Tri-State Area Club
Go Back   NASIOC > NASIOC Regional Areas > Tri-State Area Forum > Tri-State Area Private Classifieds
Old 03-01-2008, 12:11 AM   #1
Rick G
Member Sales Rating: (1)
Member#: 3122
2016 Crosstrek
Hyper Blue
Default Gauging Interest 06 STI 6sp and motor
Hey guys,
Gauging interest on 2006 STI motor and 6spd. with 30k miles, available in about 3-4 weeks with 100% refundable deposit if if not avl. in 4-5 weeks.
(call me with details 631-803-0612)
Motor with Harness $4500, $4k w/out
6spd $5000 w/rear end & axles (no diff.) $5500 w/diff.
(most likely avl. w/out harness and rear diff. for $4K and $5k)
Let me know, legit items from used(dealer sold)STI.
(friend of a friend's items)
LMK, Thanks.
Rick G is offline   Reply With Quote
Old 03-01-2008, 01:04 AM   #2
eclip5e
Member Sales Rating: (36)
Member#: 14686
2002 RASpec Impreza
Dent Sport/visual assault
I'd buy the tranny (i don't need rear diff) and drive down to pick it up.
Driveshaft and knuckles too?
eclip5e is offline   Reply With Quote
Old 03-01-2008, 08:29 AM   #3
Rick G
Member#: 3122
2016 Crosstrek
Hyper Blue
Yes, all for $5k w/out diff. Thanks.
Old 03-01-2008, 09:07 AM   #4
IIdiceII
Member Sales Rating: (88)
Member#: 90438
5500 for a 6spd swap? thats redic.
IIdiceII is offline   Reply With Quote
Old 03-01-2008, 12:02 PM   #5
AugustusMaximus
Member Sales Rating: (31)
Member#: 63060
0005 RS, 92X
silver, red
^^ 10,000 for drivetrain ^^
AugustusMaximus is offline   Reply With Quote
Old 03-01-2008, 05:07 PM   #6
Chandy69
Member Sales Rating: (179)
Member#: 16087
02 WRX
Back seat with your mom
I'm Very interested in the 06 Sti Motor.
I'll be calling you later today.
Chuck III
Chandy69 is offline   Reply With Quote
Old 03-01-2008, 09:26 PM   #7
TROLL
Top Scoob 006
Member Sales Rating: (60)
Member#: 14424
BugI w/ 07 STi Swap
www.TriStateTuners.com
$5,500 (or even a bit more more if it includes brembos) is a great price for a complete drivetrain... if its 100% complete.
trans, shift linkage, shift knob, tranny mount, driveshaft, front and rear axles, front and rear hubs, front and rear brembos, rear diff...
dont know if thats all included but thought i'd help outline whats necessary for a swap.
anyone doing the whole thing will also need to get suspension made for 05+ STi and wheels made for 05+ STi.
TROLL is offline   Reply With Quote
Old 03-02-2008, 03:06 PM   #8
Vlad
Member Sales Rating: (40)
Member#: 46135
02 WRXstiV9 Spec C
C63 AMG
Wrinkleboi, you have an '02 with an '07 swap, right?
All that is needed are transmission, clutch fork, driveshaft and front axles (as an easy means to change from female to male, without having to crack open the transmission, to reuse the '02 front axles), no?
With the '06/'07 you can reuse the clutch assembly, no?
Then, later you can decide what to do with the DCCD.
Old 03-02-2008, 04:27 PM   #9
Dubya R Ex
Member Sales Rating: (10)
Member#: 119223
2006 WRX
yea but for that much u can get a fully built ppg setup which is a whole lot stronger...i mean the sti 6spd is good..but it sure isnt that good.
Dubya R Ex is offline   Reply With Quote
Old 03-02-2008, 10:50 PM   #10
TROLL
Top Scoob 006
Member#: 14424
BugI w/ 07 STi Swap
yes, i've gone through many variations of this so i'll try to explain clearly below... hopefully the info is useful and not going off topic in a bad way...
the following are absolutely necessary unless noted...
-transmission
-6mt clutch, flywheel, pilot and tob bearings (or you can use 5mt stuff but it wont be nearly as strong, i recommend the 6mt stuff while you're in there)
-6mt clutch fork (must use no matter what)
-6mt tranny mount
-6mt driveshaft (must notch the rear flange slightly to mate to WRX R160)
-shift linkage, shift knob, shift boot (or you can mod your stock one to fit)
-proper front axle fitment (*options explained below)
options on axle fitment:
-you need female axles. if you have an 02-early 04 WRX then you already have them and you're good. if you dont then you need to get female axles... either 02-early 04 WRX or early 04 STi will work fine. doublecheck to make sure your axles are definitely female!
-if you're swapping in an 04 STi tranny which comes with axle stubs, it will fit fine with female axles discussed above.
-if you're swapping in an 05+ STi tranny then you have to purchase early 04 sti axle stubs, circlips, axle seals and then it will fit fine with female axles discussed above.
rear diff compatibility
-if you are swapping in an 04-05 STi transmission, you must convert your rear diff to a 3.9 ring and pinion, commonly found in older subarus for about $150 or so.
-if you are swapping in an 06+ STi transmission, it is already set up properly for a 3.54 rear diff, which requires no modification to the stock rear WRX diff.
i dont know why i'm even responding to this...
have you owned either? do you have a flying clue what you're talking about?
PPGs are amazing... they're incredibly strong, lighter weight than an STi gearbox, and totally badass. however they are NOT cheaper, and the only distinct advantage to them is for drag racing applications, IMNSHO. the lighter weight of it and the better gearing and one less shift are definitely advantageous on a drag strip for sure, but for general use i dont see the overwhelming benefits.
you're going to spend $4000 on the gearset alone, plus $500 for bearings and synchros, plus $300 for a busted case so you can use the case, 5th and reverse, output shaft, etc. you're going to spend ~$700 on labor for assembly, bringing the total to: $5500... and this will leave you with that shoddy open front differential that the WRX comes with. its OK for drag racing, its not OK for road racing, autoxing, etc. if you want to upgrade that plan on another $800 at least. this still leaves you with an inferior center diff but it gets the job done.
at this point you still have the weak link of the stock output shaft which can be upgraded to a PPG piece for about $1000 if you want.
ahh, now you have a tranny that is clearly stronger than the STi, for double the price. but wait, isnt the STi tranny able to hold 500+ whp all day long? a number that very few Subaru owners ever see...
ok, pretty sure i've overdone it now, but hey, you got me started...
what i'm trying to say is... good luck with the sale
anyone with more questions about making this work in their car, particularly with hubs, brembos, rear diff, etc... my PM box is open and i'll help out with info if i can.
Old 03-02-2008, 11:50 PM   #11
rice h8r
Member Sales Rating: (19)
Member#: 94524
hm I always thought it was 07 trannys that were set up for a R160. Is there another way to use a 05+ tranny besides getting all those parts?
uh oh.
rice h8r is offline   Reply With Quote
Old 03-02-2008, 11:52 PM   #12
TROLL
Top Scoob 006
Member#: 14424
BugI w/ 07 STi Swap
hmm? above i stated that if you do an 06+ STi transmission, it is set up for a 3.54 rear diff (like the WRX's R160 and of course the 06+ STi's R180)... so no modification would be required.
dont want to turn this into a tech thread any more than i already have, so any other questions just PM me or start a thread in the drivetrain forum...
gauging interest 06 sti for sale David Glasscock Private Vehicle 'For Sale' Classifieds 5 06-24-2009 02:40 AM
gauging interest 06 sti winter wheels veightkiller VIC Private Classifieds 5 12-14-2006 09:06 PM
**Gauging interest** 06 STI BBS wheels jdmmuscle SCIC Private Classifieds 0 06-20-2006 08:57 PM
Gauging interest. 06 STi wheels with tires jetfan8178 Private 'For Sale' Classifieds 13 03-16-2006 04:14 PM
gauging interest GC8 STI grill and headlights 2K4 STI Private 'For Sale' Classifieds 4 06-15-2004 01:39 PM
