Old 03-03-2008, 08:20 PM   #1
02RSBRP
Member#: 159398
Default Fuel Smell
I pulled my spark plugs yesterday to adjust my valve lash. The car had been sitting in the same spot for about 15hrs. When I pulled them, there was still a little bit of fuel on the plugs and you could smell the fuel pretty good.
Is this normal? If not what should I start looking at to find the problem?
02RSBRP is offline   Reply With Quote
Does cold weather + the fuel smell = fuel leak??! thumpetto007 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 12-19-2008 03:50 PM
Fuel smell, followed by pretty nice fuel leak, followed by car is dead sk8er722 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 01-17-2008 10:38 AM
04 WRX OEM Fuel Rail (Good for 02-03 WRX fuel smell TSB fix) Cation Engine/Power/Exhaust 8 07-01-2007 11:50 AM
Has anyone done the fuel rail fix to eliminate the cold weather fuel smell? Snowphun Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 11-01-2005 09:20 AM
Fuel Smell When Cold Out...Fuel Rail/Injectors? DJWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 11-22-2004 04:58 PM
