Welcome to the North American Subaru Impreza Owners Club Thursday March 5, 2015
Old 03-03-2008, 01:05 AM   #1
DJIMPREZA
Member#: 1199
1994 Supra+1K, 22b
alike, 07STI
Default STi clutch slipping at 26 psi of boost
Street use, stock tranny, car is just perfect for the street and ocasinal strip.
I need to find a replacement for an sti setup I need
Stock feel like pedal pressure
Low tranny impact
Able to hold at least 100 LBs of torque more
Clutch is slipping during shifftings..
From my wrx experience
ACT IS not an option as is too stiff, tranny will break too soon
EXEDY stage 1 organic won`t last too long, maybe 20 passes on the 1/4 quarter
Hate the tilton hydraulic release bearing system and the terrible noise and low inertia, terrible for awd launches and street use on heavy traffic, won`t last long.
Carbon series clutches... won`t last long on the street, expensive as hell.
I need something as close as the hybrid I made for wrx, wich is exedy stage I pressure place with act 6 puck sprung hub disc, will chatter sometimes, but it won`t make any noise as any multidisc, very easy to drive around once you get used to the chatter and is tranny friendly, the combo holds nice the 450 LBS or so.
Exedy stage II 3 puck is just to harsh compared to act 6 puck
Any other experience with clutch but.. for sti??
Later
DJ
DJIMPREZA is offline   Reply With Quote
Old 03-03-2008, 01:59 AM   #2
Unabomber
Big Ron
Member#: 18062
on car parts so PM
me b4 j00 buy
26 PSI of boost has zero to do with clutches and which one to buy. Use your torque rating or estimated torque rating and buy the clutch that meets or SLIGHLY exceeds that rating and buy it. Clutches aren't rocket science, buy what you need and nothing more. Read the Clutch & Flywheel FAQ to ramp up your knowledge base and good luck finding what you need.
Old 03-03-2008, 02:07 AM   #3
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
sounds like you might be looking at a twin disk. I had a exedy twin organic and it was great. Also rebuildable.
Old 03-03-2008, 03:25 AM   #4
Tony_Montana87
Member#: 157001
2004 Impreza WRX STI
my reccomendation. ACT EXTREM PRESSURE PLATE AND A PERFORMANCE DISC. There done, all you will need.
Tony_Montana87 is offline   Reply With Quote
Old 03-03-2008, 11:20 AM   #5
DJIMPREZA
Member#: 1199
1994 Supra+1K, 22b
alike, 07STI
act pressures plates are too much for a street car, even on my race car the best tranny won`t live that long!
Exedy twin organic?? sounds like right, but I am sure that have a lightweight flywheel! wich I wouln`d`t recomend for hard launchings and off and go on heavy traffic...
Any other recomendation?
Unambomber
I have read many times the ***, pass trough many many setups on a wrx, as you can see, the exedy stage I with 6 puck act is the best for 10 sec street cars from my findings, it will chatter a bit, but the pressure plate has just the right amount of holding capacity betwen pedal effort modulation and clamp capability for a 10 sec car.
I hate twin discs as they are offered with a lightweight flywheels, on a street subaru used ocassionally for the drag, it`s simply no good! you will overheat the clutch everytime you try to launch and it will make noise on the street...so you`ll eat it quiet fast for an expensive investment...
I love the stock clutch on the subarus, to bad it just doesn`t grab as it should, I am sure the delay valve is also contributing the slippage but.. well.. time for an exedy stage I with act 6 puck disc
Later
DJ
Old 03-03-2008, 12:58 PM   #6
06rexwagon
Member#: 114730
2006 WRX Limited Wag
9.8@150
26psi on what turbo?
06rexwagon is offline   Reply With Quote
Old 03-03-2008, 02:34 PM   #7
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
Old 03-04-2008, 03:40 AM   #8
DJIMPREZA
Member#: 1199
1994 Supra+1K, 22b
alike, 07STI
aps tsr70...
Old 03-04-2008, 11:04 PM   #9
2ndGearFling
Member#: 64466
05, STI on green
haha.....tsr70? Is that a joke?
2ndGearFling is offline   Reply With Quote
Sti Peaked at 1.2 Bar or 17.5 PSi of boost why hilfiger4you Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 08-31-2007 08:24 PM
stoc sti with boost 28 psi of boost?!!!!! Mohammadov Newbies & FAQs 5 08-26-2007 11:42 AM
FYI - Exedy race clutch for RS slips at 15 psi on 2.5L ImprezaRS dot com Transmission (AT/MT) & Driveline 0 10-17-2002 10:44 PM
Clutch slipping at 19k miles? Angelo General Forum Archive 1 01-22-2001 10:50 PM
