Old 03-05-2008, 11:06 AM   #1
Destined2race
Member#: 160344
2002 WRX "Hatch"
Default Spark Plug HP loss help??
Hey i changed my spark plugs last night(wow its a challenge, not like hondas), I replaced them with the same NGK R's (they didnt have coppers), and this morning i noticed the car seemed to have less pull? Is this something that will get better as the spark plugs get wore in a lil bit? Everything was tight, so shouldnt be an install issue. I gapped them to .32 like it said? ANy help would be great. Im going on the dyno next week so i need to get my car in perfect running condition. Thanks
Destined2race is offline   Reply With Quote
Old 03-05-2008, 11:35 AM   #2
98EJ20
Member#: 163184
98 Swapped Impreza
Red
What mods do you have?
I have stg2 plus a lil and I run .28 gap.
98EJ20 is offline   Reply With Quote
Old 03-05-2008, 01:08 PM   #3
Super_HKS
Member#: 154434
2009 WRX Hatch <@_@>
I havent even changed my spark plugs. THX for the reminder. Honestly though ya the civics spark plugs are a breeze to change. Anyways post the dyno # and well c if your laggin or up there
Super_HKS is offline   Reply With Quote
Old 03-05-2008, 01:16 PM   #4
Destined2race
Member#: 160344
2002 WRX "Hatch"
i have an APS tbe and a SPT short ram, but i had the same plugs and gap, and i noticed in instant lag when i punched it... it seemed like boost was going fine, maybe just not enough spark or sumn (since it happened after changing the plugs, obviously the culprit is the plugs ) Ill post the dyno numbers, but i dont wanna drive to chicago(200miles) to have problems or get a crappy pull... Thanks anymore ideas?
Old 03-05-2008, 01:43 PM   #5
98EJ20
Member#: 163184
98 Swapped Impreza
Red
Try closing the gap a lil. Try .030 or .028.
Old 03-05-2008, 02:20 PM   #6
Ike83
Member#: 161681
2004 WRX
Yeah...I'm not sure where you got .032 from.
I've always heard it was .030, which is what I gapped mine to when I did 'em over the weekend (coppers). Car runs fantastic now with the upgrade from platinums to coppers. Definitely back the gap back down to .030 and then see what happens....I bet it'll run much smoother.
Ike83 is offline   Reply With Quote
Old 03-05-2008, 02:23 PM   #7
Destined2race
Member#: 160344
2002 WRX "Hatch"
ok, but i dont understand why it would change at all... it ran fine with the same exact plugs at .32(wrx recommended gap), then i changed and now its lacking power. DAMNIT, why does nothing ever go right???????
Old 03-05-2008, 02:26 PM   #8
98EJ20
Member#: 163184
98 Swapped Impreza
Red
IIRC, bigger gap is a hotter spark but on a FI car it can be blown out. I remember reading that stock WRX gap is .028. I know they suck to remove, but try closing the gap up.
Old 03-05-2008, 03:07 PM   #9
Ike83
Member#: 161681
2004 WRX
Is there such a thing as getting ahold of a bad plug?
Old 03-05-2008, 03:27 PM   #10
98EJ20
Member#: 163184
98 Swapped Impreza
Red
I guess it's possible.
Maybe 1 isnt all the way tight? You need to seat that washer then tighten the plug, maybe its not totally sealed on one of them...idk....
Old 03-05-2008, 03:41 PM   #11
Ike83
Member#: 161681
2004 WRX
Weird....
Old 03-05-2008, 04:48 PM   #12
Destined2race
Member#: 160344
2002 WRX "Hatch"
well i went to autozone, and in there computer they said it shows at .032... i dont know, i talked to the guy at P&L and he said give it 48 hrs and it could correct itself from the battery being disconnected. Thanks guys for the input
Old 03-05-2008, 06:06 PM   #13
98EJ20
Member#: 163184
98 Swapped Impreza
Red
the partsamerica site shows .030.
Old 03-05-2008, 08:09 PM   #14
Arctic Penguin
Member#: 119532
2006 WRX
the gap is listed as 0.7mm - 0.8mm in the fsm
if you 'gapped' the plugs wrong and it is REAL easy to kill these plugs
then that may be an issue
also if you disconnected the battery then the ecu has reset and must relearn
Arctic Penguin is offline   Reply With Quote
Old 03-05-2008, 08:58 PM   #15
Destined2race
Member#: 160344
2002 WRX "Hatch"
that seems awfully far off from what everyone elses saying... and i was told. Anyways when i left work today i drove about 35 minutes, being easy on it and trying to let "break in". WHen i got to my street i slowed down in first and punched it.... it pulled hard and smooth so maybe it is the ecu relearning. Ill keep monitoring it though. I did remove the battery for a while so that couldve been the reset. Thanks for the help
Old 03-05-2008, 09:27 PM   #16
skydes
Member#: 141347
2005 WRX
Did you unplug the negative battery terminal before changing the plugs? You could have just reset your ECU.
skydes is offline   Reply With Quote
Old 03-05-2008, 11:29 PM   #17
WeldingHank
Member#: 98645
2002 WRX Wagon
depending on your tune, you may have reduced the IAM. if its stock, your IAM will be 8 instead of 16. so you would only be getting 1/2 of your ignition advance.
Try this:
take off the negative cable again, and hit the brakes a few times. fire up the car and take it out without getting into boost. get up on the highway or somewhere you can get into 5th gear. put it in 5th and back down to about 2000-2500rpms. watch your boost gauge and boost up to bout 5-7psi for 4-5 secs. then feel how the car pulls, that should advance your IAM back to normal.
WeldingHank is offline   Reply With Quote
Old 03-06-2008, 12:57 AM   #18
Arctic Penguin
Member#: 119532
2006 WRX
0.7mm = 0.0275"
0.8mm = 0.0315"
Old 03-08-2008, 02:09 PM   #19
SVT_WRX
Member#: 164830
G61 III OVE 58e
Yep, its your IAM. Do the Vishnu trick and you should be fine. I know because I have an 02 that had the same problem. Do what WeldingHank said and you should be good to go.
SVT_WRX is offline   Reply With Quote
Spark plugs...A little help Panic Tri-State Area Forum 4 10-09-2006 11:29 PM
Spark plug change, need help!!! ftnjun2x Newbies & FAQs 13 05-13-2006 02:20 PM
spark plug wires? need help! motorswapsleeper Subaru Conversions 3 09-06-2003 08:58 PM
Spark Plug Cold Range Help Kevin Thomas Normally Aspirated with bolt-on Forced Induction Powertrain 1 07-30-2002 01:43 PM
$130 for MBC/Unichip/Spark Plugs install?? (Wanna help?) wayoutwest Southern California Impreza Club Forum -- SCIC 12 07-21-2002 12:54 AM
