Old 03-03-2008, 01:35 AM   #1
skydes
Member#: 141347
2005 WRX
Default Grunching noise from rear suspension when going over bumps
I'm hearing this grunching noise from the rear suspension when I go over bumps. For example when I back down the my driveway and roll over the 2'' (inch) lip at the end of it it grunches. No matter how slow I go I hear the "gruuuuuuunnchhh" noise. First I thought it was my swaybar in the bushings (Cobb hollow sway) but the suspension is barely compressing and decompressing when going over the lip. Could it be my tophats are not tight enough? I torqued them to 10ft/lbs (didn't do the full 14.4 ft/lbs for fear of snapping the threads).
Mods:
STi OEM Rear tophats
STi struts
STi springs
Cobb hollow sway
Perrin Rear endlinks.
skydes is offline   Reply With Quote
Old 03-03-2008, 07:20 AM   #2
RaceComp Engineering
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
thats a starting point ,..yeah. Many people over torque those to crazy amounts(20-30) so I dont think setting them to the correct would be an issue. 10 I think is too low and if your tq wrench is off (like many are since most dont turn them back to zer owhen done)..its prob off. THat 4 ft lbs could be it. Most do it by hand and never have an issue and that ends up being in the 20's.
Myles
RaceComp Engineering is offline   Reply With Quote
Old 03-03-2008, 02:49 PM   #3
skydes
Member#: 141347
2005 WRX
Ok, I'll try that and report back.
Thanks.
Old 03-04-2008, 12:46 PM   #4
hwy61
Member#: 87950
2005 STI
Gone....Somewhere in MS
The rea bushings in my 05 STI have been replaced 4 times under warranty and they are doing this very thing again. If you come to a stop with the rear end jacked up a bit, as soon as you let off the brakes or drive in reverse...........a really aggravating crunching sound that you can feel in your seat. The fix is simple and I'm thinking about simply greasing with silcone or something myself.
hwy61 is offline   Reply With Quote
Bad clunking noise from front pass side when going over bumps? (05 STi) Optimus Prime Brakes, Steering & Suspension 16 06-24-2006 11:18 PM
Squeak from rear when going over bumps CletusTheDwarf Brakes, Steering & Suspension 6 01-31-2005 03:57 PM
STi question - knocking sound from steering wheel when going over bumps WRXIN Brakes, Steering & Suspension 16 05-05-2004 08:59 AM
noise when going over bumps! Kyguy Brakes, Steering & Suspension 1 02-02-2004 02:52 AM
