Old 02-29-2008, 01:24 PM   #1
ccc_is_for_me
Member#: 171561
2002 WRX wagon
blue
Default Where is my oil going? 02 wrx
I lose about a quart every 2,000 miles and there are no visible leaks anywhere . I even tried to use the stuff that glows under a blacklight. So I assume it is burning it off somewhere. Has anyone had a similar issue or any tips on where to start off searching on my car or what might be causing the loss? I know it is small now, but I am concerned it will only get worse.
ccc_is_for_me is offline   Reply With Quote
Old 02-29-2008, 01:59 PM   #2
bdpAKAknox
Member#: 121248
Have you tried switching oil manufacturers?
bdpAKAknox is offline   Reply With Quote
Old 02-29-2008, 02:03 PM   #3
bluesubie
Member#: 767
04 FXT
Or a thicker viscosity? Your consumption is normal.
-Dennis
bluesubie is online now   Reply With Quote
Old 02-29-2008, 02:38 PM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Subaru considers up to 1 quart/1000 miles to be normal, so your engine is within spec. Some of them will use more, some less depending on a lot of things- oil brand/viscosity, type of driving, how it was broken in, etc.
Old 02-29-2008, 03:16 PM   #5
ccc_is_for_me
Member#: 171561
2002 WRX wagon
blue
awesome, thanks. I put some of the lucas additive stuff in and it seemed to slow it a bit and it still runs super smooth. I am running the suggested 5w-30 btw, royal purple. does anyone know why the engines naturally consume so much oil? where does it go? I am mostly concerned about emissions coming up in Phoenix, AZ.
Old 02-29-2008, 05:01 PM   #6
bluesubie
Member#: 767
04 FXT
You probably want something thicker than RP 5W30 in AZ. There are many threads here about it. Do a search in this forum on Royal Purple or consumption. In an 02 WRX, I would try a high mileage oil or 5W40. Don't use Lucas additive either.
-Dennis
Old 03-04-2008, 07:41 PM   #7
only1agam
Member#: 56183
^what he said, don't use royal purple, nor the additives!
only1agam is offline   Reply With Quote
Old 03-04-2008, 08:47 PM   #8
AllWheelsDriven
Member#: 1737
2005 BMW zhp
www.vispoint.com
yeah try 0w30 or 5w40...thicker
AllWheelsDriven is offline   Reply With Quote
Old 03-04-2008, 09:33 PM   #9
dru_hill
Member#: 67661
2004 WRX sedan
I use like 1qt every 3k-3.5k and I use 10w-40. Its been like that since like 40k miles, I have 93k now. I think you are fine, but dont feel bad going to 10w-40, especially in AZ.
dru_hill is offline   Reply With Quote
Where is my oil going? akeric Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 03-31-2010 09:07 PM
in a panic...where the eff is my oil going?? bugeyerex02 Newbies & FAQs 22 02-25-2009 12:51 PM
OK, where the heck is my oil going? Sperm Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 83 03-03-2007 12:27 AM
where is my oil going cummins Service & Maintenance 18 05-20-2005 01:21 PM
Oh where oh where did my oil go? Rubasu Normally Aspirated Powertrain 15 04-25-2002 07:23 PM
