Old 03-04-2008, 03:10 PM   #1
plugged.in
Member#: 112354
Default 99rs wont run with MAF
I have a CAI (by the way) into MRT EL headers, and sti exhaust
only mods.
This morning, after i enter onto the whitemud from 159st, I change lanes from middle to left. While doing so I stepped on pedal to make my vaginamatic shift down and speed up. It certainly did shift down. but morelike a dirtbike shifts down into 1st while going down a steep hill. The car slowly went from ~4kpm down to 1, then I came to a stop and the car ishtay off.
I was in the shoulder*ish part of the left lane on the whitemud in between the 2 overpasses.
Car would not stay running for +2 seconds. It will start, idle at 1000 rpm, then die.
I called AMA, and papa bear, they concluded that the car didnt think it was getting air (but you CAN give the car gas...)
So we unplugged the MAF and the car runs in limp mode. WITH [AT OIL TEMP] light CONSTANTLY flashing
Drove home, changed out the MAF to one the dealer gave me on a recall (the dealer installed the new one a while back but the car would stay running, so they just put the old back in and gave me the new one for keeps) and i get the same problem.
I'm not sure if it's a faulty MAF (the new one) or what. I'll go try to exchange for a different one today.
The codes I'm triggering are:
P0170 (Front o2, needs replacing)
and
P0420 (emissions)
any ideas?
plugged.in is offline   Reply With Quote
Old 03-04-2008, 03:34 PM   #2
plugged.in
Member#: 112354
Now car won't run without MAF
and I get this code:
P0102 Mass air flow sensor circuit low input
Old 03-04-2008, 07:58 PM   #3
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
So it ran without the MAF at first but now it wont run without the MAF at all?
maybe the o2 sensor actually is bad and just by coincidence went bad after doing those mods? Try putting anything you changed back to stock? if that doesnt help, id try a new O2 sensor and see what that does. Did this happen just after doing these mods? (intake, headers)
Old 03-04-2008, 08:33 PM   #4
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
You putting oil on your cai filter?
Tim Sanderson is offline   Reply With Quote
Old 03-04-2008, 08:52 PM   #5
subaru222
Member#: 92967
2009 wrx hatch
dark grey metallic
how long have you had the intake on for .?
subaru222 is offline   Reply With Quote
Old 03-05-2008, 12:21 AM   #6
plugged.in
Member#: 112354
I've had the intake on since, october? headers around the same time.
started getting the o2 code about 2 months ago.
been putting it off (i know, i know, stupid...) on the replacement
i haven't been putting oil on the filter no.
and it IS pretty dirty. cleaned today.
Old 03-05-2008, 12:23 AM   #7
plugged.in
Member#: 112354
it takes serious revving to warm the car up to keep it running.
runs in limp mode now without MAF
Its parked (obviously) until i can fix it.
Old 03-05-2008, 02:57 AM   #8
plugged.in
Member#: 112354
99rs btw
Old 03-05-2008, 12:08 PM   #9
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
you're getting an O2 sensor CEl....maybe you should heed the warning and replace it.
Old 03-05-2008, 12:35 PM   #10
plugged.in
Member#: 112354
doing so, tomrorrow.
after I do that, should I reset ecu then try starting car?
Old 03-05-2008, 06:51 PM   #11
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
id try starting it without a ecu reset first.. if it doesnt work, try a reset but a reset shouldn't be necessary to get it running normally.
Old 03-05-2008, 11:29 PM   #12
silentt
Member#: 119995
2004 Outback XT
Peachy
A pooched O2 sensor will just cause the car to run in open loop and limp mode, it shouldn't have that effect on the car.
silentt is offline   Reply With Quote
Old 03-05-2008, 11:36 PM   #13
subaru222
Member#: 92967
2009 wrx hatch
dark grey metallic
yes reset it.
Old 03-05-2008, 11:53 PM   #14
xilles
Member#: 147056
clean the maf with connection cleaner real good
inspect that pcv valve if clogged
replace front o2 sensor(couldve got fouled up bc of the header)
no need to reset ecu but helps, if you reset the ecu it will clear the code and all other learned driving habits, if you replace that o2 sensor without reseting let it run for an hour or 2.
personally i had same problem.mine wouldnt start or go above 4ks mine ended up being both maf and o2. replaced both without reseting ecu drove it around the block a few times actually 12 miles shutting down and restarting the car every so often miles and cel went away...
ps i do have a 07sti and a ej20-ed 99rs.
xilles is offline   Reply With Quote
Old 03-06-2008, 09:15 AM   #15
Boxer4Dad
Member#: 137226
2005 Saabaru 2.5i
OBP, or Black
If you've had the MAF out, make sure you didn't put it back in backwards. You can get this code if you do that, too. Just something I've heard....
Boxer4Dad is offline   Reply With Quote
Old 03-07-2008, 10:48 AM   #16
silentt
Member#: 119995
2004 Outback XT
Peachy
I'll check on that for him tonight. If that's the case, I am going to slap him
Old 03-07-2008, 01:20 PM   #17
plugged.in
Member#: 112354
that'snot the case.
i dont even think the maf FITS backwards...
Old 03-10-2008, 02:04 AM   #18
plugged.in
Member#: 112354
dealer gave me a faulty MAF...
Old 03-10-2008, 07:00 PM   #19
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
sucks. what are they going to do for all the wasted time and inconvenience?
Old 03-12-2008, 08:37 PM   #20
plugged.in
Member#: 112354
nothing.
they said they didn't install it, so they won't warranty it.
They actually DID install it, but took it out because they couldnt get my car to start with it (defective sensor sounds like the first thing that would pop into my head...) and they handed it to me, threw the old one back in
Bugeye Wont Start With Maf??? quikcobra Engine Management & Tuning 6 08-06-2011 04:52 PM
Car wont run with Utec... :( Rextion UTEC 14 09-02-2009 11:36 PM
Urgent help needed: Car will not run with MAF plugged in. Carter Alaskan Impreza Club Forum -- AKIC 11 02-25-2009 09:49 PM
Need urgent help: Car will not run with MAF plugged in. Carter Normally Aspirated Powertrain 10 02-25-2009 09:47 PM
Car wont run with BOV installed 03WRXMA New England Impreza Club Forum -- NESIC 11 07-07-2004 04:32 PM
