#1 |
Member#: 152224
Vehicle:2007 Impreza 2.5i Urban Grey Metallic |
When i went out to start my 2007 2.5i with 8300 miles on it this evening, it wouldnt start or turn over. After pushing it out of my garage and catching it in gear it started up but my CEL came on and my CRUISE light was blinking, the car wouldnt start back up after I shut it off so i had it towed to the local dealership and i am currently waiting to hear from them.
Does anyone have any idea as to what is wrong? Has anyone heard of this before? UPDATE: the dealer said its the clutch switch and it should be done by tommorow
#2 |
Member#: 173384
Does it have a imobilizer system?
If so that me be the problem |
#3 |
Member#: 152224
Not exactly sure it has the factory alarm system, It's BONE STOCK
#4 |
Member#: 160840
NESIC
Vehicle:2007 impreza urban gray scoooped |
Battery
#5 |
Member#: 158794
Vehicle:xxxx wrx silver |
my cruise light is on from a bad o2 sensor.. i highly doubt thats what it is though
#6 |
Member#: 160287
TXIC
Vehicle:2007 Impreza 2.5i SE Newport Pearl Blue |
The cruise control light flashes if the CEL goes off.
If you plug in an OBD-II into it, it will give you a code. You can search for it and it will tell you what it is. Autozone does this for free. As for your problem, I honestly do not know. |
#7 |
Member#: 155430
Vehicle:2008 Nissan SE-R Spec V |
Did you disconnect the battery or mess with any electronics whatsoever? If so, thats the culprit, its no biggie.
#8 |
Member#: 152224
the dealer told me today that it was the clutch switch^^^^
thanks everyone for your suggestions |
#9 | |
Member#: 155430
Whenever i disconnect my battery the car wont start on the first turn after reattaching. I just wait a min then it starts. |
#10 |
Member#: 22664
^not sure but after i saw that done one time and my jaw hit the ground... i realized i woulda never do that to my own car ha
#11 | |
Member#: 155430
"I was gonna say you coulda jacked it from the rear diff, thanks for bending my pinch welds." |
#12 |
Member#: 152224
well... whats so dangerous about it?
#13 |
Member#: 168862
NESIC
Vehicle:2007 ej253n/a 5speed Red Sox Nation Lifer |
8300 i just hit 20k and never had this problem describe it further. you put key in yes. do lights come on? you turn key what happens? do you hear your clutch engaging?
#14 |
Member#: 36629
Vehicle:07 2.5i Regularly Being Modified |
Somehow after disconnect the battery and reconnect, the car is harder to start the very first trial. I noticed that too.
#15 |
Member#: 165749
South East
Vehicle:2007 No YELLING on the bus! |
Yeah, I am pretty sure that has something to do with the ECU controlling fuel and not anything being wrong. After reflashing my ECU, I have to turn the key to on (or crank it over for a second) and then to off and then start it or it wont start on the first attempt. happens to others, seems to be normal.
#16 |
Member#: 152224
well everything happens as it normally would except the car wont start. the dealer said that this is caused by a bad clutch switch... its probally one of those things that goes wrong just by chance.
#17 |
Member#: 165749
South East
so did the clutch switch fix it?
#18 |
Member#: 152224
finally after being without my car for a whole week I got it back yesterday, the clutch switch fixed it and it runs like it never happened
#19 |
Member#: 149764
Vehicle:2007 2.5i OBP |
I always thought it was weird with the cruise light. I had a problem at about 12k with my 07 2.5i, it was overheating while sitting and the cruise light was on. Winds up something happened and I didn't have any coolant, all taken care of by my dealer.
I have been noticing that after braking hard or after driving for a while my light will come on, after turning off and cooling down it will go off though. Kind of sucks because dealer says there is nothing they can do if it isn't on when they are around. |
#20 |
Member#: 22664
soooo why not drive like 30 mins away from the dealer, than back making it an hour trip and tell the dealer you will be doing this so they can come right out when the cars hot and see and hopefully bring it right inside
| Thread Tools | |
| Display Modes | |
| Need Help 06 legacy 2.5i problem | 04-WRX | Mid Atlantic Impreza Club -- MAIC | 9 | 06-04-2010 08:53 AM |
| 2007 2.5i Problem engine cutting out | kruga225 | Impreza Forum | 1 | 02-09-2008 10:05 AM |
| more problems with the 2007 2.5i | rhinh25 | Normally Aspirated Powertrain | 27 | 09-13-2007 02:21 PM |
| 06 2.5i Common Problems? | ScubaruImpreza05 | Impreza Forum | 28 | 06-29-2006 08:09 PM |
| 2.5i Problems | SpaceMonkey0453 | Normally Aspirated Powertrain | 8 | 05-31-2006 12:32 AM |
