Old 02-29-2008, 08:54 PM   #1
andrewp724
Member#: 73361
'03 PSM Wagon
V9 EJ207/6MT, Dom 3.0XT-R
Default Questions about JDM compatibility
Hey guys, I have just a few questions about my application. First, I have a JDM Ver.8 STi motor, and my ECU is marked(hand written on the back) as an '05 8.5 WRX STi. Where can a find the code that would tell me if it is compatible with an opensource program? Second, do any of the opensource programs support a map selector function such as the UTEC map selector switch? I'm having a problem finding a tuning platform that is compatible with my jdm ecu, controls avcs, and has the ability to switch maps on the fly. If I have to switch maps with a laptop that's not a huge deal, it would just be nice to be able to do it without the computer. AP doesn't work on my ecu, UTEC delta doesn't control avcs, and ecutek easyecu doesn't work with the ecu either. I don't want to go to a Hydra, so it's looking as if the opensource is my best option. Any input is appreciated. If it helps, I'll be running a Blouch Dom3 with a GM boost solenoid, modded USDM WRX injectors, and a perrin big maf intake. Thanks,
-Drew
andrewp724 is offline   Reply With Quote
Old 02-29-2008, 10:20 PM   #2
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
well i wold connect ecutek about ecu.
also enginuity, openecu..
Old 03-03-2008, 07:14 PM   #3
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
i've been using enginuity on my v7 and utec on top. Utec rev 6b allows for the avcs pass through. i havnt used my utec in a while due to the ecu map being soo close, but i plan to use it again once i can verify speed density can be used with this older revision for the race fuel occaisions.
fastnoypi is offline   Reply With Quote
Old 03-03-2008, 07:29 PM   #4
andrewp724
Member#: 73361
'03 PSM Wagon
Thanks for the replies, I have found out from Scott Siegel that the ecutek easyecu does work on the jdm ecu's. So, aside from the price, problem solved.
-Drew
question about wheel compatibility mcthaniel06 Newbies & FAQs 5 03-03-2010 11:24 PM
weird question about backward compatibility bigstick009 Newbies & FAQs 15 03-16-2008 10:17 PM
Question about JDM STi Uppipe megabass Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 04-06-2003 09:58 PM
question about jdm speedometer cluster and mileage Poe Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 02-01-2003 02:52 PM
Dumb question about strut compatibility... Velocity Legacy Forum 10 09-15-2000 09:26 AM
