Old 03-01-2008, 08:42 PM   #1
rllyrckt
Member#: 158033
2010 Fozzie X Prem
Camellia Red Pearl
Default throttle wires
ok, after i replaced my block this week, im down to my last step, and that is hookin up my throttle cables....the problem is , I CANT get them to attach, or when i do, the "resting" position has the throttle pretty much at WOT, and i dont wanna start the car like that. do i need to reset my tps or what do i need to do? please help, its urgent
rllyrckt is offline   Reply With Quote
Old 03-01-2008, 09:04 PM   #2
02RSBRP
Member#: 159398
Can you take a picture of how you have the cables connected and how you have the cable routed in the engine compartment. Would make for helping you out much easier.
02RSBRP is offline   Reply With Quote
Old 03-01-2008, 10:01 PM   #3
rllyrckt
Member#: 158033
2010 Fozzie X Prem
Camellia Red Pearl
ok, i will tommorow
Old 03-02-2008, 07:37 PM   #4
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
What sort of swap are you doing? Different engine, or did you just replace a bad engine with a good version of the same thing?
Old 03-02-2008, 08:10 PM   #5
rllyrckt
Member#: 158033
2010 Fozzie X Prem
Camellia Red Pearl
i just replaced the bad block with a new block, so a direct swap, no differences
Old 03-03-2008, 06:01 AM   #6
bobbyjimmy
Member#: 114012
2002 Outback
Did you put the cable end thru the hole at the end of the wheel and then feed the cable back around?
bobbyjimmy is offline   Reply With Quote
Old 03-03-2008, 10:51 AM   #7
rllyrckt
Member#: 158033
2010 Fozzie X Prem
Camellia Red Pearl
yea i routed it through the "guides" and this is what gives me the problem, its all connected correctly but its just causing the throttle to be at 1/2 open
Old 03-03-2008, 07:48 PM   #8
02RSBRP
Member#: 159398
How do you have the adjusting screws set? when the cable sits in the cable bracket, one nut should be on one side of the bracket and the other one on the other side. If you have it set that way then loosen one nut and let the cable move towards the throttle body until the throttle plate is shut.
Old 03-03-2008, 08:01 PM   #9
flstffxe
Member#: 155358
2008 Forester
Steel Silver
just a thought but the other end isn't hung up in the lever on the gas pedal is it? Not fully seated all the way.
flstffxe is offline   Reply With Quote
Old 03-03-2008, 09:06 PM   #10
rllyrckt
Member#: 158033
2010 Fozzie X Prem
Camellia Red Pearl
the nuts are set in the position that they were originally, and i know that beacuse the threads are shiny where the nuts were, so thats where i reset them at, im not sure about the pedal, im gonna check that tommorow
Old 03-04-2008, 06:09 PM   #11
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
Those two statements do not compute. Obviously something is not connected correctly, or you wouldn't be posting here.
Without some pictures showing how you've got the throttle "wires" routed, I don't see how we can tell you what you did incorrectly.
Old 03-04-2008, 06:23 PM   #12
flstffxe
Member#: 155358
2008 Forester
Steel Silver
I still say look where the cable attaches to the gas pedal and see if it is seated all the way.
Old 03-06-2008, 01:10 PM   #13
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
Did you switch intake manifolds, or just the lower part of the motor? What year car did it come from? Same year, same model? I ask because I tried to install cruise on my 97 OBS, and the cruise off a 94 impreza that had it from the factory gave me issues with the throttle cable coming from the vacuum actuator. It wasn't long enough when you mounted it in the throttle cable holder/mount. So the throttle would be open all the way when it should be closed.
The only thing I can think of is the bracket design is different, cable length is different, or intake manifold mount spot is slightly moved between different MY's. Either way, we'd need some more info to help.
Legacy777 is offline   Reply With Quote
Old 03-06-2008, 08:11 PM   #14
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
any update? im curious to know what the problem/fix is.
GrundleJuice is online now   Reply With Quote
Old 03-07-2008, 12:12 AM   #15
rllyrckt
Member#: 158033
2010 Fozzie X Prem
Camellia Red Pearl
i used the same intake manifold and heads off of my stock motor, and just another ej25 block, so its in the same position as stock and no the problem isnt solved, im still at a loss.....
Old 03-07-2008, 08:21 AM   #16
flstffxe
Member#: 155358
2008 Forester
Steel Silver
^^^ have you checked at the gas pedal yet to see if the other end of the cable is fully seated? If it worked out part way while you were swapping things out it can cause your problem. If you didn't adjust the cables at the intake(no reason too) this is just about your only spot some thing can go wrong unless you are not getting the cable in the groove on the wheel, as in the cable ferrel is hooked in the wheel but the cable may be running over the top of the tab used as a guide and not under it. Look at the gas pedal where the cable attaches. I mentioned it twice and didn't see a respons as a yea or nea on it so this is a 3rd attempt.
Old 03-07-2008, 09:01 AM   #17
rllyrckt
Member#: 158033
2010 Fozzie X Prem
Camellia Red Pearl
yeah it was fully seated at the pedal i did check that yesterday, sorry i forgot to respond to that, but yes it is fully seated at the pedal, and yeah i thought that the tab might have been giving me problems, but i made SURE that i missed the tab when i went to seat the cables, so, thanx for the suggestions but they have been already tried, i think my next option is to buy anothet throttle cable and see what that does, maybe, just maybe something for some unknown reason got screwed up on the original cable and i cannot find it and by getting another cable, that will solve it, im hoping, thank you everybody for the help and suggestions....
Old 03-07-2008, 12:28 PM   #18
Legacy777
Member#: 4800
I guess I'm with Patrick Olsen on this one. If you used the same intake manifold, same cable, etc.....everything was fine before you swapped the block, and now it won't work. Then something is not installed properly. Things don't just stop fitting.
Any chance you can get some pictures?
Old 03-07-2008, 12:36 PM   #19
rllyrckt
Member#: 158033
2010 Fozzie X Prem
Camellia Red Pearl
ill put some up in a couple of mins, lemme go take some, hold on
STi swap wiring question BMXspears Subaru Conversions 7 06-04-2010 02:32 PM
electronic throttle wiring diagram seanbass42 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 9 06-01-2007 10:51 PM
swapping in a throttle-by-wire motor = problem? edkwon Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 05-15-2003 03:52 PM
Can cruise control wires be tapped to apply throttle programmatically? rharder Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 07-23-2002 01:20 PM
Electronic drive-by-wire throttle? WRXThis Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 32 11-30-2001 04:50 PM
