Old 03-04-2008, 03:47 PM   #1
sonycrr
Member#: 128161
2006 wrx limited
wrb
Default transmission and front/rear differential oil
went in to get 30k servicing and on my reciept is says 4qts gear oil.
i called the dealer and they said this was used for the transmission and front/rear differential since they use the same oil..
is this correct?
thanks for the info
sonycrr is offline   Reply With Quote
Old 03-04-2008, 04:10 PM   #2
bluesubie
Member#: 767
04 FXT
2006 WRX? Yes, it's the same.
-Dennis
Old 03-04-2008, 04:19 PM   #3
rallymaniac
Member#: 52189
2006 MINIiiiiii
is this correct?
thanks for the info
So how much did they rip you off for on this 30k mile service ?
rallymaniac is offline   Reply With Quote
Old 03-04-2008, 04:24 PM   #4
sonycrr
Member#: 128161
2006 wrx limited
wrb
the price was about 580 including tax for everything i did there.
i didnt do oil change or replace the air filter ( i have a spt intake) and i got a boost gauge installed ( they charged 1 hr labor 94$). i also got new windsheild wipers
i had a 15% off coupon for the 30k servicing.
so 580 total price.
Old 03-04-2008, 04:25 PM   #5
sonycrr
Member#: 128161
2006 wrx limited
wrb
thanks for the info bluesubie!
Old 03-04-2008, 04:44 PM   #6
WRXSleeper
Member#: 43853
2004 WRX Sedan Stg 2
Platinum Silver
so 580 total price.
I hope they didn't charge you for the wipers. They are covered under your 3yr 36K warranty.
Sounds like a huge ripoff either way.
WRXSleeper is offline   Reply With Quote
Old 03-04-2008, 04:49 PM   #7
sonycrr
Member#: 128161
2006 wrx limited
wrb
they did charge me for wipers...its supopse to be included? wack!
Old 03-04-2008, 05:15 PM   #8
rallymaniac
Member#: 52189
2006 MINIiiiiii
so 580 total price.
ouch, what a ripp off...
Old 03-05-2008, 02:53 PM   #9
SubieRon
Member#: 64485
2004 GGA
$580 daymn!
you live and hopefully...u learn
SubieRon is offline   Reply With Quote
Questions about Engine Oil and Rear differential Oil minx1225 Newbies & FAQs 9 09-27-2005 02:50 PM
Just changed my rear differential oil and noticed it was overfilled volkl23 Transmission (AT/MT) & Driveline 10 04-13-2005 04:09 PM
Rear differential oil fill and drain bolts, same size as the oil drain plug? scooterforever Transmission (AT/MT) & Driveline 4 01-24-2005 06:06 PM
brake fluid, gear oil, rear differential oil? MavWRX Service & Maintenance 6 11-11-2004 04:17 PM
