Old 03-11-2008, 11:53 PM   #26
wrxG
Member#: 155087
04 WRX
Thanks guys for all the advise.. Its weird when car starts up cold.. like in the morning theres no knock what so ever ... but once i drive it for a little while it comes on.. I parked my car today and will take it apart this weekend.. I really cant wait to find out what went wrong .. will post pics once its all apart.
wrxG is offline   Reply With Quote
Old 03-12-2008, 12:24 AM   #27
wrxwagon253
Member#: 125620
05 3076R Wagon
B5 S4 w/ Stg.3 RS6 kit
Good luck with your car..Hope everything works out for the best..
wrxwagon253 is offline   Reply With Quote
Old 03-12-2008, 12:42 AM   #28
slowmike
Member#: 24890
2002 Jackwagon
WRB GG
Originally Posted by wrxG View Post
I did get my halves cleaned and rehoned. But if block is honed or unhoned i really dont see how that would case knock. The first time i rebuilt this block with stock subaru parts. I got my cranshaft balanced and machined caz num 3 rod bearing was spun, and i didn't rehone the cylynders but i still made 180 psi compression in allfour cylinders.
I remember when I put the Wiseco pistons in I moved the piston from side to side and seemed like it had way too much play on cylinder three. But one of my friends with "expirience" told me oh thats normal. Now im 90% sure thas the problem unless like some of you are saying .. i didn't crank the motor over enough to get the oil pump going and it could of started with any oil pressure and caused a rod bearing to spin or something.
Right now I don't even touch my car .. im so mad at it. So much time and I cant even drive it still. All of my friends with hondas are laughing at me.. they're telling me to get a honda =( .. but I know once it going to be done.. the right way.. im going to have alot of fun with it this summer killen them hondas!
Did you get oversized bearings to match the newly machined crank?
slowmike is offline   Reply With Quote
Old 03-12-2008, 03:49 PM   #29
wrxG
Member#: 155087
04 WRX
^ ofcource the machine shop supplied them for me^
Old 03-16-2008, 01:03 AM   #30
wrxG
Member#: 155087
04 WRX
Okay so I found out what the problem was! I told you guys how my rod bearing are 0.25 oversised because cranshaft was macined down after rod bearing num 3 spun. So i did use oversised bearings on rods.. but what i didn't relize was that i need oversised main bearings too.. i used cosworth main bearing set which is stock size.. I cant believe i did that still.. so its a prety easy fix just alot of work to rip the motor all apart.
Old 03-16-2008, 02:36 AM   #31
flycaster
Member#: 60142
2011 WRX
Grey
Your idea of "easy" isn't the same as mine...
Good luck, and let us know how it sounds after you rebuild it.
flycaster is offline   Reply With Quote
Old 03-16-2008, 03:10 AM   #32
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
You know, I installed a crank backwards, but at least I caught the error.
Old 03-17-2008, 12:03 AM   #33
wrxG
Member#: 155087
04 WRX
For me its easy.. i took the motor out and riped it all apart in under 3 and a half hours .. crank is at the machine shop getting check out and they will order the right size bearing for me .. dont know what u think is so hard about it .. unless uve never took the whole motor aprt b4....
Old 03-17-2008, 12:04 AM   #34
wrxG
Member#: 155087
04 WRX
haha nice man! that would work to well probly
Old 03-17-2008, 01:22 AM   #35
flycaster
Member#: 60142
2011 WRX
Grey
...dont know what u think is so hard about it...
"Easy" is something that takes 10 minutes, not 10+ hours. Regardless, I sure hope you slow down a little on the rebuild this time - "fast" leads to mistakes, as you already know.
Old 03-17-2008, 10:21 AM   #36
wrxG
Member#: 155087
04 WRX
Yeai know thats true .. ill try to take it easy this time .. thanks
Old 03-17-2008, 12:06 PM   #37
flycaster
Member#: 60142
2011 WRX
Grey
Cool - I'd much rather read a new thread which goes something like, "Built motor - runs like a dream."
BTW, 3.5 hours to take an engine out, on the stand, heads off, and then split the cases is greased lightning fast for 1 guy - especially if the engine still has all the stock accessories on it. That's an hour and a half less than book for just a clutch R&R. I assume you do this for a living?
Old 03-17-2008, 04:37 PM   #38
wrxG
Member#: 155087
04 WRX
Haha yea i cant wait to post that thread
I used to deal with subarus for a lilving yeah.. now i just fix my car and help out friedns with subarus
Old 03-17-2008, 04:45 PM   #39
Rick539
Member#: 35997
Had knock just as you described. Using helix rods. It turned out to be a rod clearance problem. All four were just clipping the block webbing on the 1 and 3 side. Interestingly we measured the webbing on the 2 and 4 side and it was 1.5mm shorter. Milled 2mm off the webbing and no more knock.
Rick539 is offline   Reply With Quote
Old 03-18-2008, 02:23 AM   #40
benw
Member#: 103320
1998 swapped
Forester L
Yikes!
Buddy of mine had a similar "I'll be damned!" moment. Got his car tuned, parked it for 4 days during a bad ice storm. started it up, and knocking like crazy. sounded like rod knock from hell. diagnosis was that the piston was actually hitting the block webbing. we think an injector filled a jug and semi-hydro'd that cylinder and fubar'd the rod. It must have happened on startup because we traveled all the way home from Dallas to OKC and it ran like a sweetheart, I was in the car the whole time.
benw is offline   Reply With Quote
Who will blow there newly built motor first? TJ Texas Impreza Club Forum -- TXIC 82 02-14-2008 02:09 PM
world's first built motor and s/c on an svx sicksubie New England Impreza Club Forum -- NESIC 49 09-06-2007 11:19 PM
First built motor and supercharger in an SVX sicksubie General Community 38 09-06-2007 11:15 PM
built motor knock sensitivity dukeduster Built Motor Discussion 5 03-13-2007 12:39 AM
unusual knock issue - built motor Lennon UTEC 8 05-11-2006 02:00 PM
