Old 03-03-2008, 06:27 PM   #1
iRick.
Member#: 158155
Default issues with delta
alright..its been two weeks and they haven't answered my e-mail. so i'm coming here for some help
1. what regrind do i order for the low end/mid end power gain?
2. how much does it cost?
because i'm getting nothing from delta
iRick. is offline   Reply With Quote
Old 03-03-2008, 06:38 PM   #2
SilverSubie2.5
Member#: 136144
2012 WRX Hatch
Ice Silver
Call them. That will be your best bet.
But to try to answer your questions, as far as I know, they both effect the mid/high end of the power band. The differences being just as the names imply; the mild grind will give a little less of a gain, but will run consistently with no other work. The hot grind will give you the best gain possible, but the idle will be a bit "lumpier" and you will have to raise your idle to avoid CEL's and stalling. When I get around to having mine done, I'm going for the hot. I'd rather get everything I can and take my chances with a lumpier idle. As far as price goes, I think it's like $95 per cam.
SilverSubie2.5 is offline   Reply With Quote
Old 03-03-2008, 06:40 PM   #3
iRick.
Member#: 158155
$95 per cam? i never realized it was that cheap. awesome
well i was told the 500 grind or whatever gives a much quicker response off the line aka putting all the power in 2-4k rpms
and the higher grind throws all the power to 4-7k
Old 03-03-2008, 07:10 PM   #4
SUBARU RALLY GUY
Member#: 162046
97 Legacy wagon
just wait and see
never got an e-mail, always best to call sorry you can also pm me here on the forum
I own Delta
Thanks,
Jon
SUBARU RALLY GUY is offline   Reply With Quote
Old 03-03-2008, 07:39 PM   #5
02RSBRP
Member#: 159398
2013 WRX STi
Plasma Blue Pearl
Delta has 2 grinds for use SOHC guys. The 148 grind and the 2000 grind. 148 gives more low end/mid power with no idle problem, while the 2000 grind give mid/upper power. The 2000 grind does cause a lumpy idle and you'll need to adjust the idle speed in the ECU for those or you'll get a CEL or car that will just die. When I got mine done, cost me $203.70. See the attached link for more info on the Delta cams.
http://forums.nasioc.com/forums/show....php?t=1416850
02RSBRP is offline   Reply With Quote
Help with Delta Dash display StiDreams Engine Management & Tuning 4 11-08-2004 11:51 PM
Tuning with Delta Dash on an Ecutek Reflash Tuned Factory 2.0L Turbo Powertrain 12 10-04-2004 08:43 PM
anyone with delta dash? onesillyracer2k2 Tri-State Area Forum 2 09-07-2003 12:51 PM
Knock signal at idle with Delta Dash maugustine Factory 2.0L Turbo Powertrain 17 09-05-2002 02:18 PM
A/F with Delta Dash mynew02 Factory 2.0L Turbo Powertrain 25 06-05-2002 12:10 AM
Message Board Statistics All times are GMT -4. The time now is 08:53 PM.
