Old 02-29-2008, 05:38 AM   #1
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
PWN3D I know I burned something, instable current when cold
I was doing something few months ago (I think I was installing Defis hooking up power to the stereo 12v)... I don't remember the details but there was some smoke coming out from the area where the deck sitss
"not again!" - thought I, but to my surpsise everything still worked
however few problems appeared:
1. deck resets itself 90% of the times when the car is shut of for more than few minutes
2. my turbo timer beeps (turns off and on) while I am driving (noticed it happens often on turns when I have the turn signal on)
3. when I start the car cold, I am having these issues;
-powersteering if weird (if I turn the wheel left and right, it wobbles as if the pump is broken and all lights in the car dim)
-defis turn on... then off, and do that for several times (happened first time last night, they couldn't get to stabilize untill 5th time )
when the car is warmed, it's all fine... well, lights dim when the rad vents go off, but that's more or less normal
bad battery?... car starts no problems, and voltage readings are fine
Hyper is offline   Reply With Quote
Old 03-03-2008, 10:46 AM   #2
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
bump for some help or clues
I suck @ teh wiring
Old 03-03-2008, 11:43 AM   #3
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
Check the wiring under the dash and look for signs of burned wires, especially where you noticed smoke coming from. Check the ground wires under the dash and clean them to make sure they are not causing some trouble. It sounds like there is a bad ground lead somewhere. You might go over the grounds under the hood also. For the radio memory problem check the memory wire connection to the radio. It may be green in color. Check the grounding to the radio also.
Old 03-03-2008, 11:58 AM   #4
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
what about the "gauges dance" when the car is cold, and trying to die when turning the steering wheel? it does go away when warm.... I thought grounds were indifferent to the temps
Know there is an intake leak, but something else odd when running in SD MConte05 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 05-17-2010 03:16 PM
When Cold Low Oil Light comes on. Anyone know why? nos Service & Maintenance 18 02-07-2005 09:25 AM
I know this sounds stupid... but Louder boxer sound when cold.. SubaruImpreza_power Normally Aspirated Powertrain 43 01-16-2004 11:19 AM
Burning something?, dont know what though.... norseone Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 08-16-2002 09:21 PM
Burns in 5th currently in Corsica Rally! Snoopy General Forum Archive 9 10-01-2000 12:46 AM
