Welcome to the North American Subaru Impreza Owners Club Sunday February 14, 2016
Old 02-28-2008, 07:42 PM   #1
nhmtns
Member#: 94283
'05 OBXT Stage 2
Min bil är svart
Angry Augh! What's rattling?
There is something clanging loudly from the rear of my wagon when I drive over bumps, even fairly small ones. I haven't changed anything on my car for over a year, but the noise started a month ago or so. I thought maybe my exhaust was bent a little from hitting a snowbank or something. I was almost positive the noise was the exhaust pipe hitting the Perrin rear sway bar. I had my GF sit in the car and I repeatedly pushed the muffler to the right with my foot so it hit the sway bar. She said that was the sound. So I installed some Kartboy long hangers to keep the exhaust from moving around and hitting anything. THE DAMN NOISE IS STILL THERE when I drive over bumps.
Today I checked the hatch to see if it might somehow be rattling. I noticed that when it's open, there is play in the ball and socket of the hatch struts if I push up. Is this normal? Regardless, when the hatch is closed I don't think it makes any noise.
Another possible cause may be the suspension. I had a strut replaced by warranty a couple months ago because it was leaking oil. My springs are STI Pinks and I think the different compression may be to blame for the strut failure. Is there a chance I'm getting rattling from another bad strut? I haven't noticed any leaking oil.
nhmtns is offline   Reply With Quote
Old 02-28-2008, 09:43 PM   #2
Mavrik
Member#: 90347
2013 BRZ & Imp 2.5RS
Yamaha FZ8
are your back seats completely latched in their upright position? that will cause a rattle/clunk/thud noise when hitting bumps.
Mavrik is offline   Reply With Quote
Old 02-28-2008, 09:57 PM   #3
PropBoyBlu
Member#: 148020
BugI WRX Wagon
Battle-Tested Blu
I had a mean rattle coming from the back of my wagon. I thought my hatch was about to come flying of. Turned out to be a leaf stuck in the roof rack tracks.
Had another mean rattling. Turned out being a can of octane booster and the funny jack-rotator-arm-thingy makin' sweet love.
Now, if only I could find out what that rattle in my gauge cluster is caused by
PropBoyBlu is offline   Reply With Quote
Old 02-28-2008, 10:15 PM   #4
blacktrail
Member#: 154841
2002 white
johnny tran
Lol, subarus and our rattles Im pretty damn sure when I picked mine up from the dealership it was already rattling.
blacktrail is offline   Reply With Quote
Old 02-28-2008, 10:35 PM   #5
winkie711
Member#: 84720
05's WRX STi & LGT
Silver-Black
Rattles...it's what makes a subaru a subaru.
winkie711 is offline   Reply With Quote
Old 02-29-2008, 12:39 AM   #6
nhmtns
Member#: 94283
'05 OBXT Stage 2
Min bil är svart
Yeah, after three Subarus, I'm used to the normal rattles and squeaks. This is worse than that though. It sounds like something is loose, and I think it might be suspension related. I did check my jack and lug wrench in that little storage cubby.
Old 02-29-2008, 01:50 AM   #7
2.5~rs
Member#: 158794
xxxx wrx
blown strut maybe?
2.5~rs is offline   Reply With Quote
Old 02-29-2008, 11:22 AM   #8
bzbuzz
Member#: 116052
2011 STI ( Sold )
check swaybar endlinks if it's torqued down
check topnut of the strut...and those 3 small nuts
bzbuzz is offline   Reply With Quote
Old 02-29-2008, 01:26 PM   #9
nhmtns
Member#: 94283
'05 OBXT Stage 2
Min bil är svart
Ok, I'll check those when I get a chance. It sounds to me like something isn't tightened down properly. What sucks is now I've got an exhaust lowered on Kartboy hangers (it keeps hitting ice chunks on the road) with more vibration coming through the car for no good reason.
Old 02-29-2008, 06:34 PM   #10
kasper52
Member#: 158901
02 BuGeYe I got
more ƒlush than a toilet
I have this tremendous rattle in the front end of my dash, im not sure what is is either!!!
kasper52 is offline   Reply With Quote
Old 03-05-2008, 02:37 PM   #11
pweizman
Member#: 131268
.... GOD........
My wagon does the same thing!!
Especially over uneven pavement, it is very frequent...like rattle, rattle, rattle...!!!
I have checked my strut tower bar 5 times, switched back to factory endlinks and played with the exhaust to no end.
SO, tighten the top bolt on the strut?
Torque down the endlink bolts? How tight are those supposed to be?
I have checked the jack...
I was contemplating taking the spare tire and everything out of the back of my car!
Edit....
Could it be this?
http://forums.nasioc.com/forums/show...t=rattle+clunk
4. wagon spare tire rattle thanks "sjl1614" for solution
solution - Where the spare tire "cover" sits down and rests of the plastic trim, right under there, the trim sits on metal tabs. Which is the souce of the rattle. use some foam tape on the metal tabs and the noise is gone - sjl1614
Patrick
pweizman is offline   Reply With Quote
Old 03-05-2008, 03:11 PM   #12
Doc Holiday
Member#: 171713
2000 Impreza 2.5RS
Silverthorn Metalic
Haha, I had a squeak that I could not figure out for the life of me. Everytime I would have a friend ride along to help find it, the #$&@er wouldn't make a peep. Turned out to be one of the bolts holding the passenger seat in place was loose, but when it had weight on it it wouldn't squeak!
Good luck!
Doc Holiday is offline   Reply With Quote
Old 03-05-2008, 03:46 PM   #13
SubieRon
Member#: 64485
2004 GGA
my solution to rattles...turn the volume up
SubieRon is offline   Reply With Quote
Old 03-10-2008, 07:10 PM   #14
nhmtns
Member#: 94283
'05 OBXT Stage 2
Min bil är svart
Well, figured out what was wrong. It was a faulty bushing in the Perrin endlink causing the sway bar to move around. I put the stock sway bar, endlinks, and mounts back on and now I'm working on getting the endlinks warrantied.
Old 03-10-2008, 07:52 PM   #15
JamesWilson
Member#: 124833
2000 Legacy Wagon
Mystic Mountain Blueberry
I had the Gruppe-S ones in the front, bearing tore right out....no way for a warranty, IMO.
JamesWilson is offline   Reply With Quote
Old 03-11-2008, 09:53 AM   #16
Doc Holiday
Member#: 171713
2000 Impreza 2.5RS
Silverthorn Metalic
Kartboy!
What's that rattle??? OMG Ash Tray MikeCee Newbies & FAQs 6 01-24-2007 07:57 PM
Bad Valve Rattle...What's the Cause? jsavage Normally Aspirated Powertrain 4 08-15-2003 05:26 AM
The rim dilemma. Augh. jblaine Interior & Exterior Modification 6 03-22-2002 02:12 PM
Still have rear brake noise. augh. Darwin Brakes, Steering & Suspension 4 07-09-2001 07:18 PM
Augh it's an invasion! Zypper North West Impreza Club Forum -- NWIC 1 05-28-2001 11:03 PM
