Mid Atlantic Impreza Club
Old 03-04-2008, 05:24 PM   #1
Adictwrx
Member#: 147668
Default Injector issues.
OK, so after having my 02 wrx out of commission for about 6 months now due to a fire from a leaky injector (sti 565 pink) I have acquired most/all of what I need to put it back together, including a new engine wiring harness that got toasted. So this is my delima; with all that happened I ended up having to take the intake manifold off, and though that Ill just get TGV deletes (got them) and Aps inlet (got it).Once I got those things assembled and put back on the manifold I noticed that after I bolted the fuel rail on and seated the new injectors and o-rings I have some up-and-down play on the injectors in between the fuel pipe and the injector location of the TGV assembly. It only moves about.. a quarter inch tho. Im not sure if this is normal on the WRXs/STIs or not? I know that you can turn them a little in a circular motion (most all injectors do that), I just dont want to have another catastrophe again... Car Fires suck.. I would appreciate some insight to my delima.
-Thanks
Adictwrx is offline   Reply With Quote
Old 03-05-2008, 08:25 AM   #2
Rippen Griffen
Member#: 91708
AD Motorsports FTW
06 OBP - Cobb AP Stg 2
Bump for my buddy Rodger
Rippen Griffen is offline   Reply With Quote
Old 03-05-2008, 09:13 AM   #3
AWD4BANGER
Member#: 166848
05 sti
When I installed mine on my other wrx, the instruction were to push them up into the fuel rail. The movement will decrease with pressure. I was also told to connect the green connector under the dash. This will fire the fuel pump and you can tell if you have a leak before you crank it. Hope this helps.
AWD4BANGER is offline   Reply With Quote
Old 03-05-2008, 10:07 AM   #4
nhat
Member#: 140163
03 STi
hellaflunctional
both of yous need to set your region/chapter info!
good luck!
Old 03-05-2008, 08:51 PM   #5
Adictwrx
Member#: 147668
Thanks guys... I need the luck lol.
Oh and Adam, I hope I can make it out to the install meet, work is my only issue. I wanna check out whats happenin out there!
Injector issue DreamEvil Engine Management & Tuning 1 01-03-2010 02:59 PM
Modified Blue Injectors - Issue BlackEyeBugEye Open Source Reflashes 17 07-30-2008 10:37 PM
02 wrx hesitation/ poss fueling/injector issue? 95lwrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 04-19-2008 08:56 PM
Injector + Turbo Install Issues Help Me Out Milwaukee MustGoFast Mid West Subaru Owners Club Forum -- MWSOC 26 10-15-2003 05:49 PM
Sti Injector issue please help WRC WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 03-01-2003 12:45 PM
