Old 03-01-2008, 10:43 PM   #1
Matt_H
Member#: 107000
2015 BMW X1
Default DIY: Clear and paint your 08 headlights
Put a few hours aside today to put this together to maybe help some people. Took about 3 hours total from start to finish. I didn't paint the light surrounding, just the reflector. Thanks to YTDiamond05 for helping.
Tools needed:
12mm Socket
#1 Philips screw drive
#2 Philips screw drive
Panel pop
Gloves
Drill (optional)
Razor (to cut the silicone when pulling the light apart)
Paint
Paint used
Step 1:
Start off by removing 6 plastic push clips, 4 in the grill and 1 in each of the head lights, and removing 2 screws in the top of the head lights pictured below, and remove the two clips in fender well, one is a push clip another is a Philips clip. There also clips on the bottom of the bumper attached to the splash guard.
Step 2:
Remove the bumper.
Step 3:
Preheat oven to 220 F degrees.
Step 4:
There are 5 screws that hold the light in, one of which was removed in the first step. Pictured here are the others that need to be removed. There is one harness that plugs into the back of the light housing.
Matt_H is offline   Reply With Quote
Old 03-01-2008, 10:44 PM   #2
Matt_H
Member#: 107000
2015 BMW X1
Step 5:
Once the light is removed you have to take off the bracket on the bottom of the light.
Step 6:
Remove the 5 small screws that hold the front lenses on.
Step 7:
Your oven should be up to temp after the last two steps. Put in oven on a cookie sheet, you do not need to remove the lights, harnesses, your choice. Leave it in for about 10-15 minutes to soften up the sealant holding the lense together to the light.
Step 8:
Remove the housing from the oven, make sure you use glove. Slowly pry open the housing. Careful not to pry too hard and crack the lense.
Once it's past the clips, it should come apart easily, just go slow.
Here is what you end up with:
If you want to paint the black housing with the chrome ring you have to remove a few more screws.
Step 9:
The reflector has two screws holding it on. I don't have any pictures of the painting, but I painted both side of the reflector with 4 light coats. Putting it back in...
Painted reflector:
Step 10:
Put the lense back on the housing, and put it back in the oven, still on 220 for 10 minutes. After it heats up remove it and make sure you put the screws back in. Screwing it together should tighten up the housing pretty good, and make sure there are no gaps between the housing and the lense. Reinstall the bracket on the bottom of the housing.
Old 03-01-2008, 10:44 PM   #3
Matt_H
Member#: 107000
2015 BMW X1
Step 11:
Put it all back together, and enjoy.
Old 03-01-2008, 10:52 PM   #4
Lubes
Member#: 147490
2007 WRX
UGM
Sweet write up man, now I just need to find the 06/07 version of this!! haha
Lubes is offline   Reply With Quote
Old 03-01-2008, 10:55 PM   #5
Matt_H
Member#: 107000
2015 BMW X1
Old 03-01-2008, 10:55 PM   #6
573
Member#: 144821
1994 LS1 Miata
2015 white WRX
Looks really good. Nice work and writeup.
573 is offline   Reply With Quote
Old 03-01-2008, 11:32 PM   #7
Lubes
Member#: 147490
2007 WRX
UGM
Gracias!
Old 03-02-2008, 02:19 AM   #8
clbd39
Member#: 104078
2013 WRX
looks very good, good job!
clbd39 is offline   Reply With Quote
Old 03-02-2008, 03:53 PM   #9
|Disso|
Member#: 155515
OBP pignose
IG-KuostA
Looks absolutely amazing! Love the contrast it gives to headlights for colors like white, wouldn't do it on OBP black though, as it just dulls the headlights down and blends them in, taking away the aggressiveness.
|Disso| is offline   Reply With Quote
Old 03-02-2008, 03:59 PM   #10
chulooz
Member#: 159438
99 GC8
looks real clean, nice job, and a good write up.
chulooz is offline   Reply With Quote
Old 03-02-2008, 04:44 PM   #11
dyslexicwrx
Member#: 46031
2009 STi
That turned out very clean. Great write up.
dyslexicwrx is offline   Reply With Quote
Old 03-07-2008, 11:23 AM   #12
djtang88
Member#: 159191
Nice DIY. yea saw it on the Nation woot. haha
djtang88 is offline   Reply With Quote
Old 03-07-2008, 03:43 PM   #13
SubieWReX
Member#: 151080
07 BME AutoX WRX
very balsy for a brand new 08, lol. Im still afraid to do this with my 07.
SubieWReX is offline   Reply With Quote
Old 03-07-2008, 03:45 PM   #14
Matt_H
Member#: 107000
2015 BMW X1
Here's a shot in the sun.
Old 03-08-2008, 12:15 AM   #15
felix27
Member#: 173805
08 impreza 2.5 1
dark grey
congrats man, very clean job, got me motivated to pop some more lamps in the oven, i used to clear out the s10/sonoma headlights like that, never had the balls to rip out my 08 imprezas, definately gonna do it soon though haha, thanks for the post
felix27 is offline   Reply With Quote
Old 03-08-2008, 02:06 AM   #16
Traxamillion
Member#: 162514
looks good man, good job. just did this to my 06 rex best mod i've done yet!
Traxamillion is offline   Reply With Quote
Old 03-08-2008, 10:16 AM   #17
Trevor K
Member#: 173144
07 STI
Nice write up. Turned out looking great!
Trevor K is offline   Reply With Quote
Old 03-08-2008, 12:10 PM   #18
SubieZen07
Member#: 145021
2007 WRX Stage 2
Carbon Fiber and WR Blue
question though...do u have to use a sealer to put back together the headlights or just screw them back?
SubieZen07 is offline   Reply With Quote
Old 03-08-2008, 12:12 PM   #19
Matt_H
Member#: 107000
2015 BMW X1
There is enough sealant still in the head light. I guess you could add more sealant if you wanted to, but I wouldn't.
You put both piece in the oven to warm it (the sealant) and it goes back together easily.
Old 03-29-2008, 10:26 AM   #20
skiteton
Member#: 53064
2011 Legacy 2.5i
2012 Acura TSX
I'm thinking about doing this to my 2008 sedan. I did it with my '04 and it looked great, so I'm anxious to do it with this one.
One question though for Matt: Do you have a picture of the area behind the reflector before you painted it? I'm hoping it's chrome b/c I don't want to paint mine, but I don't want it to look like dull plastic. If no pic, can you remember what it looked like?
Nice write up! Without this, I would never even attempt it.
skiteton is offline   Reply With Quote
Old 03-29-2008, 11:53 AM   #21
Matt_H
Member#: 107000
2015 BMW X1
It was chrome behind the reflector.
Old 03-30-2008, 01:23 AM   #22
qualityracer
Member#: 176016
2002 2.5rs impreza
dark blue
wow, it looks really good... can't wait until it gets warmer
qualityracer is offline   Reply With Quote
Old 04-08-2008, 12:12 PM   #23
RaceWeapons.com
Member#: 169311
nice work !
RaceWeapons.com is offline   Reply With Quote
Old 04-08-2008, 12:20 PM   #24
AVAWRX
Member#: 151353
2006 WRX TR
looks awesome! nice write up!
AVAWRX is offline   Reply With Quote
Old 04-16-2008, 07:01 PM   #25
pinemind
Member#: 176519
2009 BMW 335i xDrive
Barbera Red
Remove the bumper ...
I was wondering if you could possibly elaborate on this a bit? I removed every single bolt and clip named on the splash guard, grill, both headlamps, fender well. There were 3 in the fender well btw. But simply "removing the bumper" was next to impossible.
There was something connected between the fender and the bumper where they meet. I don't see how I could possible get to the inner fender of driver's side without removing the battery completely to check it out.
Is there something I'm missing here?
Justin
pinemind is offline   Reply With Quote
WTT : Cleared and Painted 04'05' Headlights for Stock Headlights d0ugch0i SCIC Private Classifieds 11 06-14-2009 03:26 PM
Anyone wanna clear and paint my 06 headlights? generalganja Southern California Impreza Club Forum -- SCIC 36 09-07-2007 02:55 PM
Clearing and painting headlights evom024 Interior & Exterior Modification 4 04-28-2006 11:05 PM
Cleared and Painted '05 Headlights drazzi Interior & Exterior Modification 3 09-20-2005 01:14 PM
Cleared and painted my headlights, what do you think? (56K beware) Padge Member's Car Gallery 15 06-27-2005 04:06 PM
