Old 03-03-2008, 09:01 AM   #1
toneloc12345
Member#: 169636
Default Fuel injectors leaking down?
I have a '93 L that I've been driving for about a little over a month. I changed the oil when I first got the car. So the other day I checked it and it read like a quart over?! Before you try to flame me... I know how to read the dipstick, I put the correct amount in when I did it the first time, and I was parked on flat ground.
I smelled the oil and it smelled like it had gas in it to me. So the only thing I can think of is the fuel injectors leaking down into the cylinders and past the rings into the crankcase. The car does have 188k.
Has anyone encountered this problem before? I was looking for a place to check fuel pressure on the lines and I didn't see one.
toneloc12345 is offline   Reply With Quote
Old 03-03-2008, 07:29 PM   #2
subtoy
Member#: 173384
Was the car difficult to start? If so the plugs may have been loaded with fuel.
The only way to check fuel pressure is to put your gauge on the hoses
were they connect to the fuel filter.
subtoy is offline   Reply With Quote
Old 03-04-2008, 08:20 PM   #3
RaceFaceXC
Member#: 165749
2007 No YELLING
on the bus!
gas in the oil could be bad HG, bad rings, cylinder not firing, worn intake valve guides or more. You should do a cylinder compression test so if you have any low cylinders.
RaceFaceXC is offline   Reply With Quote
fuel injector leaking on a ej207 swap? fliped wrx Subaru Conversions 0 06-13-2008 05:25 PM
i need fuel pump and sti pinks injectors bell down pipe have any 4 sale puppet4950 Private 'Wanted' Classifieds 3 11-21-2007 06:41 PM
Urgent: Fuel rail / Injector leak help. tube Factory 2.0L Turbo Powertrain 16 05-01-2007 07:05 AM
Stock 02 WRX Turbo, Intercooler, Fuel Pump, Injectors, Springs, Down Pipe, Mid Pipe JasonLHall NWIC Private Classifieds 24 01-12-2007 10:06 AM
Need rubber wrx fuel injector o-ring or fuel injector Shaitiger Private 'Wanted' Classifieds 2 02-11-2004 09:17 AM
Message Board Statistics All times are GMT -4. The time now is 10:26 AM.
