Old 02-28-2008, 09:14 PM   #1
theDaishi
Member#: 116247
Default New WRX owner. Used 2002 wagon. Code P1086
P1086 Tumble generator valve #2 (LH) position sensor circuit low input
I live in Omaha, bought the car in Buffalo, NY... 2 days ago. The CEL came up 30 miles into my trip. Around 500 miles back, it shut off. Came back on this morning.
At first when I got it scanned at Autozone it said Manf control fuel & air metering auxilary emission controls. Thought at first it was MAF, so I put a newer one in anyway and obviously didnt fix it.
Got on here and found it was the tumble generator. I am new to the WRX world, and have heard a little about the butterfly valves and tumble generator whatever, but I'm pretty much lost.
How serious, and possibly fix myself? The car has 100,000 + miles, so the low input makes me think it might be a corroded wire or something?
theDaishi is offline   Reply With Quote
Old 02-28-2008, 09:41 PM   #2
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
iirc 1086 is the sensor rather than the actual valve mechanism. They're fairly easy to break - dealer broke my LH one when replacing the a/c compressor and several people have broken a RH one when doing turbo replacements
if you search the 2.0 Powertrain forum there's some good info
iirc the dealer will try to sell you the complete assembly, but the faulty sensor is the same part as the throttle position sensor (TPS) which is a much cheaper fix
UkNuck is online now   Reply With Quote
New member...new wrx owner Scott02wrx Newbies & FAQs 6 08-10-2008 12:10 AM
WRX owners using an STi TMIC, question about gaskets deblas66 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 06-08-2007 05:24 PM
what FMIC are 2006 wrx owners using need2boost Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 10 12-01-2006 11:57 PM
Any 2003 WRX owners using unichip? WRXVII Engine Management & Tuning 3 08-03-2003 03:24 AM
New WRX owner in new house in new area! JAMES_WRX03 General Community 7 02-24-2003 02:05 PM
