#1 |
Member#: 129199
South East
Vehicle:2004 WRX PSM Stage 2 |
To give the back story. Thursday night (2 days ago) I flash stage one in my wrx mainly just to learn the flash process because I am about to go stage two. Anyways, So today (saturday) I was driving home from school. I was almost to my house when at a redlight the car started rocking almost like a muscle car it is bogging down like it is going to stall etc. I look down and the check engine light starts to flash(never had done this before). I limp home (one block away) and read that this means I am misfiring in a cyclider.
I think well I will just go back to my saved stock map. I flash the old map. Start it up and it is still running crappy. I can hear it knocking and it seems like it is struggling. So I then reset the ecu but disconnecting the neg terminal and pressing the brake petal. Waited 10 minutes reflashed to stock again no luck. It is weird I would think that if it was a map problem it would have arisen early put on at least 200 since flash. I did a log which I can email to someone if they can look at it.
#2 |
Member#: 17256
Vehicle:04 STi Blue w/ custom bug splat |
Maybe post some of the log here and see what everybody thinks. Did the flash complete successfully?
#3 |
Member#: 118209
Vehicle:2002 WRX Sedan |
Did you log immediately after flashing stage 1? Just speculation, but lets say the stage 1 for your car was a little too lean. It had enough detonation to kill a bearing and you might not have been able to hear it. so now, you have 1 dead bearing (aka new shortblock), which seems to possibly be accurate since you said it is knocking even on the stock map. (I'm assuming you mean making a bad noise at idle, not knocking as in detonation.)
#4 |
Member#: 108089
Vehicle:2003 WRX NF Performance |
check for leaks.
my car felt like POOP when the intercooler popped off. pulled over, reconnected it and was fine afterwards. |
#5 |
Member#: 17256
You could just have a fouled plug.....
It sound to me like a dead cylinder. What is causing it could be anything from a bad plug, a bad coil, or a holed piston (assuming a broken rod would not run). I have had my inlet hose pop off the turbo several time, and it only affects the car under boost (at least to a noticeable level). |
#6 |
Member#: 17256
You could log a bit (Enginuity), even just at idle and see if "Roughness Monitor" for any particular cyl indicates a bad cyl....
#7 |
Member#: 129199
South East
The flash went fine. In fact, I didnt flash it. It was a local tuner here that had a lot of experience. He was teaching me how to flash so I could do stage 2 on my own later on. I did log after the flash. This was a really standard map nothing crazy. My speculation is a fouled plug, coil. I dont think that it is map related because I think the problem would have surfaced before now. Plus, the problem happened after driving some 200-300 miles on new map. Lastly, it happened after I was driving for like 30 minutes and happened while I was at a stop light not during flashing etc. I am by no means an expert just my .02 cents. If someone wants to take a look at the logs then just pm me and I will email them. That would be much appreciated.
| Thread Tools | |
| Display Modes | |
| car runs horrible with maf plugged in but fine when not | SethV | Factory 2.5L Turbo Powertrain | 13 | 06-15-2009 09:21 PM |
| Need Urgent Help, Sti runs horribly | Carxpressions | Factory 2.5L Turbo Powertrain | 12 | 09-25-2006 10:15 PM |
| Bad not to have exhaust heat shields? my cars running horrible. | rbmour | Factory 2.0L Turbo Powertrain | 11 | 08-07-2005 10:34 PM |
| help.........car running on 2 rear cylinders | legzy | Legacy Forum | 0 | 05-13-2004 08:36 PM |
| HELP...car running like crap... | Samirr76 | Tri-State Area Forum | 22 | 03-26-2003 04:59 PM |
