Old 03-03-2008, 02:28 AM   #1
greenspeed
Member#: 151248
00 Impreza 2.5RS
Whore Door
Question Blown rod on ej25d...anyone else have this happen?
I had a clear rod knock on my 98 legacy gt ej25d. So my buddy, his dad, and I started to tear things down to find out what was going on. Got it down to the heads expecting to see a cracked head gasket of some sort. There wasn't a thing wrong with the gaskets but it was apparent there was coolant in at least one of the cylinders, but more likely to be in two. Cylinders 1 and 3. They had a nice carbon build up around the center of the piston looking normal, but very clean around the outside.
Got the pan off and the oil was a little metalic on color and ther were some tiny chunks of bearing in the oil pan. Then started to spin it over by hand to figure out what bearing let lose. It turned out to be the number 3 cylinder. I just am puzzled along with everyone else...how the coolant got from the head down to the rod bearing with the heads not being warped and the car never over heating.
Mentioning all of this brings insight to another question...the number 4 cylinder had "rust" on the cylinder walls, just a dusting of what i want to call rust but am not entirely sure...the engine seemed to have been apart before...
This thread is useless with out pics so I will post some tomorrow after I get a ton of other stuff done...just wanted to share and I got another day to wait on parts...
greenspeed is offline   Reply With Quote
Old 03-03-2008, 10:35 PM   #2
DeMoe Aurelius
Member#: 162900
2005 Legacy GT 2.5
Atlantic Blue Pearl
Unhappy Blew my rod 3-01-08
I throw a rod also on my EJ18. Plenty of coolant in the tank but 1 quart of oil in the pan. And the color of sparking mud. It's crazy cause I changed it when I got the car. So I only put 1100 plus miles on the oil but under 1200. I checked the oil 3 days before in the parking lot at work so it made no sense that I blew the motor with 13700 miles on the clock.
DeMoe Aurelius is offline   Reply With Quote
Old 03-04-2008, 01:38 PM   #3
greenspeed
Member#: 151248
00 Impreza 2.5RS
Whore Door
After talking to the dealer i guess its not uncommon for there to be seepage with no visual crack...
Old 03-04-2008, 06:30 PM   #4
flstffxe
Member#: 155358
2008 Forester
Steel Silver
I have broken a rod.
All I have to say is DO NOT BUY A CUMMINS REMAN shortblock from Subaru. The fun with the reman shortblock starts at post #24.
http://www.mnsubaru.com/forums/showthread.php?t=18158
flstffxe is offline   Reply With Quote
Old 03-04-2008, 07:14 PM   #5
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
those pictures make me cry inside.
Old 03-04-2008, 07:22 PM   #6
flstffxe
Member#: 155358
2008 Forester
Steel Silver
^^^Not to steal the ops thread, but right as it happened I pretty much went passed all the stages of denial, anger ..... right to acceptance. I more or less knew what had happened. Sad thing is it let go at about 2,500 - 3K rpm leaving a stop light in traffic. My failure was caused by a wristpin clip that came out of the piston followed by the wristpin walking out into the base of the cylinder wall bending the rod thus shattering the piston and so on.
Anyone else have this happen with DHL? SpunkMaster Off-Topic 13 04-12-2010 12:40 PM
weird ECU problem.....anyone else have this happen dan0025 Engine Management & Tuning 4 04-02-2008 06:30 PM
Anyone else have this happen with a utec wrex03 Engine Management & Tuning 7 09-27-2004 04:40 PM
New STI pulls to the left - anyone else have this happen? donmei Brakes, Steering & Suspension 18 05-04-2004 10:58 AM
Dead ABS! Anyone else have this happen? STiShawn General Forum Archive 5 12-14-2000 08:10 AM
