Old 02-11-2002, 08:52 AM   #1
PaulN
Member#: 566
1994 Legacy GTB
Green
Smile Auto to Manual conversion successful!
Hi
As I posted a couple of weeks ago, I have just attempted to convert my automatic Legacy GTB to a manual conversion - It worked.
I did all the work myself and it cost 950 ($1400). The transfer box on my GTB was binding so it was like driving with the centre diff locked solid
Now after a week of skinned knuckles and lying in puddles (I can't fit the car in the garage and its rained a lot in the UK this week)
Problems:
One of the torque converter bolts was rounded off and so after removing the autobox I had to attack the TC from behind with an angle grinder!!
Are the downpipes different on the manual - The downpipes and particularly the brackets are hard up against the gearbox mounting - makes a nasty vibration inside the car at low speed. (should be cured by the new scoobysport downpipe next week!
Speedometer - the auto has 2 speed sensors with 2 pin connectors, the manual has 1 3 pin connector - anyone have a wiring diagram for this bit?
Is the footrest smaller on the manual - doesn't seem much room between the footrest and clutch
PLUSES!!
The car is much faster - although the VOD is more noticable - no doubt I will get used to driving around it, but the car just takes off over 5000rpm - I also put a Scoobysport centre pipe and rear box on the car - nice noise, but not intrusive at speed - new downpipe for secondary turbo next week.
I made my own speed shift - reduced overall height by 25mm (Might take it down a bit more) but increase the height of the linkage connection by 20mm (almost double) - nice short shift, abit notchy but I'll get used to it!
Higher gearing in top, up from 22mph/1000rpm to 25mph/1000rpm
Handling much better - car is more stable (possibly due to driving with what amounted to a solid centre diff with the auto).
Parts Changed
UK Impreza Turbo gearbox and rear diff (3.9)
GTB propshaft, 3" longer than auto propshaft
Clutch pedal assembly and master cylinder (+loads of piping???) from GTB
Impreza slave cylinder and clutch
GTB brake pedal
GTB ECU
GTB Starter motor
GTB centre console and gear gaiter/knob
I'll put a full acount with pictures on my website when I get home next week
www.nebbs.com
PaulN is offline   Reply With Quote
Old 02-11-2002, 09:36 AM   #2
DLC
out back
Member#: 1964
05 OB XT LTD
Silver/Gray
I'm doing this next weekend in my "GTB" also known as a Touring Wagon in the US.
I've basically got all the parts you're using, save for the stock ECU, which does a fine job. The TCU will just be disconnected and removed.
I've had the parts for a week, i'm just waiting for shop time, it's agony!!!
Dave
Legacy Central
Team ARG
BC-BF LegacyWorks
DLC is offline   Reply With Quote
Old 02-11-2002, 10:08 AM   #3
PaulN
Member#: 566
1994 Legacy GTB
Green
Good Luck (its a fun job!)
The reason I changed the ECU is that the manual has a 7500rpm redline (up from 7000rpm), with different ignition timing and idle speed to the autos.
It also gives slightly more boost than the auto version, I'm now running 1.1bar
Paul
Old 02-11-2002, 11:11 AM   #4
DLC
out back
Member#: 1964
05 OB XT LTD
Silver/Gray
Well, our EJ22T is just SOHC and redlines at 6500 in both versions. I have heard about a timing issue, but i'm probably going to add some kind of timing control later anyway.
I'm already using an AVC-R, my limit is not having and intercooler and this tiny RB52.
I am, however, enlisting the expertise of a Subaru mechanic to do the brunt of the really tricky stuff, while i generally get in the way and take pictures.
Dave
Legacy Central
Team ARG
BC-BF LegacyWorks
Old 04-18-2009, 11:49 AM   #5
bbenson
Member#: 198744
Default Automatic is problemATIC
03 Impreza with a second auto trans with a blown input shaft bearing... manual tranny is the next step!
bbenson is offline   Reply With Quote
Old 04-19-2009, 10:40 AM   #6
DS1
Vendor
Member#: 111780
From what I've seen most guys go with the speedo wiring is to grab a manual ecu and run the wiring straight through the firewall.
I just did this swap in my 00' legacy wagon but I swapped the entire bulk head harness to a manual one.
-Dylan @ DS1
DS1 is offline   Reply With Quote
Old 04-19-2009, 12:08 PM   #7
Smoke
Member#: 172486
95 V4 STi-RA swap
Stage 49.8
Keep these threads coming!
I plan to do this someday myself!!
Smoke is offline   Reply With Quote
auto to manual conversion demonic Transmission (AT/MT) & Driveline 6 06-26-2004 12:11 AM
Is and Auto to Manual Conversion Possible? F=ma Transmission (AT/MT) & Driveline 11 04-25-2002 01:07 AM
new engine or atleast auto to manual conversion funkadellic69 Normally Aspirated Powertrain 2 02-21-2002 08:20 AM
auto to manual conversion with big torque expectations kaneda3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 07-21-2001 01:01 AM
auto to manual conversion kaneda3 Normally Aspirated Powertrain 5 07-20-2001 01:54 AM
