Old 03-02-2008, 12:24 AM   #1
Psipwrd
Member#: 102746
1992 Celica GT-4 CS
Default Power Steering Pump and Overheating
I'll try to add all details and keep it short...
PSP: Bad high pitch squealing while giving a little gas, deeper pitch when turning the wheel while sitting still. BAD PSP? I drained some PS fluid and added some, but same prob. Got worse and worse over past month.
Overheating: Only changes to the car was header wrap 3 days earlier, and Hallman Evolution BCS add-on the same day. Checked for anything I may have upset during install, found nothing. After normal driving, the temp was over 3/4. I tried the burping procedures (full heater, 3K rpm, cool, top off) and it was full after first cycle (tried 3 cycles). Tried draining and couldn't get drain plug off! Changed cap by turbo (with the pressure release) and still overheating.
People mentioned a cap on the radiator, but none on my 02WRX.
Car doesn't overheat w/o load/driving, and stops just above 3/4 heat. Idle and even revving to 3000 rpms parked, heater or A/C, temps are normal.
UTEC Stg3, ebay FMIC (2 years), ebay headers (2 months)
Psipwrd is offline   Reply With Quote
Old 03-02-2008, 10:23 AM   #2
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
Subaru sounds like a bad power steering pump
have you inspected the ps belt for correct tension?
re: overheating
02 wrx are known for hairline cracks in the OE radiator
Subaru has since superceded (replaced) the OE radiator with one which has a cap on it
do you smell any coolant - ANY????
you may not see it but if there is a hairline crack
you will get that sickly sweet coolant odor and the car will overheat at times....
been through the same thing on my 02....
Jamie
Old 03-02-2008, 05:01 PM   #3
Psipwrd
Member#: 102746
1992 Celica GT-4 CS
Pump: When I changed the belts, I just adjusted the tension until it stopped squeaking. It's slightly looser than the AC belt. I'll at it again...
Overheating: No cracks, leakage, smell, etc. I'm going with the thermostat and will look into upgrading the radiator later.
I'm in the process of changing the thermostat (PITA) and the new one didn't come with a rubber gasket, and the old one's hard and warped. Are they supposed to come with the t-stat? I'm stuck until I can get a friend over to go back to the store.
Old 03-04-2008, 11:16 AM   #4
Psipwrd
Member#: 102746
1992 Celica GT-4 CS
Fixed! I tightened the belt until it stopped squeaking and I finally got a o-ring that stays on the t-stat during install after 4 trips to the store. Thx Subie Gal!
Old 03-05-2008, 11:18 AM   #5
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
yay!!!
Jamie
FS- 2 A/C pumps power steering pump and alternator can'tread503 NWIC Private Classifieds 1 10-19-2009 08:09 PM
WTB: Power Steering Pump and Lines turboL Private 'Wanted' Classifieds 2 03-12-2009 10:34 PM
WTB - 2002+ Power Steering Pump and reservoir STEALTH-WRX Private 'Wanted' Classifieds 0 08-20-2007 07:46 PM
WTB: WRX Power Steering Pump and Lines DeusExMachina Private 'Wanted' Classifieds 7 10-21-2006 07:24 PM
power steering pump and rack spongejosh Brakes, Steering & Suspension 1 06-29-2005 06:27 PM
