Welcome to the North American Subaru Impreza Owners Club Friday June 24, 2016
Old 03-01-2008, 04:30 PM   #1
bcblues
Member#: 17256
04 STi
Blue w/ custom bug splat
Default Enginuity and UTEC?
I have a UTEC to do most of my tuning, but I am trying to adjust some parameters with Enginuity. Logging with Enginuity logger shows that boost and some other parameters appear to be clamped by the UTEC, making it useless for analysis. Anybody found a work-around?
bcblues is offline   Reply With Quote
Old 03-05-2008, 11:12 AM   #2
gandolph
Member#: 172784
Team Unamused :/
Great White STI
i don't know much about both the utec and enginuity.. but why are you using both to tune? Is the utec limited at some points.. ?
gandolph is offline   Reply With Quote
Old 03-05-2008, 11:14 AM   #3
nhat
Member#: 140163
03 STi
hellaflunctional
pm tgui. he uses both enginuity and a utec.
Old 03-05-2008, 04:32 PM   #4
Zumble
Member#: 34860
2005 Forester CGM
Post the results here.
Zumble is offline   Reply With Quote
Old 03-06-2008, 07:12 AM   #5
TheMadScientist
Member#: 23717
2005 Big red
Yes the Utec clamps the MAP signal. One of the work a rounds is to jumper the MAP signal around the Utec so the signal goes directly to the ECU. Just remember that after you do that you need to make sure the boost fuel cut limit in the ECU is raised.
TheMadScientist is offline   Reply With Quote
Old 03-06-2008, 01:48 PM   #6
bcblues
Member#: 17256
04 STi
I like the ability to switch maps via the map selector with the UTEC, and I like being able to log with UTI.
Old 03-06-2008, 03:12 PM   #7
gaby
Member#: 94097
2004 WRX Hybrid GT35
[email protected]
subcribed
gaby is offline   Reply With Quote
Old 03-06-2008, 10:14 PM   #8
Tgui
Member#: 44771
Its just as TMS describes. "T" off the map signal wire going into the UTEC, and direct to the ECU.
I suppose with enough data you might find a conversion. I can't remember from my logs if the UTEC map value hard lines at some limit, or just approaches it logarithmically. Then no need to cut and splice.
Tgui is offline   Reply With Quote
Old 03-07-2008, 08:23 AM   #9
bcblues
Member#: 17256
04 STi
Thanks! Once it gets above zero degrees (F) I will give it a try!
Old 03-07-2008, 11:43 AM   #10
gaby
Member#: 94097
[email protected]
Can anyone draw a diagram of the conections?
Enginuity and utec subieracer18 Open Source Reflashes 1 06-11-2008 03:13 PM
Dougies Friend With Enginuity and Tactrix...(Haltom) haloseven Texas Impreza Club Forum -- TXIC 7 02-08-2008 10:15 AM
Enginuity and LC1 Logging akira02rex Open Source Reflashes 4 01-17-2008 05:03 PM
Enginuity and the LM-1 rebizap Commercial ECU Reflashes 2 11-19-2007 02:42 AM
Logging '07 STI with Enginuity and a VAGCOM cable l0pl0p Commercial ECU Reflashes 15 09-11-2007 07:03 PM
