Old 03-01-2008, 02:25 PM   #1
IllNastyImpreza
Member#: 36333
98 2.5RS
tuning student...
Default Negative effects of only short trips of low mileage?
I'm looking at a 2001 Impreza 2.5rs with only 28k miles...
it was only driven like 2 miles or so to school and back... I'm guessing the car didn't reach full operating temperatures verry often.
What would be the illefects of a car driven like this ??
the car had its oil changed every 3k, but other than that not much other maintenance done.
IMO since its so LOW it wouldn't really matter at all...
what do you guys think ?
I really want the car... but don't wana buy a Lemon
IllNastyImpreza is offline   Reply With Quote
Old 03-01-2008, 04:39 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Exclusive short-trip driving dilutes the oil with fuel and other contaminants (water, combustion byproducts) that don't get a chance to burn off. With this type of use it's very important to do oil changes based on time and not just mileage, if it was run on synthetic one or two changes a year might be ok, more often if on conventional oil.
It may still be ok if they did decent maintenance on it. If you're serious about it and it's in good shape otherwise, have a mechanic or Subaru shop check it out. You can get a pretty good idea of the engine health by having a compression test done and maybe also pulling a valve cover to check for sludge.
Old 03-01-2008, 06:03 PM   #3
Arctic Penguin
Member#: 119532
2006 WRX
if the body and interior are in good shape and the price is right
as long as it runs long enough to find a motor to swap is the only real question
Arctic Penguin is offline   Reply With Quote
Old 03-01-2008, 06:15 PM   #4
jetfan2207
Member#: 61950
2008 Outback
big blue wagon
I have heard that short trips are killer for the exhaust pipes since water/condensation collects on the bottom of the pipes and does not get hot burn off as steam. the water eats through the exhaust pipes.
Sounds like you found a keeper! Good luck
Steve
jetfan2207 is offline   Reply With Quote
Old 03-01-2008, 06:46 PM   #5
IllNastyImpreza
Member#: 36333
98 2.5RS
tuning student...
awesome, thanks for the great replies guys...
The car is actualy 1400 miles away, so I would have to pay a mechanic to check it out.
I'm wondering how the hell I would go and do that
Old 03-03-2008, 08:17 PM   #6
overdose
Member#: 46399
0000 Knows nothing,
about nothing.
You couldn't GIVE me a ej251 powered subaru, they should come with flip top heads and extra head gaskets like a snowmobile has a spare belt
drive cycle is the least of concerns, when'd they fix the NA 2.5s... or did they ever?
overdose is offline   Reply With Quote
Old 03-04-2008, 02:44 AM   #7
thejaredhuang
Member#: 86206
2006 WRX Wagon
Definitely needs new spark plugs, they should be all fouled up because they didn't have sufficient time to warm up.
If the car's drivetrain and body are good then go for it. Short trips won't damage the engine unless he redlined it before it warmed up.
thejaredhuang is offline   Reply With Quote
any negative effects of eating a whole bag of jerky? -=C=- Off-Topic 22 12-04-2007 12:36 PM
FS: slew of OE 02 WRX parts, low mileage bovverboy Private 'For Sale' Classifieds 8 05-21-2004 03:47 PM
Negative effects of not using either of the factory heatshields? JF1GD2 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 62 02-20-2004 01:04 PM
any negative effects of intake silencer removalon STI? StealthWagon Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 82 11-01-2003 12:12 PM
possible negative effects of storing a car? Jonathan Kent Technical Forum Archive 8 07-28-2000 12:27 AM
