Old 03-05-2008, 02:33 PM   #1
subiesurfer
Member#: 121330
06 impreza
SGM
Default any1 know what fabrication work is needed for older exuast to fit 2.5i?
the older exahusts that fit up to 01...anybody know what kinda work it needs to fit the 2.5i?
subiesurfer is offline   Reply With Quote
Old 03-05-2008, 03:00 PM   #2
Gr3en
Member#: 160991
05 Corn Burner
Dirt Silver?
You need old headers and cat. After that it should bolt up.
Gr3en is offline   Reply With Quote
Old 03-06-2008, 12:35 AM   #3
rcortez13
Member#: 157313
2007 2.5i
Obsidian Black
The most cost effective way is to have a muffler shop cut and re-weld the flange on the cat-back so it will match the flange on your car. Thats alot cheaper than buying a header, cat and 02 sensor wire extension.
rcortez13 is offline   Reply With Quote
Old 03-06-2008, 08:47 AM   #4
subiesurfer
Member#: 121330
06 impreza
SGM
^ thats what i figured, but does the piping need to be extended in any way?
Anyone know what this tool is used for? Wagon Joe Off-Topic 45 03-12-2010 12:26 PM
i need to know what this peice is called and where to buy besides the dealership knighter General Community 3 08-12-2008 03:54 PM
What oil pressure is excessive for a SUPER HIGH HP 2.5L? WRXINTX Built Motor Discussion 22 07-25-2006 12:09 PM
? What is needed for an RS to WRX tranny swap? TaiChih Transmission (AT/MT) & Driveline 2 01-16-2003 11:03 PM
What size bung is needed for factory EGT probe ? zaidallas Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 11-28-2002 12:39 PM
