Old 01-03-2008, 04:25 PM   #1
fasterthanrayswrx
Member#: 48672
2005 Subaru
WRX
Default California spec 2.2 engine?
Hi,
I have a CA spec engine in my 99 Legacy and was wondering what's the difference. The intake is different I see, but what else?
If I were to get an intake would any one work?
Finally does my car have unequal length headers?
fasterthanrayswrx is offline   Reply With Quote
Old 01-03-2008, 05:21 PM   #2
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Your car has an EGR valve. That's mostly it. All the exhaust manifolds are pretty much the same, and they are not EL. You can get an intake and the single port Borla headers...
Old 01-03-2008, 11:31 PM   #3
PhilSine
Member#: 130489
02 WRX Wagon (WRB)
98 OBS-T, 91 Legacy SS
By my observation, the OE exhaust manifold is equal length. At least it is for the single port OBS EJ22. I can't speak for the Legacy's. Keep in mind that you have an exhaust manifold and that is not to be confused with a header.
Headers are higher performance exhaust manifolds that are usually mandrel bent, and much larger than OE. The OE exhaust manifold is about 1 3/8" on the primarues and perhaps less) and 1.5" on the collector where a Borla single port header is 1.75" on the primaries and 2" on the collector.
I'm going from memory on the OE specs but regardless of accuracy, it's safe to say that the OE manifold is small.
PhilSine is offline   Reply With Quote
Old 01-07-2008, 01:59 PM   #4
fasterthanrayswrx
Member#: 48672
2005 Subaru
WRX
okay, that clears things up.
Honestly, I want my car to sound like a WRX. I miss that boxer rumble from my WRX/STi.
Would just getting a muffler/catback do the trick or would I need some sort of exhaust mani to do it? I thought I remember someone mentioning the Borla would do it.
Old 01-07-2008, 03:39 PM   #5
PhilSine
Member#: 130489
02 WRX Wagon (WRB)
You need a manifold to do it.
The boxer rumble comes from an unequal length header.
I am in the process of making a run of Borla replica headers that are stronger but not stainless steel. So, it will rust away in 10 years unless you have it powder coated and then it will last 15 years.
Borla stopped making headers for the single port EJ22 so if you can find a Borla header, it will likely be used or if new, over $500. I'll be charging $300 plus shipping for mine and it will include new exhaust gaskets for both ends. Borlas didn't include gaskets so you'd be saving $25 there. Also, my headers will be 2" on the primaries and 2.5" on the collector.
I have a thread started for interest and from here, it's getting pretty close to production. Hopefully by the end of January but nohting for certain. The hardest part has been getting supplies together, especially Subaru exhaust flanges. That has been a lengthy process and the one that is still holding things up. Now I'm simply waiting on the UPS guy to show with my cylinder heads I bough for my mock-up.
Old 01-25-2008, 09:50 PM   #6
alejo
Member#: 170081
2004 2.5RS
blue
Is it really worth it to spend that much in headers? I mean, is the gain really good in sound and performance? Now, is there any way someone can do it any given sunday?
alejo is offline   Reply With Quote
Old 01-26-2008, 12:56 AM   #7
Calamity Jesus
Member#: 44501
1984 That's *Sir*
Weinerlicks of Douche 2u.
Cali spec cars use a MAP sensor (like the '00-'04) instead of the MAF, IIRC.
Calamity Jesus is online now   Reply With Quote
Old 01-26-2008, 03:02 AM   #8
Subyroo2.5
Member#: 168129
2013 WRX
WRBP
i had a 96 wagon. it was a 5 speed cali version. it had no egr... NoX was taken care of by valve overlap.
Subyroo2.5 is offline   Reply With Quote
Old 03-03-2008, 09:55 PM   #9
alejo
Member#: 170081
2004 2.5RS
blue
does anyone have a picture of a single port header? I still don't understand how can you fit a 2" tube on the primaries? does that mean that the primaries will be right "inside" the headers? any help would be appreciated, thanx a lot
2001 Spec C 2.0 Engine and transmission sparspecker Engine/Power/Exhaust 1 10-24-2009 10:36 PM
Need DOHC 2.5L engine specs for final project t3hWIT Normally Aspirated Powertrain 10 04-27-2008 06:31 PM
i need 2.0 engine specs ktmbass85 Built Motor Discussion 3 12-12-2006 08:43 AM
California spec ECU pinouts? Poppa smurf Normally Aspirated Powertrain 1 03-11-2002 12:06 AM
California Spec. Specs? Revision Technical Forum Archive 10 05-10-2000 10:41 PM
