Old 03-02-2008, 01:30 PM   #1
greenspeed
Member#: 151248
00 Impreza 2.5RS
Whore Door
Default My ej25d to phase 2 swap- need help asap
I blew the engine in my 98 legacy and found a buddy with an 01 rs engine. I decided to do the swap using pretty much just the phase 2 short block. Here are my two main questions that I pretty much need to get solved asap. I am digging in to take out the engine off my legacy tomorrow afternoon...
Will my flywheel bolt to the 01 rs?
If I have to mill my heads on my legacy will the intake still fit?
Thanks ahead fo time...
greenspeed is offline   Reply With Quote
Old 03-02-2008, 01:41 PM   #2
novacivic
Member#: 117980
2005 sti
wr blue
yes and yes
novacivic is offline   Reply With Quote
Old 03-02-2008, 01:43 PM   #3
flstffxe
Member#: 155358
2008 Forester
Steel Silver
Can't say on the flywheel, I don't know.
As for the heads about the most you want to take off is .010" (10 thousandths), and yes it will still fit. .010" is ~2-3 sheets of paper, not much. It is also a good idea to check the deck(where the heads bolt) on the block to see if it is also flat. Milling the heads wont do any good if the Block is not also flat, and can be the source of some repeated head gasket failures if over looked.
flstffxe is offline   Reply With Quote
Old 03-02-2008, 06:27 PM   #4
greenspeed
Member#: 151248
00 Impreza 2.5RS
Whore Door
I am actually going with a newer short block out of a running 01 rs...so I hope that the heads are straight and true and the decks good too...
Anyone know about what clearance should be with a straight edge on the heads? .010? or so?
thanks
Old 03-02-2008, 07:19 PM   #5
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Just to clarify, the shortblock does not include the heads; a longblock includes the heads. So are you planning to use the SOHC heads or your old DOHC heads? If you're planning to use the SOHC heads, well, it ain't gonna work. The sensors and wiring aren't going to match up to your ECU and wiring harness from the DOHC engine.
You can put your DOHC heads and intake manifold on the P2 shortblock.
Pat Olsen
Old 03-02-2008, 08:39 PM   #6
greenspeed
Member#: 151248
00 Impreza 2.5RS
Whore Door
I am using my DOHC heads...I am just using the short block of the SOHC phase 2
Old 03-02-2008, 09:30 PM   #7
flstffxe
Member#: 155358
2008 Forester
Steel Silver
thanks
The heads need to be within +/- .002" flatness, The same goes for the block deck. Really they should be checked on a flat plate/mill... with with a dial indicator as a "straight edge" for anything other then the machining industry may have .010" runout in its self.
Old 03-03-2008, 02:21 AM   #8
greenspeed
Member#: 151248
00 Impreza 2.5RS
Whore Door
the head are not larger than .002 using a brand new straight edge...I will have to wait on the disassembly of my phase 2 block to check the deck on that...but as for my legacy...I will post a new thread about that...
2.2phse 1 to 2.2 phase 2 swap kdub420 Normally Aspirated Powertrain 0 03-12-2008 07:48 AM
brake swap, need help asap The Beej Brakes, Steering & Suspension 1 01-07-2007 05:39 PM
EJ25 DOHC Phase 1 to SOHC Phase 2 swap 93L-RS Subaru Conversions 7 08-22-2006 09:29 PM
2.5 phase 1 to phase 2 swap limeylight Subaru Conversions 12 12-29-2004 06:31 PM
phase 1 to phase 2 swap limeylight Normally Aspirated Powertrain 0 12-29-2004 10:24 AM
