Old 03-04-2008, 09:06 AM   #1
Tequila Sunrise
Member#: 173545
2004 Forester XT
obsidian
Question Can I put synthetic oil in my turbo Subaru?
My Forester has 45,000 miles and is out of warranty. I would like to switch to synthetic so that I don't need to change the oil as often, and hopefully, get more miles out of my car.
The service manager at my Subaru dealer told me that I can't put synthetic in the turbo. Is this correct?
Tequila Sunrise is offline   Reply With Quote
Old 03-04-2008, 09:27 AM   #2
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
yes you can change to synthetic
Check the Oil FAQ for recommendations - in particular the appropriate viscosity range for your climate + type of driving
Not all synthetics are equal - if you want to start extending your oil change interval (OCI) then it's best to have a used oil analysis done after your 1st synthetic change to determine that your wear / dilution / shear are within acceptable limits and recommend a suitable OCI for you / that brand.
UkNuck is offline   Reply With Quote
Old 03-04-2008, 09:27 AM   #3
bluesubie
Member#: 767
04 FXT
Check the Maintenance FAQ sticky. Do you have an owner's manual? If so, check the synthetic oil info and then show it to your service manager. Then check the New England forum to find another dealer.
Do not assume that you can go longer intervals with synthetics. It depends on the viscosity you use, driving conditions, oil change interval, oil High Temp High Shear, etc. All synthetics are not created equal.
Also a used oil analysis will tell you how long you can run an oil. http://www.blackstone-labs.com/
edit: Nearly the same advice posted at the same time. And welcome to nasioc. Also check out subaruforester.org
-Dennis
Old 03-04-2008, 10:29 AM   #4
Tequila Sunrise
Member#: 173545
2004 Forester XT
obsidian
Thanks for the links. Seems I'll be changing my oil ~ every 3,000 miles no matter what. It is very convenient at my local Subaru dealer because for me to remove the brush pan underneath is a PITA. Plus, they do it for $19.99.
Old 03-04-2008, 10:40 AM   #5
Mesatchornug
Member#: 78292
2002 PSM Impreza RS
Red '99 Ducati ST
it won't be $19.99 for synth. unless you mean $19.99+oil...
Mesatchornug is offline   Reply With Quote
Old 03-04-2008, 10:45 AM   #6
Kean
Member#: 25187
'08 Foz Prem TGM
'10 Challenger R/T Blk
.....or use UOA's as Dennis recommended so you know what interval works best for your application.
Kean is offline   Reply With Quote
Old 03-04-2008, 11:31 AM   #7
silver-duck
Member#: 130710
I would not let that service manager near my car; he is a moron or a con man.
silver-duck is offline   Reply With Quote
Old 03-04-2008, 03:41 PM   #8
drivin blind
Member#: 73043
2011 STI/2010 370Z
Black/Black Cherry
Just use a dremel tool and cut out a square large enough to get your hand onto your filter. Problem with pan cured. RP
drivin blind is offline   Reply With Quote
Old 02-19-2009, 07:12 PM   #9
Mike Wevrick
RIP 1/19/64 - 7/23/11
Member#: 24654
1957 Taggart Comet
atlasshruggedpart1.com
Subaru is now recommending 3750 for all new turbo Subarus. (used to be 7500 for light duty and 3750 for severe). They also say that synthetic is OK but to use the same change intervals. IMO 3000 is a waste unless you really beat on your car. I am doing every 4000 or so.
edit: Take whatever your dealer says with a grain of salt. Sometimes they know what they are talking about, sometimes they don't.
Mike Wevrick is offline   Reply With Quote
Old 02-20-2009, 02:00 PM   #10
AndyH
Member#: 2133
2005 STi WRB/Gold
2005 S4 Avant
I've gone as long as 6,883 miles on Castrol Syntec 0W-30 in my '05 STi with very good results:
Generally speaking, I'm trying to stick closer to a 5,000 OCI mostly just because it's easier to remember and track.
AndyH is offline   Reply With Quote
Old 02-21-2009, 12:47 PM   #11
loyolacub68
Member#: 151745
Make the switch now and change every 4-5k.
loyolacub68 is offline   Reply With Quote
Old 02-21-2009, 02:02 PM   #12
bluesubie
Member#: 767
04 FXT
Was this a birthday bump?
Original post - 03-04-2008, 09:06 AM
-Dennis
I put a hole in my turbo inlet hose! MF-DIF Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 38 01-06-2007 06:06 PM
I put synthetic oil in my Outback planehpn Service & Maintenance 10 10-01-2002 11:13 AM
('93-'01) Synthetic Oil in my RS since she was a baby archer Impreza Forum 5 09-07-2002 09:01 PM
can I put 89 octane in my wrx? putanginamo Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 47 08-28-2002 11:49 AM
Can I use synthetic oil while breaking in my engine? Tim K. Technical Forum Archive 11 05-26-2000 11:31 AM
