Old 03-03-2008, 07:08 PM   #1
yoseph
Member#: 168644
2002 Wrx
World Rally Blue
Default Oil is everywhere
I have recently installed some megan racing, 1 piece up-pipe and header combo. My friend who was helping out with the install jacked up the motor, removed the passenger side motor mount nut and jacked from the oil pan. Oil is everywhere under the car as i learned today, leaking a tiny bit from the filter. But more so, oil is all over the front jacking point, the front sway bar, the oil pan, and some has gotten on the downpipe.
Any thoughts/suggestions are appreciated.
Thanks
yoseph is offline   Reply With Quote
Old 03-03-2008, 07:16 PM   #2
mikeythejew
Member#: 141672
Your should be former friend who wont pay for screwing up your car jacked the engine up from the OIL PAN?
mikeythejew is offline   Reply With Quote
Old 03-03-2008, 09:25 PM   #3
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
Did your friend use a wooden block or something on the oil pan, or just let the jack cradle go on it directly? If the latter, is the oil pan punctured? Did you damage any seals while doing the up-pipe (not uncommon for people to do that) or maybe loosen one of the oil lines to the turbo? You really need to clean the areas, run the engine briefly, then look to see if you can figure out where it's coming from... once it's all over the place, it can be a pain to find the source.
Old 03-04-2008, 07:01 PM   #4
yoseph
Member#: 168644
2002 Wrx
World Rally Blue
DrD... i went down and cleaned everything very, very thoroughly, ran the car for a bit, and shut it off. I went down and the oil seems to be leaking from directly above the cross member area... could this be one of the turbo oil lines?
Last edited by yoseph; 03-04-2008 at 07:04 PM. Reason: i looked from engine bay and saw no signs of oil leaking.
Old 03-04-2008, 09:49 PM   #5
rkramer
Member#: 118209
2015 WRX Limitec
could be either an oil line to the turbo or the gasket around the pan has been broken, although that shouldn't cause much oil leaking, it would seep out in that case.
Old 03-05-2008, 01:19 PM   #6
bannerd
Member#: 110771
2006 WRX
black
Jacking from the oilpan is a big problem, I would think something with the oilpan. Replacing a header is a big job and would be best to remove the entire block from the bay. That's a lot of weight on the oil pan, surprised it didn't crush it.
bannerd is offline   Reply With Quote
HELP!! oil is everywhere!!! ADAS1223 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 37 03-03-2009 07:09 PM
Help! Oil Is Everywhere IceColdRex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 05-12-2006 11:55 AM
Oil going everywhere during change? 409Industries Service & Maintenance 22 05-03-2005 11:59 AM
Oil dripping EVERYWHERE after Up/Downpipe install UGotBoost? Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 03-21-2004 10:55 AM
Water is everywhere, and it's common knowledge that drinking water is important, but I ROBOT Off-Topic 35 12-04-2002 11:33 PM
