Old 03-05-2008, 01:50 AM   #1
Strng1dah
Member#: 7053
[email protected]
Default Switching from UTEC, Log for 02 WRX, a few questions...
2002 WRX stock 2.0
Mods -
VF39
Sti Uppipe
pink injectors
walbro fp
Cobb catted DP
Sti cat back
TXS TMIC
GMBCS
k&n drop in
91 oct
Just began dialing in this reflash because my UTEC (totally out of the loop now) decided it no longer wanted to communicate with me (i think the serial connector came loose on the board).
My main question is around the AFRs. They look like they are going off of my Hi-Det map, as they flatline at 10:1, just like that map does, however IAM never drops below 16 during the run, and the fuel map switch value is set at 4. My MAF scaling is untouched, as I have the stock intake setup (except k&n), and the injectors are scaled to 550 with the normal latency values.
The knock correction timing map is set to 9.84 across the board, and it looks like there may be some knock in the midrange which I need to figure out.
The WG values are set to try and limit spiking at the moment, and I'll play around with them some more to help improve spool once I figure out the knock and AFR situation.
One thing I am having a hard time figuring out is when the B maps (fuel, timing, etc) are used.
Code:
RPM	MRP	g/s	2*g/rev	IAM	KC	IGN	IDC	AFR
2066	0.29	37.60	2.18	16	9.5	24.5	9.26	14.13
2096	0.87	36.62	2.06	16	9.5	25.5	10.93	19.57
2143	1.45	38.26	2.11	16	9.5	26.0	11.62	12.63
2196	1.89	40.12	2.14	16	9.5	26.0	12.33	12.74
2259	2.32	43.00	2.19	16	9.5	26.0	12.55	12.74
2297	2.76	45.12	2.30	16	9.5	26.0	13.00	12.50
2353	3.19	47.50	2.35	16	9.5	26.0	14.14	12.32
2422	3.63	48.56	2.41	16	9.5	26.0	14.46	12.20
2476	4.06	50.99	2.47	16	9.5	26.5	15.32	12.23
2543	4.50	54.82	2.59	16	9.5	26.0	16.28	12.11
2582	4.93	56.63	2.63	16	9.5	26.0	16.52	12.05
2672	5.51	60.30	2.71	16	9.5	25.5	17.67	12.13
2733	6.09	66.44	2.92	16	9.5	25.0	19.24	12.07
2804	6.67	70.46	3.01	16	9.5	24.5	20.34	12.01
2870	7.55	75.97	3.18	16	9.5	23.5	22.04	11.66
2971	8.42	82.00	3.31	16	9.5	22.5	24.72	11.57
2996	9.29	88.35	3.47	16	9.5	20.0	26.73	11.35
3093	10.45	99.44	3.65	16	9.5	19.5	30.08	10.94
3198	12.04	110.47	4.05	16	7.5	16.0	34.14	10.73
3265	14.07	121.99	4.47	16	7.5	14.0	38.30	10.45
3368	16.54	141.32	4.82	16	7.5	12.5	45.02	9.79
3477	19.01	150.87	5.21	16	7.5	11.0	51.18	9.53
3590	20.89	156.82	5.24	16	7.5	10.5	53.61	9.56
3716	21.91	161.76	5.22	16	7.5	10.5	56.29	9.73
3818	20.89	161.76	5.08	16	7.5	10.5	56.21	9.86
3922	20.75	158.76	4.86	16	7.5	11.5	54.39	10.01
4036	20.17	165.76	4.93	16	7.5	11.5	57.70	9.98
4185	19.59	166.75	4.78	16	7.5	12.0	58.03	10.00
4264	19.44	175.55	4.94	16	8.5	13.0	60.03	10.11
4376	20.02	189.14	5.19	16	8.5	12.5	64.41	10.13
4462	20.17	193.59	5.08	16	8.5	12.5	66.03	9.97
4593	20.31	196.18	5.13	16	8.5	12.5	67.61	9.82
4705	19.88	201.93	5.15	16	8.5	13.0	68.25	9.79
4832	19.73	205.00	5.09	16	8.5	13.0	70.10	9.80
4876	19.59	213.73	5.20	16	8.5	13.5	72.63	9.95
5006	19.44	215.32	5.16	16	8.5	13.5	73.70	9.85
5088	19.44	229.94	5.20	16	8.5	13.5	77.70	9.73
5267	19.44	232.50	5.30	16	8.5	13.0	79.77	9.78
5326	19.59	238.48	5.37	16	8.5	13.0	80.68	9.73
5423	19.44	242.79	5.37	16	8.5	13.5	82.14	9.69
5560	19.44	243.68	5.26	16	9.5	14.0	83.02	9.72
5643	19.30	254.86	5.42	16	9.5	15.0	85.47	9.80
5778	19.59	249.49	5.18	16	9.5	15.5	85.05	9.63
5854	19.15	253.51	5.20	16	9.5	15.5	86.18	9.73
5952	19.01	254.86	5.12	16	9.5	15.5	86.46	9.69
6034	18.86	254.41	5.06	16	9.5	16.0	86.24	9.73
6142	19.01	258.54	5.05	16	9.5	16.0	87.79	9.72
6255	18.86	259.01	4.97	16	9.5	18.5	88.07	9.64
6378	19.01	261.35	4.92	16	9.5	19.5	89.80	9.67
6388	18.57	261.82	4.92	16	9.5	20.0	88.58	9.69
6562	19.01	254.41	4.65	16	9.5	21.0	86.79	9.69
6567	18.72	259.47	4.74	16	9.5	21.0	88.26	9.72
6678	18.72	261.82	4.64	16	9.5	21.5	88.57	9.72
6708	9.00	158.18	2.83	16	9.5	27.5	31.48	10.20
Credit - I based my map on one ride5000 posted a while ago.
Strng1dah is offline   Reply With Quote
TurboXS UTEC for 02+ WRX with Remote Map Switch pjcoregon Private 'For Sale' Classifieds 6 09-07-2005 03:12 PM
Utec log for new tune... jstbstn Engine Management & Tuning 10 11-28-2004 08:24 AM
WTB passenger side window switch for 02 WRX djerickd Private 'Wanted' Classifieds 2 08-27-2004 01:01 AM
JUST GOT MY 02 WRX TODAY! Few questions... WRXTACY Newbies & FAQs 9 02-26-2002 09:01 PM
