Old 03-02-2008, 11:46 PM   #1
wrxpeed
Member#: 49958
'03 Cobra DSG
SOLD '02 WRB WRX
Default Please help diagnose. Car won't start and looks like an electrical problem.
I have a problem and my car won't start and think its an electrical problem. Seeing if anyone has insight to what could be causing the problem. The Car is a 1992 Legacy SS.
At first it was intermittent then over the weekend got worse and now won't start at all. It started when I was driving long distance and when I filled up it wouldn't turn back on. We tried for 10 minutes then magically it turned over instantly. That night it did it again and I had to wait longer but did work later. Then this went on for a day, getting longer and longer til it would start after shutting it off. Now its just off and won't start.
What's wrong is it seems the car isnt getting spark or fuel, but it cranks just fine and everything else seems in order. We thought it may be a bad fuel pump and swapped in a new one since the old one didn't seem to even prime when the car was turned over. We put a new one in and seemed fine and primed but the engine still didn't start. We then checked the fuel line right after the fuel filter and there was plenty of fuel so fuel was being pumped.
So we pulled 2 plugs to see if they were foiled dry, etc and to see if they were firing. When we pulled them they looked shot and looked to be missing their electrodes but didn't smell like gas or looked fouled. We then cranked the engine over and we didn't see any spark and didn't smell any gas being injected.
What could the problem be?
I did just finish a 5Mt swap Thursday but didn't mess with any electriconics. This shouldn't be effecting this but you never know.
wrxpeed is offline   Reply With Quote
Old 03-05-2008, 02:04 AM   #2
wrxpeed
Member#: 49958
'03 Cobra DSG
SOLD '02 WRB WRX
bump. anyone??
Old 03-05-2008, 03:35 AM   #3
mikeis300
Member#: 149526
2002 aps dr65 hybrid
9.1x1 built block/heads
have your ecu checked out. and check all the wires going to your fuel system. i.e. when you turn the key to on(not start) you should hear the fuel pump prime the filter( also check your fuel filter) if not thats a isue. but no spark and no fuel i would check the ecu.
mikeis300 is offline   Reply With Quote
Old 03-05-2008, 01:18 PM   #4
Arctic Penguin
Member#: 119532
2006 WRX
battery and or battery cables
Arctic Penguin is offline   Reply With Quote
Car won't start and CEL won't illuminate DiscoGsus Normally Aspirated Powertrain 5 04-14-2010 10:19 PM
car won't start....and I'm an idiot srt4eh Service & Maintenance 8 12-07-2005 03:05 AM
Need Help!! Car won't start and is clicking silversilver Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 05-16-2005 12:03 PM
Car won't start any advice on whats the problem SlidewaysSTi Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 02-23-2005 10:29 PM
Car won't start and blinking cell!!!! HELP!!!!!! RoadRageDev Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 08-06-2004 11:30 AM
