Old 02-29-2008, 12:58 PM   #1
99Subprez
Member#: 173173
Default New owner with an oil leak
I am exited about my purchase of a my 99 Subaru Impreza AWD L. Granted it is does have an automatic transmission, However it only has 50,000 miles on it. I picked it up for 4K. Not to bad I think. My first question to this post is there is a leak at the front of the engine. I read a lot of posts that say this is the crank seal? I am not sure. It looks like it is dripping from the bottom of the timing cover.
I would like to do a tune up on the car. I would like to get a little more power out of it if I could. From what I read so far, the 2.2 auto combo is not a good candidate for power. Any simple mods I can do right away.
The third and last question I have is it looks like there are 2 air filters. There is a box right behind the engine that looks like an air filter, what is this?
99Subprez is offline   Reply With Quote
Old 02-29-2008, 10:29 PM   #2
99Subprez
Member#: 173173
Any help here? I called several shops and they think that it is the crank seals or the cam seals. I got quoted $750 for doing the seals, timing belt, and water pump. Is this a good deal? I am mechanically inclined and think I could do it myself. what do you guys think? Can it all be done on a Saturday?
Old 02-29-2008, 10:42 PM   #3
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
You sure can do it yourself. It certainly should not take more than a saturday.
2 cam seals
1 front crank seal
1 oil pump seal
1 paint pen
1 torque wrench
1 long breaker bar
1 tube of sealant
1 good sized strap wrench
1 good sized c-clamp or a press
1 comfy cushion to kneel on or knee pads
Just a couple other various common tools and you should be in business.
Tim Sanderson is offline   Reply With Quote
Old 02-29-2008, 11:49 PM   #4
99Subprez
Member#: 173173
Great! Thanks, I think I will try it this weekend. Would you have a source for a good repair manual? Maybe a step by step writeup online? Thanks again!
Old 03-02-2008, 10:18 AM   #5
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
http://techinfo.subaru.com
Jamie
Old 03-02-2008, 08:36 PM   #6
subtoy
Member#: 173384
If your Impreza is a 99 it would have a 2.5 engine not 2.2.
The oil leak may be the crank seal or wrist pin plug.
If you can get the crank pulley bolt out,it is an easy job.
subtoy is offline   Reply With Quote
Old 03-03-2008, 02:21 PM   #7
99Subprez
Member#: 173173
I was told it is a 2.2 liter. I even looked under the hood and the emissions sticker says 2.2. Do you have to remove the timing cover to get to the rank seal?
Old 03-03-2008, 08:20 PM   #8
subtoy
Member#: 173384
Sorr,I thought it was a RS
Yes you do have to remove timing covers.
If you can get the crank pulley off,it is a easy job.
Old 03-04-2008, 06:17 PM   #9
99Subprez
Member#: 173173
I wish it where an RS.
Old 03-05-2008, 08:13 PM   #10
gauntlet
Member#: 168614
Figured I'd pipe in, I have MY02 TS w/ 279K on it. There is a little oil leak under the engine and also I sometimes see a few drops of coolant. I don't have any white smoke coming out of the exhaust. Can you guys direct me to the areas I should be replacing?
gauntlet is offline   Reply With Quote
Old 03-06-2008, 04:39 AM   #11
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
My goodness! 279K miles?! On an 02? Wow!
Check where the heads meet the block. Your looking for green stains or wetness. That would be a headgasket external leak. Does the 02 ts have the plastic or metal t-stat housing? The plastic ones can warp on the mating face. Where Does the oil show up from your leak?
Old 03-08-2008, 01:12 PM   #12
gauntlet
Member#: 168614
here is a link with some pictures.. sorry it's a camera phone
http://s21.photobucket.com/albums/b275/thecatjinx/oil/
let me know what you guys think
went for an oil change and left with an exhaust leak? SpeedShift Normally Aspirated Powertrain 14 11-18-2009 01:21 AM
need help with an oil leak... sniper1rfa Normally Aspirated Powertrain 23 07-07-2009 03:27 PM
Driving With an Oil Leak /Answered please close bulgarianfreak55 Newbies & FAQs 5 11-12-2007 11:18 PM
Anyone With an Oil Leak At Turbo? DesertWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 12-07-2005 07:28 PM
I need an STi owner, with an aftermarket downpipe, with a CEL for cat inefficiency North Ursalia New England Impreza Club Forum -- NESIC 2 10-27-2003 03:23 PM
