Old 03-01-2008, 07:06 PM   #1
Lachlan
Member#: 19470
1981 Brat GL
Default About to put my short block back together...
any tips besides RTFM?
Lachlan is offline   Reply With Quote
Old 03-02-2008, 08:30 PM   #2
upjeeper
Member#: 150205
Sedona Red
got fujibond?
upjeeper is offline   Reply With Quote
Old 03-03-2008, 06:57 PM   #3
Lachlan
Member#: 19470
1981 Brat GL
anything special about putting rings on the pistons?
Other than not to line up the gaps?
Old 03-03-2008, 07:42 PM   #4
St.race
Member#: 136092
yes rings are have to be placed in certain order. take in concideration that it's flat 4 engine vs inline or v-shape.
if you do not know how to do that don't you think you should let some one else do it? Or you just do it for fun of it.
St.race is offline   Reply With Quote
Old 03-05-2008, 07:14 PM   #5
Lachlan
Member#: 19470
1981 Brat GL
Alright, when putting the rods onto the crankshaft, how tight should I tighten the nuts? The manual doesn't give any values. Also, how tight should the rods feel on the shaft? Should they move freely or should they stick a little?
Old 03-05-2008, 08:47 PM   #6
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
Which manuel are you using? Mine has the numbers, but I am not near it. the rods should feel "sticky" because of the assembly lube you DID put on the bearings.
Old 03-05-2008, 08:52 PM   #7
Lachlan
Member#: 19470
1981 Brat GL
I'm using an electronic version for the 2002 WRX in PDF form. The tear-down/build up in the block section doesn't cover separating the rods from the crank. As far as assembly lube goes, the manual just mentions using engine oil--should I be using something different? The local machine shop recommended a 50-weight oil; I'm using a 15W50, about the heaviest I can find.
edit: doh--I found the page--it's in a different section.
Old 03-05-2008, 10:39 PM   #8
Lachlan
Member#: 19470
1981 Brat GL
Does the rear oil seal (goes on the crank from the bell housing end) go in with the groove facing in or out?
Old 03-05-2008, 10:57 PM   #9
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
groove in (so you cant see it)
Old 03-05-2008, 10:59 PM   #10
Lachlan
Member#: 19470
1981 Brat GL
Thanks!
Old 03-06-2008, 12:21 PM   #11
Jpizzzle
Member#: 95492
2003 WRX with STI
goodies >:)
make sure you put those 3(?) O-rings in the middle of the block...made me mad when i found out i forgot them
Good luck
Jpizzzle is offline   Reply With Quote
Old 03-06-2008, 05:20 PM   #12
Lachlan
Member#: 19470
1981 Brat GL
yeah there are four, and I made sure they were in. How did you find out they were missing?
Old 03-09-2008, 01:40 PM   #13
555ideways
Member#: 36652
This is what you need for assembly lube for bearing surfaces. http://store.summitracing.com/partde...5&autoview=sku
It's a tackier than straight motor oil. It's rare that a motor gets built, installed , and fired up immediately. Assembly lube stays does the job better. Don't forget you have to prime the oil pump with a good few cranks and the bearings run dry quick.
Motor oil is good for lubricating the rod bolts, head bolts, and case bolts. The specs are in the manual along with the order they should be torqued. When using ARP fasteners use their special assembly lube on the bolts and torque to their specs (or your machine shop's specs).
I big jug of degreaser, a pack of 100 powder free latex gloves, a bottle of heavy weight oil,, lint free sterile rags, and a few plastic drop cloths to work on and cover the project to protect it from dust.
555ideways is offline   Reply With Quote
Help put my struts/springs back together :) Rallly2000 Brakes, Steering & Suspension 12 02-17-2010 10:15 PM
Help me put my Morette headlights back together properly!!! Rallly2000 Electrical & Lighting 1 06-07-2009 01:03 AM
How easy would it be to sell my short block? Jim2752 General Community 1 06-06-2009 08:54 PM
I am willing to trade my short block for fmic preferably perrin. 04sti the famlfax Engine/Power/Exhaust 4 04-11-2008 06:50 AM
What do I need to put my suspension together? What OEM Parts? emeessen Brakes, Steering & Suspension 2 10-03-2006 03:12 AM
