Old 03-04-2008, 02:02 PM   #1
Timmay81
Member#: 161575
2002 Wagon
Default Airbag light
so i noticed yesterday that my airbag light is on.. i havent changed anything on my car, unplugged or taken anything out
i tried to undo the battery for a bit and that didnt help.. is there a way to reset or check this?
Thanks
Timmay81 is offline   Reply With Quote
Old 03-04-2008, 03:22 PM   #2
jdubya301
Member#: 139076
2002 stg2 wagon
03 suzuki sv650s
hmmm i wish i could help, but my buddy had an airbag light come on in his car one time, and about 2 hours later the airbag deployed while driving, causing an accident.
i would take it directly to the dealer, unless someone else has any suggestions
jdubya301 is offline   Reply With Quote
Old 03-04-2008, 04:23 PM   #3
fgummett
Member#: 172732
2006 Impreza N/A
I think it means the that the airbag system needs servicing... check with your dealer. Assuming you mean the red light in the instrument cluster and not the 2 stage light for the passenger airbag?
fgummett is offline   Reply With Quote
Old 03-04-2008, 04:32 PM   #4
Timmay81
Member#: 161575
2002 Wagon
yea red airbag light on my cluster
Old 03-04-2008, 04:50 PM   #5
stimko68
Member#: 85396
2007 STI
Obsidian Black Pearl
Take it to the dealer - that indicates a malfunction in the airbag system.
stimko68 is offline   Reply With Quote
Old 03-04-2008, 06:24 PM   #6
jdubya301
Member#: 139076
2002 stg2 wagon
03 suzuki sv650s
+1 get it there asap
Old 03-04-2008, 06:27 PM   #7
Peaty
Techno Sapien
Member#: 449
2010 Legacy 3.6R Lim
Azurite Blue Pearl
Something worth trying. It's not uncommon for the plug under the seat to get corroded and loose contact. First thing to try is to unplug and plug it back in. That alone might help. Happened to a lot of people including myself not too long ago.
This TSB is for the Forester but I've seen it happen in other scoobies too:
http://www.scoobymods.com/forums/showthread.php?t=4110
Peaty is offline   Reply With Quote
Old 03-04-2008, 07:10 PM   #8
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
You could have a dealer check it but you're most likely out of warranty, so they'll charge you for the diagnostic time as well as the repair. OTOH it may not be something you can repair on your own anyway.
There is a diagnostic procedure you can follow in the service manual, which involves connecting the diagnostic plugs and watching the flashes of the airbag light to get the code. This can point you to the cause.
Old 03-04-2008, 07:27 PM   #9
jryan87
Member#: 130797
2007 WRX TR
01 Leg GT DD
I would try this first. I would definitly disconnect the battery first and let the car sit for s few minutes before you unplug anything. never unplug any srs connectors with the battery connected, It can cause the airbag to deploy
jryan87 is offline   Reply With Quote
Old 03-04-2008, 07:37 PM   #10
Timmay81
Member#: 161575
2002 Wagon
i have warranty its going in tomorrow
Old 03-04-2008, 07:40 PM   #11
jetskibucky
Member#: 136694
07 STI LimitD #242
SPW Stage 2+
Someone with a service manual, tell us how to put the SRS system into service mode. I know how to do it with an Infinity, not Subaru
jetskibucky is offline   Reply With Quote
Old 03-04-2008, 09:37 PM   #12
Peaty
Techno Sapien
Member#: 449
Azurite Blue Pearl
if you go here
www.endwrench.com
and search SRS in the archives you can get info on how to get it into service mode.
Old 03-05-2008, 11:18 AM   #13
Timmay81
Member#: 161575
2002 Wagon
well i got bored so i un did the batterys and messed with the plugs under the seats and wa la.. no more light
im thinking something under my seat may of bumped one of those cables and maybe it wasnt getting a good connection
Airbag light is on, aftermarket seats, 4 airbag cords? subierider Interior & Exterior Modification 7 10-26-2008 06:00 PM
Replacing airbag OE seats - airbag light on? fpan Interior & Exterior Modification 4 10-19-2008 11:06 PM
Airbag light having nothing to do with airbags? coloradosti Interior & Exterior Modification 2 06-27-2004 06:02 PM
('93-'01) airbag light on? ferretboy Impreza Forum 3 05-29-2001 11:39 PM
