Old 02-29-2008, 02:06 PM   #1
dougkmcse
Member#: 85938
2004 WRX
Default Mobil 0w30
Any one checked it out? I just saw it at walmart. Is it as good as Castrol 0w30. That is what i use now with no oil loss between oil changes after 55k.
Thanks
dougkmcse is offline   Reply With Quote
Old 02-29-2008, 04:50 PM   #2
bluesubie
Member#: 767
04 FXT
UOA FTW!
Mobil1 0W30 is geared more towards fuel economy. It's thinner than GC at operating temp, has a lower High Temp High Shear and meets Energy Conserving requirements.
A big difference is GC gets the ACEA A3 spec.
Syntec PDS .
M1 0W30 PDS .
Castrol SYNTEC 0W–30 European Formula is engineered to meet the Mercedes Benz 229.5 specification. The 0W–30 viscosity grade is ideal for winter conditions where low temperature pumpability is required. A unique, low–temperature formulation provides exceptional pumpability in cold weather and allows for unaided engine starts down to –40ºF. Exceeds all car and light truck manufacturer's warranty requirements for the protection of gasoline, diesel and turbocharged engines where API SL, SJ, SH, CF or CD is recommended. Exceeds European ACEA: A3, B3, B4; VW 502 00, 505 00, 503 01; MB 229.1, 229.3, 229.5; BMW LL–01; GM–LLA–025, GM–LL–B–025 and the engine protection requirements of ILSAC GF–3 for API Certified Gasoline Engine Oils.
Mobil 1 0W-30 meets key builder specifications:
GM 6094M, GM 4718M (Corvette spec)
Ford WSS-M2C929-A
ILSAC GF-4
API SM/CF
ACEA A1/B1
Mobil 1 0W-30 is an advance performance synthetic engine oil designed to provide cleaning power, wear protection and enhanced fuel economy performance. Mobil 1 0W-30 offers an enhanced fuel economy formula and exceeds the requirements of the latest industry standards required by newer modern gasoline and diesel powered automobile engines.
-Dennis
bluesubie is online now   Reply With Quote
Old 02-29-2008, 07:29 PM   #3
mikeythejew
Member#: 141672
07' wrx
Uncle Scotty 5W30
Mobil1 0W40 has pretty much the same European auto maker approvals as Castrol 0W30. The low HTHS of Mobil1 0W30 scares most Euro makes from recommending and meeting approval.
mikeythejew is offline   Reply With Quote
Old 02-29-2008, 07:44 PM   #4
dougkmcse
Member#: 85938
2004 WRX
I think i will stick with the castrol
Thanks for the info....
Old 03-02-2008, 08:40 AM   #5
deadend9009
Member#: 173016
I think theres a big hipe around Mobil1. I would use whatever is cheapest. I've had great success with Castrol in reducing oil consumption and easy start up, but that was with my Volkswagen.
deadend9009 is offline   Reply With Quote
Old 03-02-2008, 09:28 AM   #6
rkramer
Member#: 118209
2002 WRX Sedan
cheapest... that is pretty much the reason so many people run mobil1. next to the walmart synthetic, mobil1 is the cheapest name brand full synth oil.
Old 03-02-2008, 09:45 AM   #7
RyanE
Member#: 118354
2005 Legacy GT LTD
Regal Blue Pearl
The Rotella-T 5w-40 full synthetic is cheaper than Mobil1 and has been working well in my Legacy for the past couple of oil changes. The only "problem" is that it only comes in 4 quart jugs, and I need almost 5 quarts for an oil change.
I like it because the motor makes less noise when hot than with the Mobil1 5w-30 I was using before. Other people's UOAs say it's good.
-Ryan
RyanE is offline   Reply With Quote
Old 03-02-2008, 01:43 PM   #8
rkramer
Member#: 118209
2002 WRX Sedan
-Ryan
I wouldn't count rotella since that is marketed as a diesel engine oil. Farm equipment with a gas engine is their only gas engine application.
http://www.shell.com/home/Framework?...llasingle.html
Old 03-02-2008, 03:37 PM   #9
JamesWilson
Member#: 124833
2000 Legacy Wagon
Mystic Mountain Blueberry
Nice post, bluesubie, good info. I bought a bunch of it to run in my dad's Sienna minivan as he is always running around all over the county, and logs his mileage. He has been using regular Mobil DC 5w-30 with short OCI's as it is one of the listed Sludge Monsters. Got it specifically for the 2% mileage claim, and it is the same cost as the other weights of M1 at ChinaMart.
In speaking with the M1 engineers and tech geeks at SEMA last year, they said it would likely replace their other weights (doubtful), and they were Nerding it up talking about it. The Marketing guys barely knew what it was, but the engineers and chemists that were there were happy to discuss....that was October 2007, now it's out ~6 months later. We'll see. If it's okay, then we'll run it in the wife's Accord V6, if nothing else for the *potential* for increased mileage.
cst @ 100-deg C = 11.0 , not "too thin" by anyone's book, but I will likely stick to my 40-wt oils in the Subaru. Kind of low TBN at 8.5, and low-ish HTHS number compared to even other weights of M1. Minimum 800ppm of Phosphorous. Wonder what the fuss is about, without seeing a VOA?
JamesWilson is offline   Reply With Quote
Old 03-02-2008, 05:08 PM   #10
prometheum
Member#: 92003
04 TDI Passat
the guys at bitog seem to like it a lot, anyway its designed for diesel applications but still suitable for gas engines
prometheum is offline   Reply With Quote
Old 03-02-2008, 05:12 PM   #11
jacobsipin
Member#: 153217
BLUE
Sup guys im doing an oil change right now at mt house. I have a question.
I been putting regular oil on my car since then. Is it bad or gonna hurt my car if I started using synthetic oil on it. car has about 94k on it.
jacobsipin is offline   Reply With Quote
Old 03-02-2008, 05:35 PM   #12
bluesubie
Member#: 767
04 FXT
Answered your question in the thread that you started.
-Dennis
Old 03-03-2008, 11:19 AM   #13
RyanE
Member#: 118354
2005 Legacy GT LTD
Regal Blue Pearl
Yup - it can clog your cats if you burn oil, but the only oil I've ever used is when an oil filter seal started weeping because it was defective. Other than that, all good.
-Ryan
Old 03-03-2008, 11:37 AM   #14
bzbuzz
Member#: 116052
2011 STI
-Ryan
+1...
yep it's been working really good on my car as well..
UOA was good too...
bzbuzz is offline   Reply With Quote
Mobile 1 0w30 Racing Oil generalee69 Service & Maintenance 25 03-06-2009 10:07 AM
Mobil 1 0W30 Syn in FLA MF-DIF Service & Maintenance 6 05-28-2005 11:34 AM
0w30 oil question sleek Off-Topic 37 11-05-2004 07:07 PM
any advantages to 0W30 Bu2WaRRioR Bay Area Impreza Club Forum -- BAIC 2 11-20-2003 10:22 PM
Anything I should be concerned about regardin Mobil1 0w30? Snoopy Technical Forum Archive 14 10-10-2000 08:10 PM
Message Board Statistics All times are GMT -4. The time now is 07:53 AM.
