02-29-2008, 12:48 AM | #1 |
Member#: 63249
TXIC
Vehicle:2004 2.5 STI Wagon 05 FXT Black |
Got my compression test, now how to rebuild?
well my Hybrid motor made it about 17k with 300+whp till it started to blow out crazy amounts of oil..
did a compression check, DF-165 PF- 165 DR- 90 PR- 190?(carbon build up maybe?) guessing rings or something to do with the piston(ringland maybe?) so im looking at a set of Wiseco pistons, 100mm bore keeping, my hybrid 9:1 CR.. should those hold up for the 400-475whp i am looking for?? i also came across a set of DPR stg 3 sti cams for a decent price that i have been waiting on dropping in till i needed to pull the motor again.. i know i need springs and retainers to run these cams, will the brian crower set be well enough?? will i be able to my stock valve buckets with these cams? i know mine are shimless already.. i am also looking to upgrade my td05-18g 7cm to a 7cm 50 trim, with the set up from above, im already running an EWG, does this seem like a 400-450whp set up?
02-29-2008, 08:12 AM | #2 |
Member#: 9960
Vehicle:2002 Impreza WRX WRBlue Perl |
what about your transmission?
02-29-2008, 08:41 AM | #3 |
Member#: 63249
TXIC
02-29-2008, 01:11 PM | #4 |
Member#: 64466
Vehicle:05, STI on green |
18g wont be enough to get 400-450. It'll be blowing hot air. Go with a fpgreen or red.
02-29-2008, 06:14 PM | #5 |
Member#: 63249
TXIC
yeah, thats what i was going to do is upgrade my 18g to a 50 trim(green) but keep the 7cm side since i am EWG anyways and i need quicker spool for the auto, not more top end from a 8cm housing
03-02-2008, 01:46 PM | #6 |
Member#: 115420
Vehicle:Its like a STI..... but it doesn't break |
any reason why you think your motor died so soon?
03-02-2008, 10:26 PM | #7 |
Member#: 63249
TXIC
well, my tuner was running a decent amount of timing, with the higher compression, and an 18g pushing 19psi..
i kept the plugs, 3 of them were white, the dead cyc was normal looking.. i will try to get some pics up here soon... so with the compression that low, is it a for sure thing its a piston/ringland? or could it be a valve or something else, the motor idles fine, just massive oil blow by.. |
03-03-2008, 08:16 PM | #8 |
Member#: 98709
NESIC
Vehicle:2005 Impreza WRX 18g EWG + Meth |
If theres that much blow by like you say my guess would be a piston issue. If it just wasn't holding compression I would say check the heads and make sure the valves are seating correctly.
03-03-2008, 11:41 PM | #9 | |
Member#: 63249
TXIC
just wanted to make sure before i go dropping the cash there it dont belong.. so forged pistons here i come... going with 100mm will be better right? so the machine shop can make the block fit the pistons? |
03-04-2008, 05:08 PM | #10 |
Member#: 24890
SCIC
Vehicle:2002 Jackwagon WRB GG |
You might want to find some pistons that will lower the CR back to stock specs. It will be easier to tune and less prone to detonation.
Help! got my 06 cluster out, how to make it red now? | 06wrxkiid | Interior & Exterior Modification | 13 | 10-21-2008 12:31 PM |
did compression test now car wont start! | renda85 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 10 | 09-01-2008 03:40 AM |
Just got my compression test results... | 06_Silver_LGT | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 67 | 03-06-2008 07:54 PM |
Compression test now flodded? | fastwrx05 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 10 | 09-21-2006 09:15 PM |
Some questions on my Compression test : | MINO | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 7 | 08-21-2002 12:55 PM |
