Old 02-29-2008, 12:13 PM   #1
2slofouru
Member#: 90539
Default Which other subaru engines have the same timing belt parts as 97 ej20K?
I remember reading somewhere a while back that the 98 2.5 dohc ej25 had the same timing components including belts tensioners and that the waterpump was the same as the early ej20 turbo engines up to 01. Is this correct? I need to buy a timing belt kit and waterpump and maybe even oil pump if the oil pump is worn and the ej25dohc kits are magically way less than the 02+wrx kits with the same number of components.
Do the 97-98 ej25dohc engines have same timing components and waterpump as 93-2001 ej20dohc turbo???
If not, do I have to get the 02 wrx timing belt kit or will I have to get them from the dealer?
Thanks
I did search (maybe not in the right places) and couldn't find the answer
2slofouru is offline   Reply With Quote
Old 03-02-2008, 07:16 PM   #2
2slofouru
Member#: 90539
Default would ej25d full gasket set work for 97 ej20k?
Would a full gasket set for an ej25d work on the ej20k? I need everything but the headgaskets at least. I plan on getting metal headgaskets, but I want to be able to buy a complete o ring/gasket set for the rest of the engine. I've seen pictures of the set for the ej25d and every gasket looks the same, even for the iac. Anyone know?
Old 03-04-2008, 01:34 AM   #3
2slofouru
Member#: 90539
Bump because I can't be the only one who changes all of the gaskets before swapping a used engine in, lol!
Old 03-10-2008, 09:08 PM   #4
napphappy
Member#: 56170
95 Impreza L
Ugly
Yes The EJ25d uses the same gaskets
napphappy is offline   Reply With Quote
do 2006 wrx seats have the same bolt-in pattern as 02-03? sti.2005.blk Newbies & FAQs 7 05-09-2010 05:53 PM
Does the NA Block Have the Same Oil Gallery Plugs as the Turbo Block? williaty Normally Aspirated Powertrain 14 05-21-2009 01:08 PM
Which Other Cars Have the Same Throttle Plate as an 05 RS williaty Normally Aspirated Powertrain 3 04-16-2009 06:38 PM
What other brand cars have the same wheel specs? chimchimm5 Tire & Wheel 3 09-22-2007 10:10 PM
which other cars out there have the same offset as Subaru's? Mr.Freeze Brakes, Steering & Suspension 7 01-21-2002 06:49 PM
