Welcome to the North American Subaru Impreza Owners Club Friday January 30, 2015
Old 03-03-2008, 06:41 PM   #1
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
Default reset ecu without disconnecting battery
i've searched but havnt found any threads that match here or on romraider.
Is there a way within Enginuity 0.4.1 or EcuFlash to reset the ECU?
id like to reset the ecu without having to disconnect battery terminals.
*flame suit on just in case *
fastnoypi is offline   Reply With Quote
Old 03-03-2008, 07:46 PM   #2
minifreak
Member#: 116914
2006 WRX Wagon
Obsidian Black
Find ECUExplorer, it offers an option to reset your ECU.
But I believe that ECUFlash reset your ECU every time you reflash too? I could be wrong on that.
minifreak is offline   Reply With Quote
Old 03-03-2008, 07:59 PM   #3
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
thanks i'll look into ECUExplorer, is it predomininantly used for logging and similar to the Enginuity logger? .
You're correct that Ecuflash resets everytime a reflash happens but i would rather minimize the reflashes only for touching up maps.
I'd kill myself if i brick the ECU while attempting to reset it by reflashing, when the surefire way is to disconnect the battery terminals.
Old 03-04-2008, 09:19 AM   #4
Tea cups
Member#: 103136
RomRaider test releases also have the ability to reset the ECU.
Tea cups is offline   Reply With Quote
Old 03-04-2008, 09:29 AM   #5
fgummett
Member#: 172732
2006 Impreza N/A
Isn't there a fuse you can pull to achieve this..?
fgummett is offline   Reply With Quote
Old 03-04-2008, 10:25 AM   #6
98EJ20
Member#: 163184
98 Swapped Impreza
Red
I know on my Toyota there is a EFI relay you can pull to quickly reset the ecu, not sure on the Subaru.
98EJ20 is offline   Reply With Quote
Reseting ECU via battery disconnect? tobylazur AccessPort 1 06-05-2008 02:41 AM
How do you Reset the ECU Without Disconnecting Battery zman519 Engine Management & Tuning 9 03-06-2007 10:53 PM
reset ECU, disconnected battery? rally_on General Community 10 01-17-2006 12:26 AM
disconnect battery, but keep power to ECU? bemani Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 04-04-2002 02:00 AM
How to reset ECU without setting off the alarm? toerag Newbies & FAQs 2 01-28-2002 02:16 PM
