel Pressure Gauge (in PSI):DF04504
Oil Temperature Gauge (in Fahrenheit):DF04604
Water Temperature Gauge (in Fahrenheit):DF04704
Exhaust Gas Temperature Gauge (in Fahrenheit):DF04804
White Series:
Part No.
Boost Gauge (in PSI):DF04303
Oil Pressure Gauge (in PSI):DF04403
Fuel Pressure Gauge (in PSI):DF04503
Oil Temperature Gauge (in Fahrenheit):DF04603
Water Temperature Gauge (in Fahrenheit):DF04703
Exhaust Gas Temperature Gauge (in Fahrenheit):DF04803
RACER SERIES (52mm)
ALL IN STOCK NOW !
Ignition off
Features:
  • Does not require and can't be used with the Defi-Link Control Unit
  • Ignition ON initiates self-luminescence gauge.
  • Lightning-like Opening / Closing mode with Blue illumination using high-brightness LEDs
  • Self-diagnostics function monitors both sensor disconnection and short-circuiting during startup.
  • The red triangle of the regular position bezel can be used as a warning indicator.
  • Full 270 degrees sweep dial provides ultimate visibility.
  • All Gauges are 52mm (2 1/16")
  • Temperature gauge used for Water or Oil- Pressue Gauge used for Fuel or Oil
Ignition on
(Blue)
Model # BLUE:
BOOST
-30inHg to +30PSI DF06501
PRESSURE
0 to 140PSI DF06601
TEMPERATURE
100 to 300F DF06701
EXHAUST TEMPERATURE 400 to 2000F DF06801
VOLT 10 to 15V DF07004
Model # RED:
BOOST -30inHg to +30PSI DF06502
PRESSURE 0 to 140PSI DF06602
TEMPERATURE 100 to 300F DF06702
EXHAUST TEMPERATURE
400 to 2000F DF06802
VOLT 10 to 15V DF07005
Ignition on
(White)
Model # WHITE:
BOOST -30inHg to +30PSI DF06503
PRESSURE 0 to 140PSI DF06603
TEMPERATURE 100 to 300F DF06703
EXHAUST TEMPERATURE
400 to 2000F DF06803
VOLT 10 to 15V DF07006
Controllers and Indicators
Part No.
Defi Link Control Unit II:
(DF05002) Required for Defi BF Series Gauges.
Defi Link Indicator II: DF05801
Defi Single Meter Hood Visor: DF05201
Defi Link Display: DF05101
Last edited by JBK Performance; 05-31-2009 at 06:16 PM. Reason: Red Racer Comparison
JBK Performance is offline   Reply With Quote
Old 02-28-2008, 04:39 PM   #2
JBK Performance
Vendor
Member#: 135346
2003 wrx
Default Autometer
AUTO METER
Auto Meter Ultra-Lite Series (52mm)
This Ultra-Lite gauge is the hottest instrument in motor sports. Aluminum construction greatly reduces weight while its anodized aluminum dial and bright red fluorescent pointer make it easy to read. This Ultra-Lite gauge includes rugged air core meter movement and a full pointer appearance. It has an anodized aluminum face with black digits. All 2" Gauges
Part No.
Memory/Warning Electronic 30psi Vacuum/Boost: 4377
30psi Mechanical Boost Gauge: 4303
0-2000 Degree EGT Kit:4345
0-100psi Fuel Pressure Gauge: 4312
100-250 deg. F short-sweep Electronic Oil Temperature Gauge: 4347
Mechanical Water Temp 120-240 Degrees F: 4332
35psi Mechanical Boost Gauge: 4304
0-1600 Degree EGT Kit: 4344
0-100psi short-sweep Electronic Oil Pressure Gauge: 4327
140-280 degree F full-sweep Oil Temperature Gauge: 4341
0-150psi Mechanical Oil Pressure Gauge: 4323
~May Require
-6' Nylon Tubing w/ Fittings: 3222
-1/8" NPT to 1/8" BSPT Oil Pressure Fitting Adaptor: 2269
Electronic Air Fuel Gauge: 4375
~May Require
-Band O2 Sensor Kit:
2244
Auto Meter Nexus Gauges (52mm)
Digital microprocessor controlled 270 degree sweep rugged stepper motor driven electric gauges offer the highest levels of precision and technology to the discerning enthusiast. Race proven senders keep hazardous fluids inside the engine bay and monitor critical systems safely and with authority. Gauge calibration and sensor diagnostics occur on power up for extreme accuracy. Most Full Sweep Electric gauges are compatible with and capable of connecting to Auto Meter Data Logger units for the ultimate race information center. These gauges offer 7 different illumination colors and the capability to store datalog information to an SD Card.
Part No.
Nexus Sensor Module: 6400
Nexus 52mm Boost Gauge: 6459
Nexus 52mm Fuel Pressure Gauge: 6463
Nexus 52mm Oil Pressure Gauge: 6453
Nexus 52mm Water Temperature Gauge: 6455
Nexus 52mm EGT Gauge: 6459
Old 03-04-2008, 01:09 AM   #3
JBK Performance
Vendor
Member#: 135346
2003 wrx
Wow thanks guys
Old 03-10-2008, 09:57 PM   #4
JBK Performance
Vendor
Member#: 135346
2003 wrx
Bring it up O YEA
Old 03-12-2008, 05:43 PM   #5
Rokudoo
Member Sales Rating: (17)
Member#: 110344
2005 Sti
Is the color of the "red racer" the same as the "BF amber?" I just wanna know how well it matches the stock STi cluster.
Rokudoo is offline   Reply With Quote
Old 03-16-2008, 07:25 PM   #6
JBK Performance
Vendor
Member#: 135346
2003 wrx
From what we can tell it matches but we wont be able to prove it untill the reach the country they should arrive this week.
Old 03-17-2008, 12:11 AM   #7
Rokudoo
Member#: 110344
2005 Sti
k, subscribed. Pics will be great!
Old 03-19-2008, 02:11 PM   #8
JBK Performance
Vendor
Member#: 135346
2003 wrx
There about to come in to the country as soon as there in hand we will show real pictures , not just the stock photos
Old 03-19-2008, 07:16 PM   #9
Big-Sexy907
Member Sales Rating: (25)
Member#: 59057
2004 Impreza, STi.
PM A price shipped for the following 60mm Electric Imperial Gauges to 99520 in Amber to match my 04 Sti.
Boost
EGT
Oil Press
I also need a center Gauge pod.
Thanks!
Big-Sexy907 is offline   Reply With Quote
Old 03-20-2008, 01:21 PM   #10
JBK Performance
Vendor
Member#: 135346
2003 wrx
All Sent
Old 03-26-2008, 04:59 PM   #11
AlxSti
Member Sales Rating: (19)
Member#: 94615
|'06 STi 341/356|
www.AffinitiBrokerage.com
whats the deal with the red racers matchin the sti cluster?? ive seen some people on here have em installed already.. you guys get em in yet?? do they sweep?
AlxSti is offline   Reply With Quote
Old 03-26-2008, 06:52 PM   #12
Rokudoo
Member#: 110344
2005 Sti
^ yeah that.
Old 03-26-2008, 08:57 PM   #13
JBK Performance
Vendor
Member#: 135346
2003 wrx
I have them, Let me see if I can get a actual picture to compare. http://www.integrated--performance.c...453&child=6816
Old 03-31-2008, 11:06 AM   #14
JBK Performance
Vendor
Member#: 135346
2003 wrx
Thanks for the sales
Old 04-06-2008, 05:48 PM   #15
JBK Performance
Vendor
Member#: 135346
2003 wrx
Default Vs
Edit edit
Old 04-12-2008, 06:07 PM   #16
JBK Performance
Vendor
Member#: 135346
2003 wrx
New Shipment Arrived
Old 04-13-2008, 05:36 PM   #17
CSCSATCWRX
Member Sales Rating: (1)
Member#: 140032
06 vf43 wrx R.I.P.
09 forester 2.5x
could you PM me the price for the defi blue racer boost gauge sent to 15501?
thanks
CSCSATCWRX is offline   Reply With Quote
Old 04-13-2008, 07:47 PM   #18
JBK Performance
Vendor
Member#: 135346
2003 wrx
Thanks for the order
Old 04-17-2008, 06:15 PM   #19
JBK Performance
Vendor
Member#: 135346
2003 wrx
Bring it UP, over STOCKED RED|WHITE RACER PRESSURE AND EGT GAUGES
Old 04-21-2008, 08:39 PM   #20
JBK Performance
Vendor
Member#: 135346
2003 wrx
Over Stocked On Pressure And Exhaust Temp Still
Old 04-24-2008, 06:09 PM   #21
JBK Performance
Vendor
Member#: 135346
2003 wrx
New Stock arrived
Old 05-01-2008, 10:03 AM   #22
bzbuzz
Member Sales Rating: (18)
Member#: 116052
2011 STI ( Sold )
pm me best price shipped to 60062
defi 52mm white racer boost + oil temp in PSI and F*!
in stock?
bzbuzz is online now   Reply With Quote
Old 05-05-2008, 09:07 PM   #23
JBK Performance
Vendor
Member#: 135346
2003 wrx
All sent
Old 05-06-2008, 01:59 AM   #24
dasnowman
Member Sales Rating: (33)
Member#: 125450
Gone 07 SWP STi LTD
07 Nissan Nismo 4x4
52mm red racer in boost , oil pressure, and EGt shipped to v3c 1k7 vancouver canada in stock ? comes with all sensors etc??
dasnowman is offline   Reply With Quote
Old 05-06-2008, 02:01 PM   #25
JBK Performance
Vendor
Member#: 135346
2003 wrx
All SENT, COMES WITH ALL SENSORS OF COURSE
WeSellCarParts.com // DEFI Combo's & Deals - Also AEM, Autometer & More! WeSellCarParts Gauges & Electronics 34 03-13-2011 09:23 PM
Defi Racer Red Boost ketchupfreak Interior/Dressup/Audio & Security 8 07-25-2009 04:37 AM
Defi Racer Red & White Preorder Deals+Aem,Autometer,Defi JBK Performance Accessories & Misc 65 05-25-2009 08:13 PM
Gauges AEM- AUTOMETER - DEFI -COMBO DEALS JBK Performance Gauges & Electronics 10 02-18-2008 11:41 AM
2003 Mini Cooper S Low Miles Red & White Classic - $16500 Libra Monkee MAIC Private Classifieds 4 10-03-2007 02:18 PM
