Old 03-05-2008, 12:45 AM   #1
91turbosedaan
Member#: 135144
1991 legacy turbo
white
Cool will ej22 or ej22t heads fit on my ej18 motor?
Hi
So im doing head gaskets on my ej18 motor. and i have a set of ej22t and ej22 heads siting around. Will these fit will they raise the compression raito or lower it? and will i need to use a differnt intake mainifold.
91turbosedaan is offline   Reply With Quote
Old 03-05-2008, 01:03 AM   #2
imprexaRS03
Member#: 145883
2008 wrx
psm
im pritty sure it will change the compression ratio.im not sure up or down but it will change.
imprexaRS03 is offline   Reply With Quote
Old 03-05-2008, 01:36 AM   #3
stickfiguredanny
Member#: 60408
1995 Impreza L
SeaFoam green i think
it will go down just add a turbo to make it go up again
stickfiguredanny is offline   Reply With Quote
Old 03-05-2008, 02:38 AM   #4
91turbosedaan
Member#: 135144
1991 legacy turbo
white
do i need to change intake mainifolds to make it work
Old 03-05-2008, 07:08 AM   #5
Storm
Member#: 5218
96L Most Over-
Developed Beater
Yes, they will fit. No you don't need to change manifolds. Compression may change a little bit. How much of a change depends on the volume of the combustion chambers.
Jay Storm
Old 03-06-2008, 01:42 AM   #6
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
If you use the stock bottom end and the non-turbo ej22 heads w/ stock head gasket you will drop down to about a 8.08:1 with the solid lifter heads(which come at or around 95' IIRC). With the 90-94 heads you get about 8.2:1. Very boost friendly.
~Josh~
will stock 04 wrx airbox fit on my 02 subywrxtuner6969 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 08-24-2006 03:18 PM
will an 03 H brace fit on my Sti? subaru222 Brakes, Steering & Suspension 1 11-23-2005 01:15 PM
Q: Will WRX or RS brakes fit on a v7 sti front hub. subenick Brakes, Steering & Suspension 2 11-09-2005 07:24 PM
Will a 2004+ sti Steeringwheel Fit on my '02 WRX CrowbarKen Interior & Exterior Modification 3 07-18-2005 03:09 PM
Will the WRX turbo back fit on a GC8 motor swap? suberboy Normally Aspirated with bolt-on Forced Induction Powertrain 13 04-20-2002 11:23 AM
