View Poll Results: Do you believe I am doing the right thing in trying to keep this car?
Ye 6 66.67%
Ne 3 33.33%
Multiple Choice Poll. Voters: 9. You may not vote on this poll
Old 02-29-2008, 01:31 AM   #1
Kansei
Member#: 173080
1997 Legacy 2.0 GT
Forest Green Metallic
Legacy 2.2l SOHC legacy L Horrible condition... Need all the help I can get...
Ok. so my problem is my car is running really really bad. I have a inop speedo, a cyl 1 misfire, 4250rpm limit when it warms up, horrible gas milage (2-8mpg), its ticking pretty loudly (could be a knock), and it had 164k before the speedo went out (mind you it went out before I bought the car).
So when I bought the car, the previous owner bought it straight off the lot. Then it broke down, he thought it was too expensive to fix so he left it in a parking lot for 3 years. I bought the car for a total of $200 and it didn't start. Replaced fuel pump and strainer and it ran.
Too bad I didn't have my license yet so I had to wait a month till I could take the test. Passed driving test. Drove it for a little over a month... then washed engine compartment, wouldnt start.... So I replaced the coilpack, plugs, and wires, it runs again but now it has a mis in cyl 1, and it wouldnt even stay running. So I tightened the throttle cable, just enough to make it idle around 500.
I bought the car in october started driving it in november and killed it on christmas... then it got fixed around january 12. I've only had the car for a good 4-5 months and it's my first car so I really want to keep the car and need all the help I can get. And the only CEL's I'm getting are VSS1 no contact and misfire cyl 1.
thank you for any help you may provide.
Kansei is offline   Reply With Quote
Old 02-29-2008, 01:38 AM   #2
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
bbs.legacycentral.org
Old 02-29-2008, 10:56 AM   #3
birukun
Member#: 52801
1999 Legacy Wagon L
Green 30th Anniv.
For 200.00 I say keep it. You aren't going to make money selling it, and the misfire could be a bad sparkplug gap or one not tight enough.(don't go too tight though!) VSS1 error could be water in the connector or it just needs to be reseated.
Any car, even one that runs poorly is worth more to the owner than what anyone will give you for it.
Did you reset the codes after changing things around?
Last edited by birukun; 02-29-2008 at 10:58 AM. Reason: edited to remove already mentioned fixes
birukun is offline   Reply With Quote
Old 02-29-2008, 11:56 AM   #4
99Subprez
Member#: 173173
200 dollars sounds like a keeper to me as well. Just don't let it become a money pit where you will end up spending 3,000 dollars in parts and realize you could have bought a great running car!
99Subprez is offline   Reply With Quote
Old 02-29-2008, 12:10 PM   #5
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
What year is the car?
First thing I'd do is check the timing belt.
Second thing I'd do is a compression test.
Third thing I'd do is a leakdown test.
That should tell you the exact condition of the engine.
Tim Sanderson is offline   Reply With Quote
Old 02-29-2008, 12:18 PM   #6
Kansei
Member#: 173080
1997 Legacy 2.0 GT
Legacy
The car is a 1996 leg l.
thanks for the ideas. and all the plugs have been gapped and they arent fouled so I really dont think its the ignition.
I'm thinking about getting a new fuel pressure regulator set. does that sound like a resonable idea?
I had the codes checked and reset after wards at my school (Francis Tuttle, I'm in the Automotive class). I also changed the oil when I replaced those parts.
Old 02-29-2008, 12:33 PM   #7
Subyroo2.5
Member#: 168129
2013 WRX
WRBP
Your BEST bet is to spend $60 and have the car troubleshooted by a mechanic, instead of throwing parts at the damn thing.
Subyroo2.5 is offline   Reply With Quote
Old 02-29-2008, 04:02 PM   #8
birukun
Member#: 52801
1999 Legacy Wagon L
Green 30th Anniv.
Maybe a Subaru guru from the board could stop by and do a quick look see?
I am in Cali, a bit far.
Old 02-29-2008, 04:02 PM   #9
05RSnazzy
Member#: 173007
2005 2.5RS...AW
05RS-RIP...avenged by AW!
^+1 had the same decision with my old 97 VW VR6
05RSnazzy is offline   Reply With Quote
Old 02-29-2008, 05:12 PM   #10
Kansei
Member#: 173080
1997 Legacy 2.0 GT
Legacy
I go to Francis Tuttle Technology Center here in Oklahoma, and we did a couple of things to it. But to no avail. We also tested it through a SOLUS and a MODUS scanner. I haven't gotten time to do a compression test or leakage test on it yet so that is my next thing to try.
By the way, at FT, all we do is fix cars and my teacher has been working on them for 27 years so I trust he knows what he's doing.
I have also heard that the cam and crank sensors might cause these problems. Anyone know about that
Old 02-29-2008, 09:40 PM   #11
Subyroo2.5
Member#: 168129
2013 WRX
WRBP
Well **** the scantool didnt fix it? Go figure!!
Old 02-29-2008, 10:05 PM   #12
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
check timing belt and components, comp. test, leakdown test. Check mechanicals first then move onto electrical. A misfire can be caused by many things. A bad coil, a burned valve, low cylinder compression, etc.....
If you are considering replacing the fuel pressure regulator than you must have tested your fuel pressure right? What was it?
Somebody tell me what vss1 no contact means.
So far you've told us twice that you are going to automotive school. That's great. Learn how to be a mechanic, not just a parts replacer. If you don't want to follow advice or if your teacher thinks it's bad advice then you should not ask for advice.
Call up a salvage yard and ask how much a motor is for your car. If you think you'll throw at least that much at it then just replace the thing. It's ticking anyway right?
Old 03-01-2008, 02:02 AM   #13
Kansei
Member#: 173080
1997 Legacy 2.0 GT
Well you put it pretty nicely... I'm thinking about replacing the motor but there isn't anywhere I can even find a motor for it. subaru's in salvage yards arent that common here. thats the only reason I'm throwing parts on it. and I don't have access to an ebay account so I cant buy one there.
money to pay my down on my wrx!!!!!!!!!!! trickraca NWIC Private Classifieds 2 07-13-2009 01:34 PM
95 2.2L Legacy to 98 2.5L DOHC EastsideLegacy Subaru Conversions 32 01-29-2009 06:57 PM
WRX clutch on 2.2l Legacy? Chi_San Transmission (AT/MT) & Driveline 8 05-28-2004 05:56 AM
I have tickets to pay at 9am in the morning and no money to pay them... HalfBaked Off-Topic 3 09-09-2003 02:23 AM
2.2l legacy engine and 2.5l RS engine jetfan8178 Service & Maintenance 10 04-02-2002 05:47 AM
