Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 03-04-2008, 04:30 AM   #1
benw
Member#: 103320
1998 swapped
Forester L
Default wastegate corrections... how does the math work?
I've always been terrible at math, can someone help me out?
if the current wastegate duty is 50%, and the IAT compensation cell being used is say, -10%, will the current applied wgdc be 40% or will it be 45%?
Basically, is it a percentage of a percentage, or a subtraction of one percentage from another?
Hope this makes sense. I couldn't make heads or tails from the Enginuity oops ROMRAIDER definition.
Thanks,
BW
benw is offline   Reply With Quote
Old 03-04-2008, 05:58 AM   #2
Broxma
Member#: 158006
2003 WRX IdleWagon
1992 GVR4 379/1000
This post about the GMBCS and WGDC's has about the best explanation your going to get.
http://forums.nasioc.com/forums/show....php?t=1445774
/Brox
Broxma is offline   Reply With Quote
Old 03-04-2008, 08:12 AM   #3
Tea cups
Member#: 103136
Thanks,
BW
It is a relative percentage, so it would be 45%. This is clearly spelled out in RomRaider with the label "Wastegate Duty Compensation (% relative)" -> make sure you are always using the latest ECU defs.
Tea cups is offline   Reply With Quote
Old 03-07-2008, 03:43 PM   #4
benw
Member#: 103320
1998 swapped
Forester L
I'm am and have always used the latest definitions. But do you not see where I am coming from? The description along with the fact that two percentages are being used together, is a bit confusing. Common sense told me that 50% WGDC less 10% would equal 40%. Same units, subtracted. I'm glad I asked though, thanks for the clarification.
Old 03-07-2008, 04:00 PM   #5
Tea cups
Member#: 103136
the label would indicate "% absolute" if that were the case (as is with the turbo dynamics corrections).
Old 03-08-2008, 02:05 AM   #6
benw
Member#: 103320
1998 swapped
Forester L
I see what you mean now, after you explained it. Part of learning Enginuity/RomRaider is learning how to speak to language.
how does the ranking work here? elmst Newbies & FAQs 3 10-15-2007 01:16 AM
OT--how does the wheel work? Physics Junkie Off-Topic 7 12-14-2005 01:01 AM
How does the antilag work on the Hydra? Crazykev Other Engine Management 2 10-15-2005 07:11 PM
How does the AWD work with one front wheel off and one rear wheel off? crash Transmission (AT/MT) & Driveline 6 02-06-2003 06:34 PM
OT: How does the VDC work? Bahumut Technical Forum Archive 7 07-31-2000 06:21 PM
